Question about Acer Aspire 5100 Notebook
My monior screen is flipped 90 degrees counter clockwise
  • Acer Master
  • 5,660 Answers
Press the CTRL key, and ALT key down at the same time. Now tap the Up Arrow key.
Posted on Oct 06, 2009
My screen does not flip 180 degrees when i turn the screen around
Computer users occasionally have a need to rotate, or "flip," a monitor display to be better able to read long documents or to view pictures. Because rotating a computer screen is such a basic function, modern operating systems (Windows XP and up) include hot keys and display options that enable the user to rotate the computer screen by 90, 180 and 270 degrees. Rotating the computer screen allows for more display options. For instance, when rotated 90 degrees, a 1680x1050 monitor becomes a 1050x1680 monitor, which provides more vertical pixels than a standard display.
Windows XP/Vista Monitor Orientation
Minimize any windows or programs to the taskbar. Click the desktop. Press "CTRL" + "ALT" at the same time. Press one of the arrow keys to flip the monitor orientation by 90, 180 or 270 degrees. The left arrow rotates the computer screen 90 degrees; the down arrow rotates the computer screen 180 degrees; the right arrow rotates the computer screen 270 degrees; the up arrow resets the monitor orientation. Rotate the computer screen in Windows Vista by opening the Control Panel, searching for "Tablet PC" and changing the "Orientation" drop box to the desired rotation. b> Windows 7 Monitor Orientation b> Click the Start menu at the lower-left hand part of the screen, and open the Control Panel. Select "Display," then click "Change display settings" from the left column. When using multiple monitors, select the monitor that you would like to rotate. Click the drop box next to the "Orientation:" option. Select the desired rotation and click "Apply." Click "Keep Changes" or "Revert," depending on preference. Click "Apply" in the Display Settings window. Click "OK" to finish.
Jan 28, 2013 | Panasonic Toughbook 19 Rugged Notebook -...
How do i set lock on axa ntc=95 combination lock
with the lock open (!) (with the right combination set, push the gray buttons backwards so the lock opens), then rotate the right triangular marker clockwise 90 degrees, then turn the numbers to set your new code, then place the right triangular marker back to it's normal position. (rotate back 90degrees counter-clockwise).
Took me a while to find out too...!
Nov 07, 2012 | Locks & Locksmithing
How do you change out water filter?
Hi and welcome to FixYa, I am Kelly
Press in hard.. rotate it 90 degrees Counter clockwise and wiggle / pull it out. When you re-install a new filter align the filter with the internal locking tabs and press in hard and rotate 90 degrees clockwise.
Some times the filter can br really fussy to remove you just have to keep wiggling and pulling to get it out of the recepticle once you have rotated it 90 Deg CCW.
Thanks for choosing FixYa,
Kelly
Feb 14, 2011 | Maytag MFI2568AES Stainless Steel Bottom...
All the item in my screen are rotate 90 degree counter clockwise ( horizontal ) how to change it to vertical position?
hi
press these keys together
ALT, CTRL and use the arrows beside up-down-right-left , to correct the view.
Feb 14, 2011 | Computers & Internet
Where is the water filter located?
The filter is in the refrigerator section in the space behind the vegetable bin. Thus pull the bin out to change your filter. Then remove the cap by rotating it counter-clockwise. Remove the old filter (turn 90 degrees counter-clockwise and then pull out) and then take the protective cap off your new filter. Slide the new filter into the housing and then rotate clockwise 90 degrees. The alignment marks should indicate the filter is locked into place. Then replace the cap. Remember to run water through the dispenser for several minutes to clear the lines.
I hope this helps.
(I don't have a manual for the RS2630WW; however, the Samsung RS2630SW should have the filter in the same place.)
Oct 23, 2010 | Samsung RS2630WW Side by Side Refrigerator
Pic up side down
  • Open the picture(With Windows Picture & Fax viewer)
  • Type "CTRL+K" to turn the picture 90 degrees clockwise. Additionally, instead of using the command keys, you may select the "mountain" icon. This icon located next to the magnifying glass icon on the bottom of the picture.
  • Type "CTRL+L" to turn the picture 90 degrees counter-clockwise or select the second mountain icon. This icon located next to the red "X" icon on the bottom of the picture.
  • Repeat the steps, changing the number of degrees as needed to adjust the picture to the correct angle.
  • hope this will help you... Have a Nice Day
    Sep 25, 2010 | Computers & Internet
    My acer aspire one netbook display was rotated 90% counter clockwise by accident. How can I restore the display to normal
    Right click on the desktop away from the icons. Scroll down untill you see something like ati or Nvidia control panel. Select that and look in the left hand side for either screen orientation or screen rotation. Choose 0 degrees or landscape.
    You can also get to these settings through the control panel > display settings > Screen Orientation > Landscape.
    Jun 21, 2010 | Acer Aspire One AOA110-1113 Netbook
    I pushed some keyboard sequence by accident and my screen turned 90 degrees counter-clockwise. How do I undo this?
    To undo this, press "CTRL + ALT + Up" arrow keys together.
    Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
    Aug 27, 2009 | Televison & Video
    Screen has turned 90 degrees counter clockwise
    press ctrl alt and the up arrow button at the same time and it should work fine
    Jun 06, 2009 | Dell Inspiron E1705 Notebook
    Background has turned 90 degrees
    You can flip the screen around by holding down
    CTRL + ALT AND ARROW KEY
    CTRL + ALT + right
    CTRL + ALT + left
    CTRL + ALT + up
    CTRL + ALT + down
    with these keys you can flip the screen around as you want. Noting serious.
    May 08, 2008 | Toshiba Satellite M30 Notebook
    Acer Aspire 5100 Notebook Logo
    104 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
