Question about Olympus Cameras
I want to buy an Olympus OM20 manual - Olympus Cameras
    President:
  • 1,187 Answers
Olympus om 30 manual
The OM-30 has focusing system limitations. Most of the time, you can use the LED in the viewfinder to help you focus an image. If the lens you attach has a maximum aperture of F4 or smaller, (F5.6, etc) you set this switch to F4, then focus the lens manually using the prism gridlines visible in the viewfinder.
In short, just set the F4/F2 switch to whichever is the closest to the maximum aperture of the lens you are using. With an F1.8 lens, for example, you would use the F2 setting. For a lens with a maximum aperture of F3.5, you would use the F4 switch setting.
Aug 19, 2014 | Olympus Om Auto Extension Tube 7 For Om-1...
Remove film om20
You are turning the rewind dial on the front of the camera before trying to turn the rewind crank on the top?
Nov 15, 2013 | Cameras
I bought an Olympus TG-610 camera and I would like a paper manuel instead of the cd. Can I buy one and from who and the price.
You can order the printed manual from Olympus on their web site at
http://www.olympusamerica.com/cpg_section/cpg_support_manuals.asp?id=1546
Jun 04, 2011 | Olympus Cameras
Can I buy a manual?
Why to buy, if you can find it in this LINK: Olympus-E-20N-Digital-Camera.
Hope this helps (remember to rate and comment this answer).
Jan 09, 2011 | Olympus Camedia E-20N Digital Camera
Where to buy instruction manual for olympus c 7000 zoom ?
You can download the free manuals from: http://www.olympusamerica.com/cpg_section/cpg_archived_product_details.asp?id=1136&fl=8
You'll require Adobe PDF Reader insatlled on your PC to view the manuals. If it is not already installed on your PC, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. For more help and clarifications, please reply to this post. Thanks
Aug 30, 2009 | Olympus Cameras
How to KNOW the light is right 4 an Olympus OM20 Manual camera?
OM-20 was basically a upgraded OM-10 with the manual adapter built in and a number of other refinements.
The viewfinder has LED's to show the shutter speed recommended by the camera's lightmeter for the ISO and aperture selected. It also has an exposure compensation indicator (the +/- symbol) and an indicator for flash ready which doubles up as a post-exposure flash confirmation. There is also the indicator lamp to show manual mode has been selected. OM-10 lacks the manual mode lamp and the +/- indicator.
Like the OM-10, the OM-20 is primarily an aperture priority automatic camera. In this mode you set the ISO film speed, choose which aperture you wish to use (with the ability to use the lens depth of field preview button) and then the camera selects the correct shutter speed. The +/- exposure compensation control allows the user to tell the camera to modify the recommended shutter speed by up to two stops either way.
In manual mode, there is no manual metering. The light meter behaves exactly as it does in aperture priority mode and the viewfinder shows the recommended shutter speed and not the manually selected one. Correct metering is therefore a case of adjusting the aperture first, and then choosing the correct shutter speed indicated in the viewfinder. If the user then decides to select a different shutter speed, then the aperture ring must be adjusted to maintain the correct exposure. For example the aperture is set to f8 and the camera recommends 1/60th of a second. The user decides that a faster shutter speed is required and chooses 1/250th, but the viewfinder remains showing 1/60th. In order to keep the same exposure value the user must open the aperture by two full stops to f4. The camera's light meter will detect the new aperture setting and providing the light on the object is unchanged the viewfinder shutter speed display should now show 1/250th as well to confirm the correct adjustment. Alternatively, the user can choose the shutter speed first by looking at what has been set on the control ring (or by turning the ring to the end of its travel and then counting the clicks from there as all experienced OM users do) and then turning the aperture ring until the shutter speed shown in the viewfinder matches what's been manually set.
It all sounds clumsy and complex but is done far more quickly than I've taken to type this and becomes second nature.
Aperture priority metering is selected on the camera by choosing AUTO on the mode selecter. In this mode the shutter speed ring has no effect and the viewfinder always displays the automatically selected shutter speed.
May 09, 2009 | Olympus OM-2000 35mm SLR Camera
Which battery charger should I buy
I went to two camera shops with my camera and the manual... they show me what I need and I buy it on e-bay.... much much much less expansive.... thanks anyway
Aug 14, 2008 | Olympus FE-230 Digital Camera
Manual
You can download the PDF format of that manual here: OM20
Feb 11, 2008 | Cameras
Transferring images from Olympus Master Folder
You have to buy the upgrade to Olympus Master 2, to be able to burn images to a disc.  Olympus Master doesn't allow you to.  I get around it by manually saving my images in an additional folder on my computer and then burn them to disc from there.  It's a slow process and very inconvient.  Good luck.
Oct 12, 2007 | Olympus EVOLT E-500 Digital Camera
Cameras Logo
69 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
