Question about BenQ FP557S (Silver/White) Monitor
I have problem with BENQ Fp557c monitor(Q5C3) model.No display.When power on monitor light remains yellow.then PC swich on it turns blue(Same as Green.VGA data OK)I check Monitor mother board for burns.No any mark.Fuse also ok. Any suggestion for solve this problem
SOURCE: Benq FP71G LCD Monitor - Can't keep POWER ON / Button Problem?
I had the same problem and found that Q808, Q809 and Q805 had failed and which if left long enough can also cause PF801 to fail. I also replaced all of the electrolytic capacitors during the rebuild as it was only a few dollars to do so.
Although in my case Q815, Q816 and Q812 were fine I suspect that they may also fail in time.
Here are the parts which should be available at most electronic stores or online.
Q808 & Q809 - 2SC5707
Q805 - IRFU9024N
PF801 - 3 AMP PICO FUSE
Posted on Jan 22, 2009
romsky79
  • 822 Answers
SOURCE: Benq FP92G Display couple of seconds then blank. LED still green.
budged electrolytic capacitor nearby high voltage transformer. 220microcarad/25Volts. apply fresh solder and re-connect lamps.
Posted on Jun 01, 2009
romsky79
  • 822 Answers
SOURCE: Monitor displays desktop for a short while
this kind of trouble is very common to all LCD monitors. your inverter is shutting down. please check all capacitors at the power supply some are badged or blown on top due to hot pressure inside.
Posted on Aug 17, 2009
SOURCE: benq 937s monitor stopped working. Green light on but blank scree
I have the same problem and have gotten it fixed twice. Going to be my third time now. Every time, they replace a costly part. I've submitted multiple emails during it's warranty through the tech support form at BenQ's official website and never once gotten a reply.
To solve this problem, pay to have it repaired and auction it in a yard sale to cover the cost. Then never buy a BenQ again.
~ Northkin
Posted on Feb 12, 2010
SOURCE: Where can I buy a logic PCB for FP71G Benq
Shenzhen VIIV Technology Co., Ltd is an expert at PCB,PCBA and Rigid Borad manufacturer based in shenzhen China.
MSN:viivtech@msn.cn
Yahoo: viivtechavril
SKYPE: viivtech
Mobile: 86)15989403359
Email:avril@szviivtech.com ,zhwei930@163.com
Website :www.szviivtech.com
Tel: 0086 755-29477736
Fax: 0086 755-29410695
ADD: sha
Posted on Aug 31, 2011
Benq t902hda
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
7. Also, you could try your display on a friend's computer. If it doesn't work, your monitor probably needs replaced. If it works properly on your friends computer, the problem may be with your computers video output port, motherboard video chip (or video card, if you have one), or drivers.
Mar 11, 2014 | Computers & Internet
Benq Q5C3
Someone would have to open the unit and see if fuse bad or even puffed up caps in the power supply for it.
Dec 06, 2012 | BenQ FP731 17" LCD Monitor
My monitor screen is ok for awhile but suddenly turns a dull yellow color. I just bought it a few months ago.
you must adjust the display settings in the software program that was being used to change the display setting.
  • If you have a flat panel LCD monitor, unplug the monitor power cable, wait about 30 seconds, reconnect the cable and then turn on the monitor. This resets the electronics on the monitor.
  • Make sure the monitor has power - the light on the monitor is on. If the light on the monitor is off, the monitor does not have power. Connect it to a different power outlet.
  • If the monitor has a detachable video cable, obtain a second monitor cable for testing purposes in case the cable is bad.
  • follw the another steps-
  • Replace the monitor power cable.
    1. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    2. Replace the video cable. Turn on the monitor. If the monitor displays an image, you are done. If the monitor remains blank, continue using these steps.
    3. If the monitor does not work after replacing the cables, replace or service the monitor
  • Thanks,
    Nov 18, 2009 | Compaq Presario 5000 PC Desktop
    Power light on no screen shown
    unplug from pc, turn on monitor. if there is a 'no signal' or any image displayed on the screen then the problem is not the monitor..
    Nov 15, 2009 | BenQ FP737S-D 17" LCD Monitor
    Jun 01, 2009 | BenQ FP92G+S (Black,Sylver) (Silver,...
    Xerox XA7
    ccfl tube is destroyed or fuse on inverter board
    Sep 01, 2008 | Xerox XA7-192i 19" LCD Monitor
    Benq 17"Lcd monitor fault
    Resolder the power transistors on inverter board and also check them.If display is not there at all some of this 4 transistors C5707 should be defective.Check associated fuse and Fet which drives the transistor.
    Also check with Benq ,Normally offers three year warranty.
    Samir
    Mar 23, 2008 | BenQ FP737S-D 17" LCD Monitor
    Secondary monitor
    When you first switch on Does it show Benq?If not the inverter circuit has failed.If you are technically able you can try resoldering transistors on inverter board.If your display is black all of the time transistors could have failed as also related fuse etc.
    And yes please check with BenQ Normally these have a 3 year warranty.
    Mar 05, 2008 | BenQ FP757 Monitor
    LCD monitor went blank
    Which model is it?Does power led remain on?
    Samir
    Jan 22, 2008 | BenQ FP737S-D 17" LCD Monitor
    On Pwr up logo appears then LCD returns to stanby Black screen
    I will assume the monitor is staying on during the boot process all the way until Windows loads.
    If that is the case, then...
    • Start the computer
    • wait until the initial bios/logo screens for your motherboard go away.
    • Press F8 to get the Windows recovery boot menu
    • If you see the Windows Logo you would normally see then press rest and try again.
    • In the recovery screen, select SAFE MODE
    • Boot into Windows and uninstall your video card.
    • Reboot the computer the normal way through the start menu.
    • When your PC starts back up it should then reinstall the video card, and set itself automatically back to 60khz as default.
    Let me know how you go =)
    Jan 20, 2008 | BenQ FP71E 17" LCD Monitor
    BenQ FP557S (Silver/White) Monitor Logo
    309 people viewed this question
    Top BenQ Computers & Internet Experts
    JP Services
    JP Services
    Tony
    Tommmix
    Level 1 Expert
    Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
