Question about Technics 13.5VDC 1.2A Class2 Power Unit (TEAD48131200U) Power Supply
Please help hi mate please can you help . i have a pretty old technics seperates there new class A and cant set them up , i was wondering if you could help as i cant find the manaul any where and its a nightmare if you dont know what ya doin , cheers
0 characters
1 Points
Power button won't start
It is possible that your power supply unit went out and will need to be replaced. Also the power button itself may have gone bad as well. It is either one or the other. Power Supply Units are located inside the box of your computer
It may be a good idea to take this in to a local shop to have this done if you have never done this before. Power button switches look like this.
Depending on your computer the power supply unit and power switch may be different as well. If you know what you are doing you can replace these pretty easily the degree of difficulty is about a 3 on a scale of 10 so not that hard all you have to do is plug in everything that came out and remember where the wires go. Mark them so that you will not forget I use a b c d on and on for each part or wire.
You can obtain a new power supply unit pretty cheap. Just take the old with you when you go to buy one. If you go online to buy one just make sure that you have the same one match the case numbers and you should be fine. Most power supply units are ATX it will tell you on the old one. I would start there and change this out. Thanks for using FixYa! please vote for me. John
Mar 13, 2011 | MPC Computers MicronPC power supply - 220...
Error while hibernating my coputer
it is not due to ram.... for hibernation there is a hiberfile.sys file in the system... its size depends on your system configuration....
it is 2Gb in my system.... depending on its size only your system can hibernate...
May 29, 2008 | Acer System Power Supplies
Compac battery problems.
Hi, I don't know of a driver you may buy for this. One thing you could buy is an external fan to help keep the laptop cool. This is a fan which is plug into the laptops usb port and the computer is place on top surface of the fan which is design to hold the computer.
Just a recommendation.
Oct 17, 2009 | System Power Supplies
Computer cuts off!!
Although you didn't specify whether your system is a Desktop or a laptop, but I will just tell you some basic, possible solutions.
From what you have described, three things are very much likely to be wrong with your system, and this are :
1. Your CPU Fan might be faulty and this makes your CPU to become unnecessarily hot. In this case, unscrew your system, or get a technician to do it for you, and change your CPU fan (Dont repair Please), then after that, make sure your PC always stays in a well-ventlitated and cool environment.
2. It might be as a result of a faulty VGA Adapter, if this is the case, just try and get an adapter card to replace the one inside, or let a technician do it for you also.
3. It might be your Power Pack that is faulty, so try and test your system with another power pack first, then if it work perfectly well, then you might just have to change the power supply.
Hope this helps you out. Sorry about the problem.
Jul 11, 2009 | System Power Supplies
Can i use 24-pin power supply on a 20-pin motherboard?
You can, with no problem.
The 24 pin power supply has the extra 4 pins on a "tear off" type of deal on the power supply connector. You seperate it, and you can then put in the 20 pins, in the older style motherboard.
Apr 05, 2009 | System Power Supplies
My laptop battery is not charging 100percent
Your Battery gone bad. So replace your battery.
If you have active contract call bto your laptop technical support they can help you in replcaing it.
Hope This Helps!!!  Please Don't Forget to Rate my Response!!! Thanks!!!
Mar 05, 2009 | System Power Supplies
I suggest buying a new power supply-it's really cheap...and I thing the motherboard is ok...most of the times the power supply takes all the damage...As in the fixing of the old power supply..well if your really ambitious about this, you could try it, but I REALLY not recomand you trying puting it on a computer ever again!Hope you'll listen to my advice!
Aug 26, 2008 | Gateway (ATX-300-12EB3) (ATX30012EB3)...
check ebay
Dec 17, 2007 | System Power Supplies
Power supply does not fit!
OK most PSU's are the same.. by that I mean as long as the output & connections match, then the size & shape don't really matter. On the PSU somewhere will be a "Wattage" rating say 250Watt... whatever.. simply obtain a standard (Usually 350Watt) PC Power Supply Unit (PSU)of the SAME or HIGHER Wattage rating & also ensuring the Mating Connector onto the MotherBoard is the same... ya be all good..
Aug 31, 2007 | Compaq (480082-001)...
Newly installed, first boot up PSU problem
If it's a new PSU, then return it for a replacement...Even online distributors will replace faulty units. And since your old PSU works on it, I'd have to say it's the new PSU that's faulty. Did you make sure that it's the right PSU for the CPU that you have? (As there are PSU units for AMD and seperate ones for Intel...Intel just has a additional power cord to connect to the motherboard)
Apr 06, 2007 | RaidMax Aurora RX580 (RX580F) 580-Watt...
System Power Supplies Logo
Top Technics System Power Supplies Experts
Kimberly Roegge
Level 1 Expert
Josh Whitehead
Josh Whitehead
 joe wright
joe wright
Level 1 Expert
Are you a Technics System Power Supply Expert? Answer questions, earn points and help others
