Question about Refrigerators
First freezer stopped freezing. now icebox is not cooling at all and freezer is warmer than inside of icebox
  • 725 Answers
You have a bad defrost system in this unit. Call or emailus with the brand and model number and we;ll get the correct part out to you right away to get you cooling again! We look forward to working with you and hope to hear from you soon.
Posted on Oct 06, 2009
Ge tfx25jrbb-ww refridgerator not cooling
The first thing to check is if you can hear the fan running inside the freezer. This not only keeps the whole freezer cold it alspo circulates air down to the refrigerator keeping it cool as well.
May 28, 2012 | GE Refrigerators
The frezzer is freezing up and the icebox is not cold. the fan in the freezer is turning. model 106 74262400 serial ER 2922094 type 22TFA
Check out these tips...they can help you figure out what is going wrong with your refrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator
Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Mar 10, 2011 | Kenmore Refrigerators
I have the one with frezzer on bottom and french doors fan makes loud noise louder some days then others open doors it stops close them back and it starts again my modle does not have an ice or water...
refrigerator (commonly called a "fridge") is a cooling apparatus. The common household appliance comprises a thermally insulated compartment and a heat pump-chemical or mechanical means-to transfer heat from it to the external environment (i.e., the room in which it is located), cooling the contents to a temperature below ambient. Cooling is a popular food storage technique in developed countries and works by decreasing the reproduction rate of bacteria. The device is thus used to reduce the rate of spoilage of foodstuffs. A refrigerator maintains a temperature a few degrees above the freezing point of water. Optimum temperature range for perishable food storage is 3 to 5 °C (37 to 41 °F).[1] A similar device which maintains a temperature below the freezing point of water is called a "freezer".
The refrigerator is a relatively modern invention among kitchen appliances. It replaced the icebox, which had been a common household appliance for almost a century and a half prior. For this reason, a refrigerator is sometimes referred to as an "icebox
Jan 16, 2011 | Samsung Refrigerators
Freezer not freezing; compressor motor continues to run
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator2_bing.gif Condenser Coil Cleaning Refrigerator2_bing.gif Repair
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
Refrigerator Troubleshooting2_bing.gif Refrigerator Compressor
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
Refrigerator Compressor Start Capacitor and Start Relay
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Jul 11, 2010 | Frigidaire FRT21P6C Stainless Steel Top...
Refrigerator is freezing up and not cooling the icebox
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
How to Defrost Refrigerator Defrost Timer Problem
heatman101
yte
Apr 11, 2010 | Kenmore 72102 / 72104
Fridge stopped cooling and freezing and making ice all of a sudde
is the unit free standing ? if so have you defrosted it using hot water.please dont.need more info ............
Feb 06, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Cooling sometimes, freezer leaking water when it stops freezing
It is probably the defrost thermostat located on upper condenser coil to the left of the fan in the freezer compartment. If not, it could be the defrost timer located near the thermostat in the refrigerator under the plastic dome where the light is. If the defost thermostat or defrost timer is not cycling the defroster heater element on and off correctly... an ice dam forms clogging the drain tube which freezes and blocks water (from the the defroster) to draining down and into the evaporator pan located on top of the compressor in the rear of the unit near the floor.
Mar 31, 2009 | KitchenAid Refrigerators
Refrigerator not cooling sufficiently/ Freezer not freezing
Yes, if defrost board is bad it will cause problems. Need to listen for fan inside the freezer compartment also. If freezer does not defrost cold air will not circulate properly causing warmer temperatures inside refrigerator. Is model number SXD524VW ?
Let me know, Thanks, Sea Breeze
Mar 26, 2009 | Amana SXD524VW Side by Side Refrigerator
Freezer/Refrigerator tempurature swinging wildly
The compressor is overheating and not starting. Could be just the start relay. If this happens again try unplugging it for about an hour then it should work for a while. Heat between doors is normal this is an electric heater designed to keep the doors from sweating. You just noticed it because the refrigerator wasn't cold.
Jun 26, 2008 | Freezers
Refrigerators Logo
50 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
