IAM HAVE A HARD TIME TO FIND A LIMIT SWITCH .
  • mahubhai Oct 06, 2009
    AHW-938D-M-2 FRIGIDAIRE A/C LIMITSWITCH IS BURNT I CAN NOT FIND THE RATEING'S OF THE SWITCH IF U HAVE A MANUEL AND CHECK THE RATEING'S AND WERE TO BUY ONE !
  • 3,267 Answers
A limit is a protection device designed to shut the flames down when a temperature has been exceeded for whatever reason.This is applicable where HVAC are used. In hot weather the thermostat setting is to cool, so it does not have anything to do with heating. When you switcht over to heating option the furnace lights up and the hot air is forced to circulate the air a BLOWER is used. Thus the limit switch is located near the blower assembly gets electrically activated. The limit switch is generally used very little since one does not have to set it everyday. Look near the FAN/BLOWER assebly for the limit switch It ts a knob with heat cliberation readings in Fahrenheit or Celsius or both for sitting the pointer at the desired temperature...........sodeep
Posted on Oct 06, 2009
    President:
  • 1,462 Answers
Can you give me your model and make, so i can proceed further..
And please elaborate your question, thanks
Please leave it as comment, we may help you in solving your issue
RNJ VINODKUMAR
Furnace blowing cold air after replacing limit switch
Limit switches are safeties and require a manual reset. They are also a Normally Closed contact. A hi temp. thermostat operates on its own. If you are sure it is a limit, find the red little button and listen for it to click. Sometimes they push pretty hard.
Feb 03, 2013 | Coleman 7990-319p Evcon Gas Furnace...
Have a gmp125-4 furance blower runs all the time checked themostat wires error code 1 blink then 2 then 3 then 5 furance works if you turn power off turn back on when heat kickes off blower comes on gives...
Sounds like limit switch issue. Furnace heats up, high temp limit switch opens, fan will stay on. GMP model is older and do not have the codes.
May be over fired, have airflow problem, to cause the limit to open.
Next time before shutting off power, try to find the limit, it has two wires that connect to a 1.5 x 2 inch card mount to the furnace fire wall. tap on it and see if the blower stops. If so replace the limit.
Sep 06, 2011 | Goodman Heating & Cooling
Hi, I have Starling QVX heater. The air flow space where the limit switch is located heats up to around 210 Degrees after the furnace runs for awhile then the switch cuts off the gas and the fan...
The should be a temp stamped right on the limit switch telling you it's limit. It is very possible it is going bad. I know they make adjustable limits but would not go too much higher than what is in there now. Good Luck!!
Apr 27, 2017 | Sterling RF30 Natural Gas Garage Heater
Door comes down and goes right back up. then the lite blinks 4 times with a click noise. the safety eyes also are not on
It sounds like you need to adjust your down limit switch and/or perhaps your motor force settings. If the limit switch is not in the sweet spot along the rail it can be triggering too soon or not in time. In your case it could be too far down the rail and thus not stopping/slowing the motor in time. Your door is then being pushed against the floor too hard. Your safety/return force is goes way over limit and tells the opener to go back. While closing your door look at your rail and if its bending when the door hits the ground, this is definitely happening. After finding the sweet spot for your down limit switch, you can readjust your return/safety force per your opener manual.
Jan 03, 2011 | Chamberlain 12HP Power Drive Chain Drive...
HI IAM A ELECTRICIAN WORKING ON A LAAR HOT WATER BOILER WITH A STORAGE TANK THE TEMP IS SET TO 160 THE HIGH TEMP LIMIT SWITCH IS SET 200 AND THE AQUASTAT ON THE STORAGE TANK IS SET ON 120 THE BOILER COMES...
I would suspect a water circulation problem, most likely air in the system, if the water can't flow it will overheat.
If the problem persists after bleeding check to make sure the pump is running
May 06, 2010 | Heating & Cooling
MY IPHONE IS LOCKED HOW CAN I UNLOCK IT.WHILE IAM COPYING ITUNES TO MY PHONE IT IS LOCKED.ON SCREEN IAM GETTING ONLY THE EMERGENCY CALL KEY PAD AND NOTHING IS THERE.IAM NOT ABLE TO OPEN THE MAIN MENU
Dec 26, 2009 | Apple iPhone 3G
2004 Jeep Grand Cherokee. Keeps stalling, engine
P0505 means the whole Idle Control system, not only the IAM. Check all related sensors (i.e. crankshaft sensor). Check with a voltmeter direct at the connector of the IAM if you get any signal. Remove the IAM from the TB, connect him, let someone switch your ignition key to ON. The IAM need to drive in/out for a short time to find the right position. Hold the IAM near a hard part, that they cant drive out completely! If IAM works fine, check the fuel pressure, check and clean your TB ( if not done yet). If that doesn't work, come back again please
Oct 25, 2009 | 2004 Jeep Grand Cherokee
Win xp sharing connecion
For Windows XP Professional, the maximum number of other computers that are permitted to simultaneously connect over the network is ten. This limit includes all transports and resource sharing protocols combined. For Windows XP Home Edition, the maximum number of other computers that are permitted to simultaneously connect over the network is five. This limit is the number of simultaneous sessions from other computers the system is permitted to host. This limit does not apply to the use of administrative tools that attach from a remote computer.
Feb 01, 2009 | Microsoft Windows XP Professional With...
LImit Switch on AC/Heater Unit for Home
Get a diagnostic fee only, then determine if you can fix it yourself or not. Generaly you should only pay around 65. Depends on your service tech, call around. meBNme is on to something check your filters, if the unit is suffering from any air restrictions, it could be going off on high pressure. You could also be overcharged and or overcharged (from a leak).
Dec 06, 2008 | Heating & Cooling
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
