Question about Garmin nuvi 200W GPS Receiver
GARMIN ARE HOOKUP TO PC, WHAT IS NEXT? - Garmin nuvi 200W GPS Receiver
  • 687 Answers
You will need to install Garmin Mapsource and then upload your Map to your PC you will be able to save waypoints and transfer POI (points of interest) to you satnav.
You will need to register for an account and also your unit ID on the back at myGarmin
Hope this helps.
LOL
Posted on Oct 06, 2009
To get it started it will not open just comes up garmin
Have you tried reloading the software from the Garmin support site, if not do that. You can also call Garmin the phone number is listed at the support site. You will need a USB cable for the hookup specific to the Garmin GPS
Jul 08, 2016 | Garmin GPS
My Garmin nuvi 40 does not start
Is it getting ac power or battery? Plug the usb attachment in and hookup to computer, Troubleshoot from there. How old is the Garmin?
Oct 04, 2013 | Garmin Nuvi 40
I have received the lifetime update card for my Garmin 255W. Now what do I do next? Apparently I need a username & password. Where do I do that?
When you register your satnav at www.garmin.com you select a username and password. If you haven't already done so you'll need to connect your satnav to your pc to register it. If you have and have forgotten the username and password you'll have to contact Garmin Support. Contact details are at http://www.garmin.com/garmin/cms/cache/offonce/us/support/supportcontact;jsessionid=451C4302E8469EEE9E7F2C9DABE2DD6D
Jul 24, 2010 | Garmin nuvi 255W GPS Receiver
What are my options for GPS hookup. My lighter
you should probably check the fuse box and make sure a fuse is not blown for your lighter
Mar 18, 2010 | Garmin Nuvi 660 GPS Receiver
Computer not recognising Garmin 765T GPS
go to programmes and look for Garmin, see if that has a programme called "web updater" if it has remove it (uninstall) then go to garmin.com and reinstall web updater when done reconnect gps and follow instructions
Jan 03, 2010 | Garmin nuvi 765T GPS Receiver
My garmin cannot start
Hi there... If you mean it doesn't do anything when you push/slide the on button, then try this... (mine did the same thing just yesterday and was a result of a very low battery - would not even start with 12v cord in from the car!)...
Find the USB cable that came with your Garmin. Hook the USB cable to your computer, with the other end hooking up to your Garmin (where the normal car cable goes).
The Garmin will probably turn on instantly once you have hooked it up to your PC (assuming the PC is turned on and in Windows etc). This will actually charge the Garmin battery too while hooked up the PC, so leave it connected for a little while (a couple of hours).
If it doesnt switch on automatically when connected to the PC, try using the slide ON switch. Once it is active, it will be in PC transfer mode (assuming you have an SD card in the card slot of the Garmin). Now is a good time to use the Garmin WebUpdate application (available from www.garmin.com) to see if any software updates are available for your unit. If so, go ahead and install them. I updated mine yesterday!
Once you get it working via connection to the PC and the battery has charged up a little, take it back to the car and keep the 12v car cable plugged in all the time. This will continue to charge it up as it is being used (while the car is running of course). You should find that after u get it working on the PC it will again work in the car too...
i think it just turns it off for some reason permanently when it gets a really low/dead battery and only the PC hookup seems to re-activate it... Also, apparently you can hold the slide switch on the Garmin in the ON position for 7 seconds to reset the unit, but that didn't work for me... Worth a try anyway!
Jan 16, 2009 | Garmin nuvi 260W GPS Receiver
I purchased a Garmin nuvi 200 and registered it 12/22/08. I would like to update it on line. How do I go about it. I need a tech to help me.
First, you need to have a USB cable that connects between your PC and your Nuvi. Next, go to www.garmin.com and download their webupdater program onto your PC. Next, Connect the USB cable between your PC and Nuvi and run then run the webupdater program. Garmin will scan your Nuvi and then you will be prompted for various selection of updates.
- Jim
Dec 03, 2008 | Garmin GPS
Connection problem maybe ? im not sure
make sure that you have the garmin driver downloaded onto your pc
Nov 12, 2008 | Garmin StreetPilot i3 GPS Receiver
SATTELITE NAVIGATION
Install Mapsource program from the CD and also install the maps. Start Mapsource program and use the Map tool to select the states you want to install. Now hookup your Garmin to the computer and Transfer the maps to the Garmin
Oct 19, 2007 | Garmin StreetPilot i3 GPS Receiver
Cannot load map in my Garmin Streetpilot i3 GPS
i dont think you can upload maps to an i3, it can only load pre-loaded maps on micro-sd cards.
Sep 22, 2007 | Garmin StreetPilot i3 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
