Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
We change the keypad code on our craftmans garage door open and now the remotes will not work and the light is flasing on the inside panel
    President:
  • 3,197 Answers
Press and hold for 3 seconds the button on the wall control with the lock icon.
Posted on Oct 06, 2009
My craftman 139.52606 opener does not have a learn button to set pin on keypad. I had keypad working at one time but since I changed the battery I can't rember how to reset the keypad.I also changed...
If the keypad is hardwired, do this:
To program the keypad, first unplug the garage door opener from the electrical outlet. Next, remove the nameplate from the console that the keypad plugs into and locate the program/operate switch. Flip the switch to program. Next, enter your desired four-digit PIN number into the keypad. Slide the switch back to operate and plug the garage door opener back in. The keypad should be programmed.
Sep 02, 2011 | Sears Craftsman LiftMaster Chamberlain...
Craftman belt 1/2 hp garage opener with security sensor plus system. All remotes and homelink programed. Unable to get keypad to work. Enter code with light switch pressed then top bar pressed and nothing,...
The simplest way to program the keypad is to press and immediately release the smart/learn button and then walk over to the keypad and key in your 4 digit code and press enter. If this doesn't work the keypad is bad or you have the wrong keypad. You don't say why you are programming everything so I am guessing about the wrong keypad part.
Jul 21, 2010 | Sears Craftsman LiftMaster Chamberlain...
My Craftman Garage Door Opener is approx. 7 yrs old. Remotes work fine. Keypad acknowledges receiving code, but then will not open door. Installed new bsttery.
If your keypad is the same age as your door and worked before it has probably just quit. If it is new and you have programmed it and it still doesn't work it may be the wrong one for your model opener.
Oct 04, 2009 | Sears Craftsman LiftMaster Chamberlain...
Can not program both keypad & remote to operate at the same time
One of your units has reverted from "rolling code" to "billion code" and as you have found they will each work but will not work with each other. The problem is finding out which unit reverted. The most common one is the hand remote but that could be wrong.
Aug 09, 2009 | Sears Craftsman LiftMaster Chamberlain...
Craftman garge door opener changing code on key pad
having all the remotes you want programed with you, find learn button on back of opener. hold button until little light goes out- no remote will work now, with each remote Press learn button once,Press big button on remote-light bulb on opener will blink on/off if bulb is working-do this each hand held-keyless is same way, put you 4 #'s in HOLD enter button-light bulb blinks on/off you have 15 sec. for each time you hit the learn button. also best to start off with new 9 volt battery before you start programing
Aug 19, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftman Garage Door
I enrolled in the Assistant Premium Plan and am waiting on a response.
Apr 29, 2008 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
106 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
