Question about Cycling
I have purchased a Cyclops Stone Mountain bike and I don't have a manual. I am wanting to know how to adjust the front brakes as one of them is rubbing up against the wheel which is making the wheel hard to turn.....any ideas or do you have a manual on this bike.....thank you Sandra.
  • 1,305 Answers
There are adjustment screws just above the brake calipers where the cable ends . You can adjust the barrel screw that the cable passes thru. Turn the screw clockwise, which should allow more slack and allow the brake to lessen it's grip...
If that doesn't do the trick, you can loosen the clamping nut on the cable and let the caliper open up a little then retighten. take your time and be careful to make sure the brakes are working correctly before you ride..
K
Posted on Oct 06, 2009
How do I adjust the front disc brake on the Genesis V2100 mountain bicycle, model # 52686?
adjust the cable at the brakes or and piece by turning the retainer that holds the outer cable case
May 24, 2016 | Genesis 26 Inch V2100 Dual-Suspension...
How do i adjust mountain bike brakes
There is a small tension nut on the cable near the brake calipers on the cable coming from the brake. Loosen that nut and squeeze or loosen the brakes to where you want them and then retighten the nut on the cable.
Sep 08, 2012 | Magna Women-s 28 In Cityscape Bike
I HAVE A ROAD BIKE SHIMANO 7 GEARS WHAT IS THE BEST WAY TO ADJUST THE FRONT MECH SO THAT I CAN **** TO THE BIG CHAINRING AND ALSO TO THE SMALL CHAINRING. MY SECOND QUESTION IS ABOUT THE SHIMANO MECH DISC...
Park tools has a great online bike Matanance guide. Use these links to adjust your derailer and brakes. http://www.parktool.com/blog/repair-help/front-derailleur-adjustments http://www.parktool.com/blog/repair-help/categories/brake-service-and-repair To adjust your brakes, look at the page and use the article that best gifts your brakes. Unless you have REALLY nice brakes, you have mechanical brakes.
Jul 22, 2011 | kona-mountain-bikes Kona Bicycle Co. Dew...
Adjusting brakes on relaigh bmx
Vist the Raleigh (note the spelling) website amd download the Single Speed Manual. Page 13.
http://www.raleighusa.com/downloads/owners-manuals/
You could also use any Search Engine and enter "adjusting brakes on bmx bike" for video instructions.
Jul 07, 2011 | Mountain 3 Raleigh Bikes Bmx Road Frame...
Is there a Bianchi bike owners manual so I know how to adjust the gear lever?
Look on the brake lever for a manufacturer and model number (probably Shimano). Even if you can't establish a model number, go to the website and find the mountain bike shifter that is closest to yours, There will probably be a technical manual for it and it will describe how to install and adjust it. You'll also want to look for and understand the derailleur it controls.
http://techdocs.shimano.com/techdocs/index.jsp
Dec 26, 2010 | Bianchi Mountain Bike 19"/49cm
My diamondback mountain bike brakes need adjustment. the pads sit too close to the rim and rub constantly. how do i adjust the caliper so the wheel turns without interference? is there a document...
For brakes you need an instruction manual or repair book. Brakes are a little too complicated to explain in detail in a simple document. Although the service manuals for the brakes have a decent amount of explanation, they do not outline specific tools and other helpful information.
For the component owners manual you will have to visit that component companies website (ex. Shimano = (www.shimano.com) and look under tech documents.
For a good book, try Zinn and the art of mountain bike maintenance or The big blue book of repair from Park tools.
Side note: double check that your cable and housing is seated throughout its route from lever to brake, if the housing comes unseated from the frame stops it will shorten (tighten) the brakes, Also check to see if you have any adjustment at the lever to reduce the tightness of the brake cable (there should be a knurled nob at the end of the lever where the brake comes out, if that is screwed out away from the lever this will shorten (tighten) the cable tension, screw it back into the lever. Finally you can loosen the cable at the brakes, opening them up, then retighten to make the brakes work.
Dec 13, 2010 | Diamondback Outlook 26" Mountain Bike
Men Mountain Bike (26"): How to adjust tention on the rear brakes...
Your bike likely has linear pull brakes so you will need to a. loosen the pinch bolt that holds the brake cable to the noodle (down at the wheel). You then pinch the brake in towards the rim with your hand until it's almost touching and then retighten the cable. You can then do some fine adjustment on how close the brake pads are the rim with the adjusting nuts up at the levers.
May 18, 2010 | Huffy Men Mountain Bike (26")
I am looking for a manual for a mongoose tech 4 mountain bike or instructions regarding how to adjust the brakes
The brakes should have a label on them so you can find their website. Most of the good manufacturers have directions on their sites for adjusting their products. The bike I looked at had V brakes. http://www.sheldonbrown.com/canti-direct.html is the site to look at. Great pictures and good explanations.
Jun 24, 2009 | Mongoose Tech 4 Full Suspension Mountain...
Cycling Logo
587 people viewed this question
Top Cycling Experts
Michial Gueffroy
John Egan
John Egan
Are you a Cycling Expert? Answer questions, earn points and help others
