Question about LG L1919S LCD Monitor
Monitor trouble I have a westinghouse monitor and we had a wind storm .My server went down for about 5 minutes and when it did my monitor went black,like it was off but it's not. What could the problem be?
  • rodmorf Jul 26, 2008
    Hello, I have the same problem, my monitor does not come on even when i restart my computer seems like it is on sleep mode, is there any combination of keys to reset it, or any one else know another solution to reboot it?
Nope, I have the same problem and the screen says"power saving mode". What should I do anyone? Help!!!
Posted on Oct 23, 2008
I THINK THE MONITOR IS IN STAND BY MODE,PLS RESTART UR PC IT MAY SOLVE UR PROBLAM.
Posted on Dec 23, 2007
Monitor goes blank after being on for 5 to 10 minutes. after some readjustment of the cables it comes back on... this does not always work
If the video cable is detachable from the monitor and the computer, sub another set of video cables. If that fails use a spare monitor to see if you have the same problem, if you do! The Video Graphics Card in the computer is suspect, if the spare monitor is fine it means the Westinghouse Monitor is the issue and is not cost effective for repair.
Jan 07, 2011 | Westinghouse 19" Widescreen Flat Panel LCD...
I have a westinghouse monitor L1916hw and my monitor was fine last night but this morn when I woke up the lighting was flickering and then went black and when I turned it off and back on it will stay lit...
Get in the habbit of turning off LCD monitors when not in use. First, save electric. Second, save your monitor as LCD will burn up faster than a CRT. As for your problem, I would assume it's burning out and/or about to burn out...overheating. I would shut the entire system down, let is sit for 5 minutes and reboot everything. If it still fails to strike properly, it is probably toast.
Jun 29, 2010 | Westinghouse Electric L1916HW 19" Monitor
Westinghouse 22 lcd monitor. faint click and went
More likely the filter caps failed and may have taken out the inverter fuse and the MOSFET in the inverter circuits also. yoo need to open it up and inspect the inside, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Mar 09, 2010 | Westinghouse L2046NV Monitor
LCM-17v8 Monitor Blacks out after a few minutes. Unplug power source and you have display again, for how long is anyones guess. Any suggestions
Does this happen ONLY when connected to YOUR computer,
or does this happen when conected to some other notebook/desktop?
If the former, your computer is entering "power-save" mode,
after a few minutes of inactivity. Just "wake-up" your computer,
and it will wake-up the LCD monitor.
If it is the latter, then you have a "hardware" problem with your LCD monitor. Take it to a qualified technician for trouble-shooting.
Jan 13, 2010 | Westinghouse LCM-19v1 Monitor
Westinghouse lcm 19w4 has to be used in brightest mode or
I had this same problem and going through the on-screen menus I found a reset option. I reset the monitor settings and the scrolling bars went away. I plan to leave it powered up for a while to see if they come back.
Jan 13, 2009 | Westinghouse LCM-19v1 Monitor
Blank Screen
Be sure that the power cable and the video cable are plugged into your monitor, the power cable is plugged into a good outlet, and the video cable is plugged into your computer. It's possible that you simply have a loose cable.
If everything is installed correctly, and if the screen is completely blank (no "cable disconnected" or "test mode" messages), then it sounds like your monitor is simply dead. Since there was a heavy wind storm recently, it was probably hit by a power surge. If you don't already, I recommend that you use a surge protector for all digital equipment.
Nov 12, 2008 | Computers & Internet
Monitor Failure
Your system was not affected because the PSU can prevent power surges. Your monitor's backlight has went out due to surges in electricity to your monitor. Unfortunately, you can not replace the backlight. I would suggest you buy a new monitor. 19" LCD Monitors has have went down dramatically in the past month.
Aug 25, 2007 | X2Gen MG19MY 19" LCD Monitor
LG L1919S LCD Monitor Logo
103 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
