Question about Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water
Water filter replacement?
2005 22ssA wirlpool ed2choxk005 sidebyside with ice maker and water...does this model have a water filer on it - I can't find one? Where is it? If it doesn't then can it have one put on it to filter the water? Thanks.
  • 725 Answers
You do have a filter on the bottom kick plate. It looks like a round cap and it's the same color as your refrigerator. Give us a call and we'll be happy to send the correct filter out to you. Hope this helps and we look forward to hearing from you soon.
Posted on Oct 06, 2009
Kenmore sidebyside no water or ice replaced valve and icemaker still nothing
The first thing I woulb check is the water filter itself. Water comes into the machine via the water valve, and from the valve it goes to the filter and the to its respective area, dispensor or ice maker. It's a very rare case that both the ice maker and water in the door stop working at the same time other than the filter being bad,
May 10, 2012 | Kenmore Side by Side Refrigerator
Where is the filter for the ice maker on whirlpool refer model number ED2CHOXK005
Removing and replacing a water filter - base grill location
Filters situated in the base grill (below the freezer compartment) of Whirlpool-built side-by-side refrigerators are relatively simple to replace. Follow these two steps:
  1. Grasp the filter's end and make a one-quarter turn to the left.
  2. Pull the filter straight out.
To replace with a new filter, repeat these two steps in the opposite order, making sure to first remove the red cap from the filter. Proceed by pushing the filter straight into the slot, and then giving it a one quarter turn to the right.
Note: Replacing this type of filter is quick - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Dec 18, 2010 | Whirlpool 21.8 cu. ft. Side-By-Side...
Replace water inlet valve for ice dispenser with new. When icemaker cycles it dispenses through the water dispenser instead of tube going to ice maker. I have switch lines around but can only get water...
The ice maker is what tells the water control valve to open so it may be correct now and the thermostat in ice maker may be defective. Part 27 or 627985 down below where it says Whirlpool Ice Maker Parts Breakdown and in that photo is the ice maker thermostat. If your ice maker has been used for many years the complete ice maker may be better to replace. Ice maker Model=> 4317943
Or click here=>Point and Click Then enter model or part number into search feature. If you have questions please ask, Thanks, Sea Breeze
Whirlpool Model ED5GTFXKQ02 Ice Maker Parts Breakdown
Dec 17, 2010 | Whirlpool Refrigerators
The water dispenser has stopped working all of a sudden...a little water drips out, but that's it
Make sure water valve was not turned off,
Check water Filter,
Empty Ice container to see if you have problem with ice maker.
if water filer is good & Ice maker are working good
Then there are only two things it could be .... The internal water valve or the line is frozen
Most common is water valve in the refrigerator.
Oct 06, 2010 | Jenn-Air JCD2389G Side by Side...
Cannot find the filter on the whirlpool ED2CHQXKB05. The ice maker is producing ice with a white film on it. I was told to change the filter only I cannot locate a filter.
From what I can see with your model number you do not have a water filter contained within the cabinet. You can install an inline water filer between the source and the refrigerator. Also, you will likely have hard water stains in the ice maker mold itself, FYI.
Oct 01, 2010 | Refrigerators
Model ED2CHOXK005 Whirlpool refrigerator with ice maker the ice maker quit working still puts ouf water but no ice
The problem is most likely your water control valve for the ice maker. There are 2 one for ice maker and the other is for the dispenser. Fill your ice maker with tap water. Let it freeze and if it dumps and does not refill then the water control valve part number 2188542 let me know if you need more help, Sea Breeze
http://servicepartstec.blogspot.com/
Aug 19, 2009 | Whirlpool Refrigerators
ICE MAKER NOT MAKING ICE &WATER DISPENSER NOT DISPENSING WATER. WIRLPOOL ET9FTTXLQ11
Check the water filter cartridge - possibly needs replacement. It should be near the bottom of the unit in the front.
Mar 28, 2009 | Whirlpool ET9FTTXL Top Freezer...
Ice maker
1 may have frozen water line
2 reset ice maker press in ice lever 5 times
3check check ice maker plug
May 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
Whirlpool 21.8 cu. ft. Side-By-Side Refrigerator with PuR Filtered Ice and Water Logo
461 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
