Question about Dryers
Kenmore Elite HE3 Electric dryer model 110.82832100 if the heating element is out, would that also cause the status lights to not go on either?
    President:
  • 1,304 Answers
It would in the following case, your polarity is reversed at your outlet,
in that case L1 is running through your heater to the control, there by if your heater is bad or out you might not have the proper voltage to them
Posted on Oct 06, 2009
I have a Kenmore Elite HE3. My dryer will not heat up and I have replaced the heating element, blew out the ducts, I have checked the fuses and the sensors and still no heat. Everything checks out and I...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Sep 10, 2011 | Kenmore Dryers
HE3 Dryer not heating
check the thermal fuse and also check to make sure you have 220v at the outlet.
Jul 23, 2010 | Kenmore Elite HE4 Electric Dryer
My kenmore elite he3 dryer has quit heating could it be the heating element and if so where can i find it on the dryer? The model # is 110.82822103 and the serial# is MR1751757
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Jun 05, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
Dryer will not heat up.
There can be a few reasons why an electric dryer does not heat...
Check out this tip that I wrote... it iwll help you find tha thing that is causing your problem..
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Apr 06, 2010 | Kenmore Elite HE3 Steam 8674 Dryer
My Kenmore Elite (Whirlpool) HE3 elctric dryer is no
A dryer not heating usually means that either the heating element is burned/broken (open circuit); a thermal fuse in line with the heating element is blown or; a thermostat is faulty.
Dryer needs to be partially disassembled to diagnose with a multimeter.
Charlie
Sep 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
My kenmore elite he3 dryer does not heat with no codes
a couple of problems could cause this heating element or possible that one of the thermostats has gone bad.bset thing to do is check the continuity of the element and thermostats.if you meter has a tone one it when you check this they should all have a tone if they are good.if they do not tone out then you have found the problem
Sep 16, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 Gas Dryer - Heat flame will not ignite
The Igniter glows, then shuts off without igniting gas - the problem is probably with defective coils (black, located on top of the gas valve). It is recommended to replace all coils (usually two or three) if found defective.
Note: Sometimes the whole gas valve may be defective, thus not letting the gas out. However, this problem is not common.
Jun 20, 2009 | Hotpoint NVL333EY Electric Dryer
Kenmore elite dryer no heat
You may want to check if the heating element needs replacing. Most Dryers have 2 heating elements that are found by taking the back off, some of the newer dryers have 3.
Jun 08, 2009 | Kenmore Dryers
Kenmore elite electric dryer want heat
chances are the element is broken. generally the element will eventually break at a weak point. if you are a "fix it yourself" type you can repair the element with a little efort. (be glad to tell you how if t you choose this as apposed buying a new one.
good luck.......jay
Mar 20, 2009 | Kenmore Elite HE3 Steam 8674 Dryer
Kenmore Elite HE3 dryer stays cold
you probably need a new heater element.
Dec 12, 2008 | Kenmore 82822 Electric Dryer
Dryers Logo
224 people viewed this question
Top Dryers Experts
