Question about Canon MX300 Office All-In-One Printer
My printer won't print out ink. Printer is
My printer won't print out ink. Printer is installed, cartridges are full. Any suggestions?
SOURCE: Installation of ink cartridges
is this still current?
Posted on Aug 19, 2008
  • 4 Answers
SOURCE: Reset ink level on CANON MP 140 PIXMA PRINTER
How to reset the Canon MP150 after a refill (Step 10 concerns refill; instructions below the steps):
Method1 (Safe Factory Method):
1) Disconnect the printer’s power outlet
2) Press and hold the power button while connecting the power outlet back.
3) While still holding down the power button, press the reset button twice.(red circle with a triangle)
4) Release the power button
The printer takes about 10 seconds to show the number 0.
5) Press + to change the value from 0 to 1.
6) When this value is 1, press colour button; this will light up two leds.
One is for plain paper and the other for photo paper. At this point is feed the printer with paper.
7) Press the power button twice and the printer will print a some stuff (if it doesn't print by itself, then press the "color" button once and the test sheet will print). Don’t worry much about the printed material. I got some stripped lines and some numbers. I believe that my colour cartridge is clogged which is why I got the green strips.
When you print this sheet the value in the display returns to zero.
8 ) Open the printer cover cover (not the scanner cover) and remove the cartridges. With the printer still open, disconnect the power outlet.
9) Close the lid and turn on the printer.
10) Refill cartridges and place them back in their nice little abode in the printer.
Posted on Jan 09, 2009
yooperbud
  • 8637 Answers
SOURCE: cannot align ink cartridges in my cannon mp160 printer
Normal 0 Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Posted on Jan 28, 2009
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
SOURCE: Canon Pixma ip1900 Printer wont print
Silly me!!..I thought that friends of the internet would give me free advice (just lilke I do!)..thanks guys but no thanks..I'll ask around on a friendly and free site.....
Posted on Oct 24, 2009
I have a Lexmark Pinnacle Pro 901 printer and its set up to print using black ink only, but it keeps telling to replace color cartridges and it won't let me print at all, how do I print using blac
The printer would need all cartridges to have sufficient ink levels to continue printing - that's to prevent damaging the printhead. Every time a cartridge is replaced, all colors are primed simultaneously thus the need for all cartridges to have ink.
To save on your ink investment, try printing in draft mode and by making sure that your printing preferences is set to print using black ink only.
Oct 25, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Ink shows full but color won't print
Uncommon faults are with the electronic drivers in the printer system that drive and control the printer cartridges. This is providing the cartridges are proven to not be defective. Also, jammed nozzles will prevent printing.
Make sure your software is not set to print in monochrome (B&W) only .
Jerry G.
Sep 08, 2012 | Epson Workforce 610 All-In-One InkJet...
My printer won't print? it has full ink cartridges.How do i fix it?
Maybe your cartridges are not out of ink. Try it with another game cartridge kit...
Apr 30, 2012 | Canon PIXMA MP780 All-In-One InkJet...
Epson Stylus Photo R220 Ink Jet Printer won't print with new ink cartridges
Silly question: Did you remove the plastic tape from the bottom of the cartridges when you installed them?
Apr 30, 2012 | Epson Stylus Photo R220 InkJet Printer
Installed new ink and now won't print anything, not even a test page. says error. deskjet 4400 series
Each ink cartridge has a metal, thin Copper 'plate'.
In this 'plate' there is a series of VERY small holes. The holes are so small it's hard to discern their existence, with just the ***** eye.
The area on the printer's body, that the copper plate matches up to, also has matching holes.
After a given time the ink dries up in these tiny holes.
The dried ink needs to be removed.
Printer UNPLUGGED from power, printer case open.
I would suggest wearing dish washing gloves, and remove all ink cartridges.
Small bowl half full of distilled water as hot as you can stand it, dip a clean, lint-free cloth in it. (Distilled, because non-distilled water can leave hard water spots)
Squeeze all excess water out until the cloth is damp. (D-A-M-P) Wipe the area on the body of the printer.
I would suggest wiping in one direction only. Wipe, then go to a fresh, clean part of the cloth, wipe again.
Keep wiping until the cloth picks up No ink.
You may want to follow suit on the ink cartridge/s now, as they may have picked up dried ink.
Suggest use a can of compressed air for computers, and make SURE all areas are D-R-Y.
Allow the printer to set open to dry afterwards. May only take 30 minutes, or less.
Ensuring all surfaces are dry from the water, reinstall the ink cartridges.
Close the printer's case. Plug back into power, WAIT 1 minute, then turn on.
Regards,
joecoolvette
Dec 10, 2011 | HP Office Equipment & Supplies
Hi, I have re-filled the black toner cartridge, but the display says it is still empty. The red light is on and it won't print. Any suggestions please? Many thanks.
you need to use the menu on the printer and find the selection that says printer options-> ink cartridge-> new ink cartridge. what happened is you never told you printer that you were installing a new cartridge so it thinks that its still the old one. The printer actually never checks cartridge levels it just makes predictions based on how many pages you have printed.
Jun 30, 2011 | Samsung CLP 300 Laser Printer
I have changed the colour ink on my canon mp460 but it still say empty
CL41, this is the one you are using for your cartridge.
Did you change your cartridge with brand new one or refilled one??
If you did with refilled one, the ink level won't go back with full.
This is the method how printer measures the ink level.
1. Each cartridge has a serial number.
2. As soon as installation in printer, printer recognizes the cartridge by serial #.
3. And the printer starts to count the printing document.
4. After reaching certain print counting, the ink level will show "low ink"
So my answer is even if you refilled your cartridge, the ink level won't change,
since printer cannot weight the cartridge or.....some other technology to measure each color ink level.
Thanks.
Jun 15, 2011 | Canon PIXMA MP460 All-In-One InkJet...
After installing re-filled ink cartridges, both color and back & white, the printer message that shows ink level still shows low level ink? How do we resolve?
Try this procedure:
1. Open printer lid so cartridges move to center of carriage.
2. Lift clamp and remove black or color cartridge from the holder.
3. Place cartridge on table with copper contact strip facing you.
4. Carefully place a strip of clear plastic tape over the four contacts on the upper left corner of the cartridge.
5. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position.
6. Open lid and remove cartridge again. Remove tape from left side and place tape over four contacts at upper right corner of cartridge.
7. Reinstall cartridge in printer and close lid. Wait until cartridge returns to parking position again.
8. Open lid again, remove cartridge, remove tape.
9. Reinstall cartridge and close lid.
Printer will now recalibrate. Once the process is complete the ink level meter should be reading full again.
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | HP Hewlett Packard Deskjet 5650 InkJet...
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Canon MX300 Office All-In-One Printer Logo
15 people viewed this question
old marine
old marine
