Question about EnGenius EOC-3220 (EOC3220)
EOC -8610-S having problems conecting to 192.168.1.2, the login screen doesn't come up in the browser. It does on 192.168.1.1 though
  • 84 Answers
The devices can be misconfigured or damaged.
Check if radio working fine, perform a site sruvay with a laptop (wireless).
Posted on Oct 19, 2009
How do reset "EOC 8610
Push in the rest button on the back:
Reset Setting
  • Reboot (press 1 second)
  • Reset to Factory Default (press 5 seconds)
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
Dec 17, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
EOC-3220 connects but no internet access
What are you using for Internet connects? do you have the Access point connected to a Router. or is it connected to the Cable or DSL modem. I will need more information to complete this. If you have a router is is set to give an IP address or do you have a static IP? If it is set to give a Dynamic ip change the access point to recieve ip address from router and same with computer. If your connected directly to the Modem with the access point and you only have one IP address it will be used by the access point and not allow the computer to connect.
for more help please provide your internet (DSL, T1, CABLE) if you have router,  how it provides IP, and how access point is connected to it.
Oct 31, 2007 | EnGenius EOC-3220 (EOC3220)
I want to reset using RS323 port , i forgot its ip adress
Hi
You can reset the device through RS232 port then please follow the below steps.
You need a laptop with Console port and a console cable for EOC-8610 EXT, You really dont need the IP address if you want to do it via console (RS232) interface.
1. Connect the console cable one end to EOC-8610 EXT RS232 port and other end to Laptop serial port.
2. Open Hyper terminal and select com-port option and then provide the username and password for the device management.
3. Go inside the system menu and select Reset Factory default.
Remember if u set to load the factory default settings, the device will loose its config and will boot up with factory default configuration.
Nov 03, 2010 | EnGenius / EOC-8610 EXT / 54Mbps /...
How to setup internet between 2 EnGenius EOC-2610 devices?
Thanks for a very thorough problem report. It's a little ambiguous near the end, though, so I will have to restate what I think I understand you are saying.
You are saying that you have your internet connection and AP in one building, and two devices or PCs in that building can access the internet and share files (though you don't specify if they are using the EOC-2610 access point or are just accessing the router in some other fashion). But you have a remote building where there is one PC and one EOC-2610 in Client Bridge mode, and although both EOC-2610 units seem to be communicating with each other, the PC will not communicate with anything. (I presume you have inspected the access point's configuration screens and verified that it does have the other EOC-2610 listed as a connected client.)
First, the PC in the remote building has to be connected to the Client Bridge EOC-2610 by its ethernet cable in order to access the network. Second, the PC in the remote building has to have a valid IP address in the range 192.168.0.0/24, or it won't communicate with anything. If you are relying on your router's DHCP to assign your PC an IP address, verify that this has happened by examining your PC network properties. If you are assigning all IP addresses manually, make sure you have assigned the PC an address, and one that doesn't duplicate some other device.
Sometimes failure to specify DNS servers appears to be a lack of communication with the network. Open a browser and type 66.70.119.204 in the URL bar. If you get to fixya.com, you have a good network connection. If you type fixya.com in the URL bar and can't get the same result, you need to define DNS servers on the PC (or inside your router).
Mar 13, 2010 | EnGenius EOC-2610 802.11b/g Wireless...
I forgot ip address of my EOC 8610. how do i
Try address 192.168.1.1 in most cases this is default IP for the routers.
Sep 23, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Acabo de comprar un access point senao eoc 8610s ext y cuando acabe de configurar lo necesario para que funcione.....luego quise volver a entrar y ya no pude....es verdad qe le puse contrase?a, pero tome...
Translating this request to English, I understand you to be saying that after you configured this unit, you lost the ability to login to it using the name and password. This unit can be reset to factory defaults using the procedure in the file identified at the end of this message.
Traduciendo esta petición al inglés, le entiendo para decir que después de que usted configurara esta unidad, usted perdió la capacidad de abrirse una sesión a ella usando el nombre y la contraseña. Esta unidad se puede reajustar a los defectos de la fábrica usando el procedimiento en el archivo identificado en el extremo de este mensaje.
http://engeniustech.com/datacom/support/general-details.aspx?id=65
Apr 27, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Restoring engenius EOC 8610 to factory default
Resetting the older beige Engenius radios requires a screwdriver and a USB-to-serial cable. You must unscrew the small plate at the bottom, which covers a serial connector. Plug the serial cable into it and then into your computer. Follow these instructions to perform the reset:
Mar 31, 2009 | EnGenius / EOC-8610 EXT / 54Mbps /...
Resetting the engenius eoc 8610ext
I have reset lots of these using the manufacturer's instructions.
Plug in the serial cable before powering on the unit. When you power on the unit, you should be able to see a log of what the unit is doing. If you can't, then your parity, bits, speed, etc. in Hyperterminal are set wrong.
When the unit stops logging (usually with a #), type in
flash reset (and hit the return key)
You should see a bunch more logging, indicating that the unit is shutting down and rebooting. After that, you should be able to log into the unit at 192.168.1.1 with admin/admin or admin/(blank).
Aug 14, 2008 | EnGenius / EOC-8610 EXT / 54Mbps /...
EnGenius EOC-3220 (EOC3220) Logo
119 people viewed this question
Top EnGenius Computers & Internet Experts
rdarell
Level 1 Expert
Karen Gibson
Level 1 Expert
Are you an EnGenius Computer and Internet Expert? Answer questions, earn points and help others
