Question about Panasonic Audio Players & Recorders
Wireless digital transmitter doesn't work
The Panasonic SC-PT850W wireless digital transmitter doesn't ''connect'' between the rear speakers and the home theatre system, so the rear speakers don't work! The red W1 light flashes on the DVD system but doesn't seem to link?
I'm having this same problem; it worked all ok in the beginning then one day it didn't and no matter what I try it doesn't seem to connect. Similarly im getting the W1 flashing and even when I take the receiver and move it closer (even within a few feet) it still wont pick it up. I've removed the wireless home phone and baby monitor from within the room without any result. I cannot think of anything else that could be interfering. Any advice or resolution would be much appreciated.
Posted on Jan 26, 2011
  • OssS Jul 22, 2011
    i have the same problem , it was working well till one day , it start flash and no respond happened !!! please if you solve the problem notify me please
    thanks alot
Home Cinema Wireless Kit
It may be favorable to simply purchase a rear wireless speaker system all by itself and use the existing system for surround sound applications. Monoprice . Com has some units are a good price.
Mar 05, 2014 | Panasonic Audio Players & Recorders
How to set speaker delay on Panasonic Home Theatre SC-PT960
You need to go into the Video menu of the device and select 'Speaker Settings'. See the manual available from Panasonic.
Feb 17, 2013 | Panasonic SC-PT960 Theater System with...
Just purchased SBHS100AE-K rear speakers to connect to my SC-BT100. I want to connect them wired rather than purchase the wireless transmitter, but I can't figure out how to connect the wired rear speakers...
This unit is not as flexible as traditional receivers are as far as speakers are concerned. Speakers are labeled and *must* be connected to the correct speaker terminals.
Upon reading the manual - it is quite apparent that the only provisions for rear surround speaker connections is <i>only</i> via the optional wireless transmitter / receiver hardware. The optional digital transmitter is connected via a proprietary plug on the rear of the SC-BT100. The optional receiver amplifies the received signal and passes it to the connected surround speakers. I would bet that there are no provisions for amplifying a surround L and R speaker channel inside the SC-BT100, and that it only provides a low level (like a "tape out") or un-amplified signal to the transmitter plug. Even if you were to manage to get the surround speaker connections made up there - you would not be able to hear anything from them - as there is no amplifier. The amplifier is contained in the wireless receiver, and is largely why it requires a connection to house current.
Unfortunately, I doubt you'll find a way to listen the surround channel audio from the SC-BT100 without the optional transmitter / receiver and the integrated amplifier.
You can review the manual like I did here:
http://service.us.panasonic.com/OPERMANPDF/SCBT100.PDF
I hope this answered your question.
Jun 11, 2010 | Panasonic SC-BT100 Theater System
Panasonic Wireless Rear Speakers Ticking
move ur speakers around. if the noise is absent on some places u can be sure its the digital box. or one fix that might work is - get aluminium foils and wrap ur speakers. this can blank out interferences. if that works, open ur speakers and line the walls with thick aluminium foils. hope this helps.
Apr 13, 2010 | Panasonic Home Theater System System
I got a panasonic sc-bt100 from sears used but i cant connect the rear speakers i think im missing a part do you need to put something on the dvd player so the rear speakers could work?
There should be a "module" that you slip into a slot on the back of the main SC-BT100 unit...this is the transmitter that sends the signal to the rear speaker unit. The rear speakers, while "wireless" to the main unit, are wired to the separate unit that should have come with your set-up.
Oct 02, 2009 | Panasonic SC-BT100 Theater System
I just bought a dvd home theater system sc-pt760 and i have a 42 inch LG flat screen and the sound wount work on AUX for the TV
Are you using the HDMI connection on both units, the SC-PT760 does have a HDMI input Yes/NO ? If not then it has HDMI output to the LG for HD Picture. What I would do if no HDMI INPUT to the SC-PT760 is available, run out of the TV with the Digital connection into the SC-PT760 Digital Audio in, assign the input as tv and you shoild get TV audio out of your home theatre, you could also use the analog connection audio out of the tv to the home theatre but this would not yield a dolby digital sound.
Feb 02, 2009 | Panasonic Home Theater System System
Connecting rear Wireless Speakers on Panasonic Home Theatre Kit
Hi
Just push and hold the fast forward button on your receiver and push the button number 3 on your remote simultanously
your unit cames in pairing mode a P appear in the display
after, goes to your wireless receiver and push the reset button on the back
normally after that the unit must connect with your receiver
Dec 29, 2008 | Televison & Video
Panasonic SC-PT850w sound cuts out
Are you watching 10HD off the air from an antenna? You are losing video and audio intermittently, which may just be indicative of a weak signal. Does your TV have a signal meter?
Apr 27, 2008 | Panasonic Home Theater System System
Panasonic home Theatre
You need to obtain audio leads and connect from home theatre directly to audio input in back of tv - be careful as there are normally 2 in back of tv
Dec 14, 2007 | Panasonic SC-HT720 System
490 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
