Have severe clicking problem in audio, poor picture quality,lots of vidieo static at top of screen, and have changed sat. provider with zero change with these problems. Mod. #40rv525r--purchased new in box 4/07/09 installed 4/28/09. Purchased from buydig.com on 4/07/09. Have all receipts, etc. We have, currently, 4 Toshiba units and only one giving us problems. Any advice for our difficulty?
    President:
  • 1,462 Answers
Most of the time the convergence ICs are bad and some low ohm resistors and or low amp fuses with some cold solder connections would have gone bad..
Try checking the convergence IC anf try touching all the points with the solder rod..Think this should solve your problem...
Please leave me comment if it doesnt work,will help to solve your issue
RNJ VINODKUMAR
Posted on Oct 06, 2009
TX-NR818 picture no sound. had sound before. Sound would fade when changing channels
Howdy BWADE,
Evidently...
A really well known issue with apparently very poor grade Onkyo
CAPACITORS... (don't know if Onkyo has stepped up to it yet).
There are a lot of suggestions... games, seances... (etc.)
on the web... (contemporary wisdom) but the real solutions are:
  1. contact the manufacturer to fix
  2. eat the cost yourself (w/quality capacitors)
There seems to be an entire sphere of influence REPLACING these (gum-wrapper) caps... growing industry.
I WOULD NOT recommend doing it yourself... unless you rigorously, take pictures and notes... know or learn about heat-sync soldering... and study UP COMPLETELY ANTI-STATIC circuit handling procedures (ESD hazards).
Less than meticulous handling of any/all electronics can easily turn an inexpensive small issue into a catastrophic ($$$$) pile of useless rubble...
and... buying a general purpose "KIT" is much more expensive and wasteful than productive.. not likely to provide QUALITY results (shop Jimmy, noted below has a great "KIT" reputation)..
You might want to have a look at getting your equipment PROFESSIONALLY refurbished...
TV Parts Universal TV Stands DLP Chips ShopJimmy
Feb 08, 2016 | Onkyo Audio Players & Recorders
I have direct satalite tv VR 6050 kenwood surround sound tuner vizio tv, dvd player, and a vcr, Im confused on how its hook up and what order should it go something like sat in to sat box to kewood...
that reciever is not going to carry a hi definition video signal, it doesnt have either hdmi or component video inputs.
you can still use it, but if you run the picture through the reciever, it will have poor quality.
heres how you are supposed to hook it up:
find the single,m yellow video jack on your sattelite box, and hook that up to the "tv" video input, then hook the laft and right audio outputs from the cable box into the "tv" audio left and right inputs on the receiver. hook up the dvd player and vcr in the same manner, using "dvd" and "VCR" (if labeled as such) inputs on the reciever.
finally, send the tv video and audio outputs to the composite video in and left/right audio inputs on the tv. the video will be running through the reciever, and when you use the reciever to switch the sound source, the video will also be changed. you could get better picture quality if you ran the video directly to the tv using component (seperate green, red and blue) outputs/inputs, and bypassing the reciever on the video end, but then you would have to change inputs on the tv AND reciever to change from your cable box to your dvd player.
Nov 25, 2010 | Kenwood VR-6050 Receiver
Sony xbr lcd screen going all green on occasion
This is an HDMI compatibility problem. Your cable/SAT box is not playing very nicely with the TV. You can try replacing the cable/SAT box with a different model # or switch your connection type from HDMI to Component (5 wire connection). I hope this was helpful, best wishes.
Apr 17, 2010 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
My emachines m6811 screen shows a poor quality
Sounds like the pc is set to a low pixel setting, try going to properties and adjust display settings.
ie. Right click on desktop image, click on Properties. WIndow will pop up, click on SETTINGS tab and adjust Screen Resolutions and/or Color Quality. That should make the change. Sometimes programs installed changes those settings. Good Luck!
Jul 15, 2009 | E-Machines M6811 Notebook
Poor picture quality on Toshiba Regza 32AV555DB LCD TV
i had the same problem! i just changed my scart leads to some quality gold ones, this made the picture a lot crisper . hope this helps :0)
Dec 14, 2008 | Toshiba REGZA 32WLG66 32 in. Television
Poor print quality
See my previous post about intensive head cleaning as I think this would help get your printer running again:
http://www.fixya.com/support/t138226-printer_not_printing
Jun 29, 2008 | Lexmark X1290 All-In-One InkJet Printer
Poor picture quality and sound problems on Lite-on LVW 5115GHC
have you tryed replaceing scart leads plus check if there in a priority order 2 like going form dvd 2 tv then tv 2 sat recever try going via sat recever then dvd then you tv if that dose not seem 2 solve you problen it might seen you might have dry solder point inside you dvd unit if so take bk where you buy it from and explane to then wat is happening hope helped
Aug 05, 2007 | Lite On LVW-5115GHC+ DVD Recorder
No picture
If the screen is completely black, do you feel static from the screen? If not then you probably lost your High voltage to light up the screen. If you do feel static, and in a darkened room can see a gray screen, then you have lost your video signal internally, and it could be anything from a video IC to the microcontroller chip which would be an expensive repair. Since you see some pixels in the middle of the screen when the TV is off, I'll assume the High voltage is good, and besides the video circuits, it's possible that if you had a defect in the vertical sweep circuits, it might kill the video as well. May want to get an estimate or if it's over 8 years old, replace it.
Dec 19, 2006 | Panasonic PV-DF2704 27 in. TV/VCR/DVD...
Alternating audio quality
Hardware issue - must be replaced
Oct 20, 2006 | SanDisk Sansa m230 MP3 Player
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
