Question about Fuji FinePix S3100 Digital Camera
My Fuji 3100 arm came off that turns on the flash.
My Fuji 3100 Digital camera, when you open the flash lid their is a little arm that pulls up and turns on the flash. It has came off and fell down inside camera, can this be fixed.
JIM HARNESS
SOURCE: fuji finepix A600 camera - Zoom error
I had the same problem turn up after a few weeks. When I used the zoom button, the lens pushed out again and the camera worked normally for that time. I had to go through that procedure every time I turned the camera on.
I then sent it back on warranty and they replaced the lens assembly as well as the mode dial knob etc.
This camera has a 3 year warranty.
good luck...
Posted on Feb 19, 2008
SOURCE: Stuck flash on Fuji S5600
error focus
Posted on Mar 18, 2008
  • 109 Answers
SOURCE: flash not popping up or
The S700 does NOT have a manual release for the flash to pop up, but it DOES have a spring already. DO NOT try to force it! Set the flash to "FORCE", leave your lens cap on and waste a shot to allow the flash hood to pop up. Reset your flash to the desired setting and now the flash is already open and ready for use without the delay and the startling effect it has when your concentrating on framing your shot. As for the other problem of no flash in any setting: Check your menus to see if you have the flash totally disabled, check your batteries, does the "charge indicating light" come on at all between shots? In RARE cases, the actual bulb that flashes may be burned out, or a component in the flash circuit itself,such as the capacitor, may have gone bad. Did the flash ever work? If under warranty, return for repair or replacement. There are NO user serviceable parts in these tiny cameras
Posted on Jul 16, 2009
  • 11967 Answers
SOURCE: Fuji FinePix A345 Digital Camera lens is stuck, I
Fixing a Lens Error on a Digital Camera
This has to be THE most common failure mode for a digital camera. Some common error messages that might show up on the LCD's of cameras with this problem include “E18 lens error”, or “lens error, restart camera”. Some cameras might show nothing at all, but merely make a beeping noise as the lens goes out, then in, then the camera shuts off. Sometimes the lens won't even move.
The problem is actually quite common throughout all camera brands. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended. Believe it or not, one BIG contributor to lens errors is using a camera case. Sand, gunk, case fibers, etc... accumulate at the bottom of the case. These materials love to cling to the camera by electrostatic build-up from the camera rubbing against the side of the case (especially those cases with soft fibrous intreriors). Once these materials work their way into the lens mechanism, that's all she wrote. I have many Canon's, and NEVER use a case for this very reason.
A camera owner that suffers this problem may have no recourse for having the camera repaired. Many camera makers will not honor repairing this problem under warranty as they claim it is due to impact damage to the camera, or sand or debris getting into the lens gearing mechanism (neither of which is covered under warranty). The quoted repair cost is usually close to or more than what the camera is actually worth.
Fortunately, about half the cameras that suffer this failure can easily be fixed by one of the following methods. None of these methods involve opening the camera, although some have potential to cause other damage to the camera if excessively done. If the camera is still under warranty, before trying any of these, please please first contact your camera's maker to see if they'll cover the repair, or to determine how much they'll charge for the repair. Who knows, you might get lucky. But if they quote you a number that's higher than the value of your camera, you may want to consider the following methods.
The methods are listed in the order of risk of damaging your camera. Thus make sure you try them in the listed order. And remember, these fixes (especially #6 and 7) should only be considered for a camera that's out of warranty, who's cost of repair would be excessive, and would otherwise be considered for disposal if unrepaired:
Fix #1: Remove the batteries from the camera, wait a few minutes. Put a fresh set of batteries back in (preferably rechargeable NiMH 2500mah or better) and turn the camera on. If that didn't work, try pressing and holding the Function or OK button while turning the camera on.
Fix #2: Remove the batteries, then remove the memory card. Then install new batteries, and turn on the camera. If you get an Error E30, it means you don't have a memory card installed, so turn it off, slip in the memory card and turn it on one last time.
Fix #3: Insert the cameras Audio/Video (AV) cable, and turn the camera on. Inserting this cable ensures that the camera's LCD screen remains off during the start process. Thus extra battery power is available to the camera's lens motor during startup. This extra power can be useful in overcoming grit or sand particals that may be jamming the lens. If the AV cable doesn't fix the lens error by itself, consider keeping this cable installed while trying fixes 4, 5, and 7 as a means to provide extra help to these fixes. But note that I DON'T recommend keeping the cable installed during Fix 6 as you may damage the AV port while tapping the camera. Reinsert the cable only AFTER tapping the camera.
Fix #4: Place the camera flat on its back on a table, pointed at the ceiling. Press and hold the shutter button down, and at the same time press the power-on button. The idea is that the camera will try to autofocus while the lens is extending, hopefully seating the lens barrel guide pins in their slots.
Fix #5: Blow compressed air in the gaps around the lens barrels with the idea of blowing out any sand or grit that may be in there jamming the lens. Other variations include blowing with a hair dryer in “no heat” setting, or sucking the gaps with a vacuum (careful with this one).
Now we're entering into the realm of potentially damaging your camera in conducting the fix. There is definitely some risk here, so take care when conducting the following two fixes.
Fix #6: Repeatedly tap the padded/rubber usb cover on a hard surface with the intent of dislodging any particles that may be jamming the lens. Other variations include hitting a side of the camera against the palm of your hand. A lot of people have reported success with this method. HOWEVER, there is also some potential for damaging or dislodging internal components with this method, such as unseating ribbon cables, or cracking LCD screens.
Fix #7: Try forcing the lens. More people have reported success with this method than with any of the other methods. HOWEVER, there's obviously some potential for damaging your camera by using this method. Variations include gently pulling, rotating, and/or twisting the lens barrel while hitting the power button. Attempt to gently straighten or align the barrel if it's crooked or twisted. Another variation includes looking for uneven gaps around the lens barrel, and then pushing on the side of the lens barrel that has the largest gap (note pushing the lens barrel all the way in is NOT recommended as it may become stuck there). While doing any of the above, listen for a click that indicates that the lens barrel guide pins may have reseated in their guide slots. If you hear this click, immediately stop and try the camera.
Posted on Dec 17, 2009
Testimonial: "Thanks a lot, this is a F**king great solution, man you should post it a tip or something it's grat "
  • 11967 Answers
SOURCE: Zoom Error with Fuij FinePix - looking for "telephone trick"
Posted on Dec 28, 2009
Shaking icon always displays on fuji camera
On a Fuji camera, the little "camera icon" looks like it is "shaking" with an "apostrophe" next to is to signify a low light condition and shows up when the flash is turned off. A bad symbol choice in my mind but so be it.
Aug 04, 2012 | Fuji FinePix S2000hd Digital Camera
How do you change the battery in a fuji dl200 camera
You need to open the back cover completely. There is a little silver arm that prevents it from opening all the way. You can gently pull back on the silver arm where it attaches to the the body. It will pull away from the body and allow you to open the back all the way. There you will find the battery.
Thanks for choosing Fixya. Good luck and have a nice day.
Jan 18, 2012 | Cameras
Fuji finepix f810 flash wont pop up when button pressed
hi your camera is kind of getting old but it is still great. some people really like it. personally I like also. however, fuji finepix f810 has little problem like yours due to delicate design. on your flash problem could has two sequence check. first is flash circuit defective or flash tube defective. second is main pcb doesn't work properly with flash function. your local repair shop would charge around $75 to 185. Fuji camera usually charge more than other brand. I am sorry that you know. Good luck with you and best regard.
May 22, 2011 | Fuji FinePix F810 Digital Camera
I have a Finepixz Fuji camera and everytime I turn it o it says card protected what should i do to get rid of this issue
pull the SD card out of the camera, on the side of the card is a little slide switch, slide it in the opposite direction, this should make it "open" for you to use. If it still doesn't work, you may have a bad card or the camera may be the issue. Try a different card first.
Mar 10, 2011 | Fuji Finepix Z20fd Digital Camera
Flash won't pop up all the way open.
What has happened is a tiny little spring has broken inside or gotten out of position. Rather than try to fix that, get a thin rubberband (with circular, not flat, cross section) of the proper length as determined as follows. When you turn on the camera, select "force flash", and then half-press the shutter button, you'll be able to lift the flash unit with a fingernail under the crack separating it from the rest of the camera. Once open, put your thin rubberband under the black plastic "ridge" at the front of the flash unit; this ridge is just above the glass-enclased flash tube. As you pull the thin rubberband toward the back of the camera, put a half-rotation into it so that the rubberband crosses over it self (makes an X ) halfway back. One of the X-loops is under the ridge. Put the other X-loop around and under the eyeball-viewing protrusion on the back of the camera. If the rubberband is short enough (but not too short), it will have enough stretchy force to hold the flash unit in the fully open ("up") position. If you're lucky, it may also pop it open when the flash is called for. If not, use your fingernail and just let the thin rubberband hold it in the up position. It works for me.
Feb 24, 2011 | Fuji FinePix S700 Digital Camera
Fuji finepix e550 flash will not pop open. Was working fine then went to shoot wont open. Any ideas
Make sure the flash is turned on in the cameras settings.
is it stuck? try helping it a little with a small screwdriver carefully.
Sep 11, 2009 | Cameras
Fuji s5700 my flash is not popping up on auto
Don't blame the Fuji Designers for this fault - it was the Fuji Bean Counters that are at fault - the flash design is for TWO springs, the plastic casting has the holes for a second spring on the other side - which wasn't fitted so 100% overloaded the single spring mount.
Anyway if you are brave and handy you CAN fix this.
First remove the back of the camera - 3 screws in battery bay, 1 in the side above the memory card door, The two rear most on the bottom, two in the USB/video door, and the rear most on the left hand carry strap bracket.
Carefully prise the back rearward about 5 to 8 mm.
Now take a look at the two screw holes under the flash (when popped - or flopped out now that is broken) now go and bend a screwdriver of the type you used for the previous screws - you will need a 90 degree bend very close to the tip to fit in this gap and be able to turn the screws a few degrees at at time.
A little at a time lock the screwdriver into the screws and undo until the flash cover comes off.
You can then slide the shaft out of the flash to release the spring which will have the end that should fit into the broken bracket now sitting proud..
Make a suitable bracket like the one in the photo attached to slide over the broken plastic bracket.
make sure it fits really well the epoxy into position.
Getting the spring back in is a fiddly job - I found the best way was to fit the end of the spring into the new bracket, slide the shaft just into the spring - the lever the other end of the spring down into the back of the flash body and then slide the shaft all the way into place.
I did have to file down the little plastic "blade" inside the lid which presumably is designed to assist the the (now broken) bracket from breaking....
reverse the dis-assembly and now you should have a working flash bb61266_2.jpgbb61266_1.jpg
Jan 14, 2009 | Fuji FinePix S700 Digital Camera
How to replace battery in a Fuji DL-200
What luck! Today I was browsing a local thrift store and bought it for 99 cents. It looked like it might have a nice lens. I nearly gave up on finding the battery compartment, but finally figured it out. You need to open the back cover completely. There is a little silver arm that prevents it from opening all the way. You can gently pull back on the silver arm where it attaches to the the body. It will pull away from the body and allow you to open the back all the way. The battery I found was a Panasonic Lithium CR-P2 6V. I hope that helps.
Oct 14, 2008 | Fuji Cameras
Fujifilm a345
Remove batteries and clean the contacts in the bottom of the battery compartment with a pencil eraser and polish the compartment lid contacts. Gently polish with a tissue the card contacts. Then see what happens. If the same fault persists squeeze the battery cover. If it then stays on, open the cover ,take a small piece of foil to cover the batteries to pack it out a little.
May 22, 2007 | Fuji FinePix A345 Digital Camera
Fuji FinePix S3100 Digital Camera Logo
20 people viewed this question
Top Fuji Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Fuji Camera Expert? Answer questions, earn points and help others
