Question about Mitsubishi WS-65907 65" Rear Projection Television
Sound ok, OSD ok, no picture from any input.
Started as turn on would turn right back off (green light). After being off for three days power stays on, sound works, osd works, but no picture from any input. Convergence amps are new.
2 Suggested Answers
SD Tech
  • 14553 Answers
SOURCE: TV's picture and sound goes off. Had to cycle Mitsu WS-55513
THERE IS, aside from having the set taken to a shop, One other thing you can try---
NOT THE RESET BUTTON ON THE FRONT OF THE SET!
If the original Mitsubishi remote works on the set---this set has a hidden menu---it also in that menu has a HARD RESET---puts set back to the condition is was when new in the box--will come back on on channel 3 in the air band and any labels you placed on any of the video inputs (ie--named a input DVD etc) will be gone.
If you have OSD but no video either you have some problem with a single voltage coming out of the power supply(shop repair) or if you had a power outage or the power cord was removed with the set on---the hard reset may fix it---nothing to lose--set is not usable now---
Let me know if you want to try the reset and I will tell you how----
REGARDS, SD TECH
Posted on Oct 26, 2009
Lcd tv has sound but no picture, checked the inverter board and light is coming on the screen but no image
1. Symptom: Powers up, relay clicks, LED turns green, backlight comes on but there's no display from any input, and no OSD.
Solution: On the T-Con board labeled 320WTC2LV3.7, stickered J01420PE7F0288, check/replace:
F1 = 2A, 35V SMD (measured 9 Megaohms in circuit) - OK!
Dec 27, 2013 | JVC LT-32E488 32 in. LCD Television
No Sound, No Picture on LG 42LC7D
I do not have a solution but I have the same situation with my tv
Dec 27, 2009 | LG 42LC7D-UB Television
REGARDS, SD TECH
Oct 26, 2009 | Mitsubishi WS-55513 55" Rear Projection...
TV's picture and sound goes off. Have to turn off and back on then it work's for awhile then it happens again
On the signal board there is 4 surface mount transistors. There is oneright by the input board (BA09), i would check the corresponding capsand diodes2_bing.gif close to it also. I would replace all of the 4 transistors.If this SMT starts to go you will see wavy lines in your picture thanit will go away in 3 min or so and get worse over time until no pictureis seen. When it totally fails you will have no inputs what soever butyou will have an OSD screen and when you choose DTV you will get ascrolling picture.
Oct 25, 2009 | Mitsubishi WS-55513 55" Rear Projection...
Sound but no picture - won't stay on
you may check your lamp first. other than that i would say a faulty mains board.
Apr 16, 2009 | Samsung DLP HL-P4663W 46" Rear Projection...
My tv turns on but no picture or sound
power pack capacitors have failed they will need to be replaced with new ones and that should repair the tv, soldering skill is required to do this or replacement of the entire power pack.
hope this helps
Apr 07, 2009 | Samsung Televison & Video
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sony KF-60WE610 Screen and Sound On/Off
All symptoms in your TV shows that you need to replace its Lamp as it has been consumed its life hours and TV requires new lamp. Lamp can be obtained from Sony Website. Price is $200, Hope this info will help you to enjoy your Sony TV in coming days.
Aug 17, 2008 | Sony Grand WEGA KF60WE610 60" Rear...
Lcd 17"monitor phillips 170b4bb
that video input board will have to be replaced.
been there , done that.
Apr 25, 2008 | Computers & Internet
Mitsubishi WS-65907 65" Rear Projection Television Logo
21 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
