Question about RCA F38310 38" TV
How do i know wether the thermistor is shorted / open, defective?
I have problem with my tv ( brand is sony ).,its a dead set..the fuse keeps on blowing when i put it..i juz want to know y,even if i replacing with the same ampere rating..the problem is all about in the power supply section..im focusing in the power supply section..i suspected thermistor as the causes of the problem..now i juz want to know if the device defective ---> (thermistor)..can i used ohmmeter to test wether if it is shorted or open? how do i know if it is open/shoted ,defective? it has three therminal on it..im so much confused on how to deal with it.email me pls. pio_042@yahoo.com..thank you so much in advance
  • 883 Answers
If this device "it has three terminals on it", I believe this part is not a thermistor, rather a power resistor (2 inside part)...does the part show a small diagram with resistor symbols (jagged lines) printed on it? Does it have a part number? Also attempt to measure the current at the fuse...first determine if it is AC or DC and if the projected value may blow the ammeter's fuse, then attach the leads of an ammeter at the fuse points (watch polarity if DC!) and set to highest range and progress to where lowest possible range can be used to get a decent measurement. Does it come close to the fuse rating or far above it?
Posted on Dec 23, 2007
    Genius:
  • 1,139 Answers
Hello clydex, Yes you can use an ohmmeter, however you will need a hot air gun to. Let me explain: There are two types of Thermistors +Temperature coefficient and - Temperature coefficient. The +temperature thermistor reacts this way: as the temperature goes up so does the resistance of the device this is used when dealing with degaussing coils as the current passes through the coil it heats up the thermistor until the thermistor cuts off the current needed to run the coil. The -temperature thermistor reacts this way: as the temperature goes up the resistance decreases, this can be seen when dealing with circuits that are designed to short out when excessive current is present. The excessive current causes the thermistor to heat up and the the resistance drops causing the device to short out. Here is how to do it.: connect the device to the ohmmeter and use the heat gun to heat the component up the value of resistance should rise or decrease.
I hope this helps,
Thank you, Shuttle83
Ricoh aficio 1045 - SC541
Fusing thermostat/thermistor open
Symptom: The fusing temperature detected by the
thermistor is below 10°C for 5 seconds
after the main power switch is turned
on.
Possible Cause:
• Fusing thermostat defective or out of
position
• Fusing thermistor defective or out of
position
• Power supply board defective
May 25, 2011 | Ricoh Aficio 1035 Copier
Samsung LN40A530P1F LCD TV keeps blowing main power fuse when i turn set on it blows right away i have replaced fuse many times. Also when back was off i noticed a arcing as fuse blows at a component just...
http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP01&prd_ia_cd=&prd_mdl_cd=&prd_mdl_name=LN40A530P1F
If a fuse blows like that there is a major problem, inside. I suspect that what your are seeing is the inrush thermistor, and they exhibit this under great load. I would explect that this fault maybe in the actual PSU. Due to the lack of service manual support, i would get a quote for repair from an authorised service center.
Jun 22, 2010 | Samsung LN40A530 40 in. LCD TV
Main power button and remote will not turn on tv. It is plugged in and has 110. Worked last night but would not come on today.
The most common failure for these sets to go totally dead is the degaussing thermistor shorts out thus causing the A.C. fuse to open. The part number for the thermistor is D4DDF1R50001 and the fuse is part number XBA2A00101F... You can do a Google search for these parts. One you get the parts and look at the board where the A.C. cord connects to, the fuse and thermistor are not too far from that point. Its an easy fix if you have any soldering skills. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Panasonic CT-32HXC14 32" TV
E-5 error code
E5 code refer to fuser unit.To dfisplay both digits press the Enter.
E 52 Fusing error 1 Defective thermistor,heater lamp open,defective main or ac/dc drive board.
E 53 Fusing error 2 thermistor in shortcircuit,fusing harness shorted or ac/dc power supply board defective.
E 54 fusing error 3 main board or ac/dc board defective.
E 55 Fusing error 4 rhermistor open,defective main board or fusing lamp open.
When E5 service call condition occur for safety reasons they cannot be cleared by turn OFF/ON the power switch.After repairing the copier turn ON the main switch.Enter in the SP mode and press 97.Turn the main switch OFF wait 10 sec and turn ON.
Oct 07, 2009 | Ricoh FT5832 Copier
Infotec 5221 displays a E-5 symbol
E-codes (E1-E7)are displayed im the copy counter.To display both digits of the E code press the Enter key.When service call E5 conditions occur,they cannot be cleared by turning OFF/ON the main switch for safety reasons.Ehe following procedure must be performed to clear these service call condition:
Turn ON the main switch.
Turn DIP switch 101-1 ON and OFF.
Turn the main switch OFF and ON.
Code E 52 Fusing lamp warm up error.Causes:thermistor open,fusing lamp open,therofuse open,power supply/ac drive board defective.
Code 53 Fusing lamp overheat.Causes:thermistor short,power supply defective,main board defective.
Code 55 Fusing thermistor open.Causes:thermistor open,main board defective,power supply/ac drive board defective.
Aug 14, 2009 | Ricoh Office Equipment & Supplies
Blows fuse
You may want to check the regulator IC. RCA had a lot of shorted regs
Nov 07, 2008 | Televison & Video
SC542
thanks for the info. care to try again?
Sep 23, 2008 | Ricoh Office Equipment & Supplies
Hello clydex,
I hope this helps,
Thank you,
Shuttle83
Dec 23, 2007 | Televison & Video
Blows fuse
If you disconnect the degaussing coil and the set plays fine, it means one of 2 things is wrong. The degaussing thermistor could be shorted internally. I have seen this happen a few times on those degaussing thermistors that are in the little black boxes with 3 legs. Those boxes actually have 2 thermistors in them, one to do the actual degaussing and another connected directly across the AC to act as a heater for the degaussing thermistor. One of those thermistors could have "flashed over", which would blow the fuse the instant the set it turned on. The only other thing would be the wrong size main fuse. Without a degaussing coil the set probably draws about one amp, but the surge at turn-on with a degaussing coil could be as high as 4 amps. If you have the correct fuse installed and it blows at turn-on, replace the degaussing thermistor.
Aug 14, 2007 | Emerson EWC20D4 Combo
RCA F38310 38" TV Logo
99 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
