Question about Broan-NuTone VX475 Bagged Central System Vacuum
Vaccum runs for 2 or 3 minutes then shuts off. Can not restart it for several hours. We have tried EVERYTHING with no luck. I see there is the same problem with the VX550...is there a recall on this one too?
    Scholar:
  • 95 Answers
The VX series NuTone's have had some problems but NuTone is taking care of them as long as it is under warranty. You can contact NuTone at 1-888-336-6151 or whoever you purchased the unit from and you will most likely get a new unit. There are no parts available for the VX units so whenever there is a problem NuTone has been sending new units out.
Posted on Oct 08, 2009
Testimonial: "Thanks but I guess I forgot to mention we can not find the receipt anywhere and we live in Alberta Canada. "
  • Faith Oct 08, 2009
    I am not sure about Canada but even without the receipt they will probably work with you. These units have been a hug problem and they are trying to take care of their customers.
  • HRMHalifax Oct 30, 2010
    It took us 4 emails and finally an 8 page fax to them (Broan Nutone) before they would even respond to us. Now they are asking for the receipt, which we of course can not find, and Home Depot only keeps records for 18 months. If they knew this product was faulty they shoudl have issued a recall. Not impressed.
S7000 Just shuts off...
It's shutting down due to overheating to protect the motor ( and to prevent a fire! ). Running it and feeling around the motor to see if it's gotten hot would be the first thing I'd check. If the vacuum is new and giving you these problems, I'd return it to the store you bought it from and see what they'll do about it..there may have been a recall you aren't aware of.
Jan 13, 2014 | Miele S7210 Bagged Upright Vacuum
Oreck vaccum cleaner runs about 4 or 5 minutes then shuts down.
this means you have a blockage somewhere on the vac
Feb 17, 2013 | Oreck Vacuums
Nutone Model CV353; runs for several minutes and then shuts off. After a couple of hours I can turn on again, but again only last a couple of minutes. Possible relay problem?
Check the filter. If it's dirty, thoroughly rinse it in cool water, then let it thoroughly dry before using. If you don't have an extra filter to use during this time, you should get one.
It could also be a clogged hose or pipe. These would cause the motor to overheat, thus shutting off. Check hose at end for suction. If weak or nonexistent, detach hose and try dropping a penny or dime, or marble, down the hose. If it comes out the end, the hose is probably clear. If this is the case, you need to check other outlets.
Dec 12, 2010 | Broan-NuTone CV353 Central Vacuum
I bought it in may , I can honestly say , it is THE worst vaccum
There are several filters on bag-less vacuums that need to be cleaned. Dig out your owners manual or open the one below. See section 3 for filters and maintenance. If you are vacuuming a house bigger than about 1500 square feet, you should be cleaning the filters every other use. Personally, after using a bagless for a couple of months, I went back to my bagged vacuum.
http://www.hoover.com/pdfs/manuals/U6630900.pdf
Dec 20, 2009 | Hoover U6630-900 WindTunnel Bagless...
Dyson vaccum runs for a few minutes then the power shuts off, I have heard there is a second filter, any ideas?
its over heating due to insufficient air passing through the motor and a heat sensor is cutting out the power due to a blockage maybe a filter or a cloged hose ,
Oct 28, 2009 | Vacuums
Dyson shuts off in 5 minutes, then starts up 2-3 minutes laters w
I think there's a good chance of a clog that you haven't found. On the Dyson it's fairly easy to remove several covers that give you access. From the collection canister is a tube that runs toward the base. At the bottom of the tube you can remove a cover where you can check for a clog. Thats basically on the right side of the machine. From the rear side, very low and toward the middle right is a tab that you can push in and remove the tube that goes up into the flexible hose. Thats another good place for a clog to hide.
Jun 10, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Eureka Vaccum Tripping Breaker While in Use
ur overloading the circuit in the house try turning off everything that is on that surcuit i mean everything then see if the vac works
Apr 04, 2009 | Eureka 4700A Maxima Bagless Upright Vacuum
Hi, vacuum clogged and motor shut down, how do I restart. thx
I'm assumeing you have remove the clog so unplug the machine an let it set of about an hour then plug it in and before you turn it on get it ready to vaccum then turn it on the overload switch should reset and it should run
Jan 15, 2009 | Dyson DC07 Animal Bagless Upright Cyclonic...
Nutone central vac vx550
It's a known problem. I bought my vx550 last year in July and it stopped working this year in May. On for 5 minutes, shut down, can't run for a few hours, runs for another five minutes, etc. I called the Nutone customer service department and they exchanged the unit for a new one, cross shipped, via UPS. Mine was still under warranty though. It has to do with some defective thermostat or controller in the electronics of the vacuum.
Good luck
Sep 11, 2008 | Broan-NuTone VX475 Bagged Central System...
Hover mach 4 vaccum
usually caused from being plugged, so first find the plug and clear it. The motor has an automatic reset, should restart after about 30 minutes, if it continues to shut off, there is still a plug.
Dec 12, 2007 | Hoover U6437-900 / U6439-900 Windtunnel...
Broan-NuTone  VX475 Bagged Central System Vacuum Logo
974 people viewed this question
Top Broan-NuTone Vacuums Experts
Steve
Gerry Harvey
Gerry Harvey
JoeVacs
Are you a Broan-NuTone Vacuum Expert? Answer questions, earn points and help others
