Sounds like you have a broken drum belt.
If you have to replace your drive belt and if you have a front loading machine. First you will need to unplug your dryer from the electric. Remove the front of the machine, this will expose the belt and drum, remove the drum and belt and this will expose the drum rollers, idler arm bracket with pulley, and motor with pulley. While you have the drum out, I would also recommend that you lubricate the drum rollers at the shaft of the roller with a good grade of machine oil like 3 in One oil. This will save you problem later with the rollers getting noisy, also check your drum rollers for flat spots, if they have flat spots on them this will cause a noise like a thumping type noise. You will need to replace the drum rollers if they have flat spots on them.
If the belt is not broken, then I would check to see if the timer switch is working properly, if not then you may need to replace it. Good luck, I hope this helps
Was this helpful?
Yes
No
Popular Solutions for Roper REX3614KW Electric Dryer
Roper dryer bearing out? I have a Roper dryer that I bought around 1997. I has been squeeling loud...
(More)
Roper dryer bearing out? I have a Roper dryer that I bought around 1997. I has been squeeling loud for the last week when we first start a load, now it won't start turning if there's a full load. The bearing is out, right? How Hard is that to fix?
The dryer is getting warm, but not hot. When I first bought it I couldnt touch the clothes they were...
(More)
The dryer is getting warm, but not hot. When I first bought it I couldnt touch the clothes they were so hot. now it just seems they only get warmm Any ideas?
how to determine if the start button is broken? fuses are working, circuit breakers are fine...the...
(More)
how to determine if the start button is broken? fuses are working, circuit breakers are fine...the dryer won't do anything when we push the start button.
