Question about HP Office Equipment & Supplies
It says out of paper while full of paper and will not print.
  • 68 Answers
Pull out paper tray and look inside.The paper sensor could be out of bracket or broken.You should see the the lever that can me moved up by finger if the sensor is in place.When you insert the paper tray into the printer,the paper stock pushes the sensor lever up.This is how most printers detect paper in the tray.
Posted on Oct 06, 2009
Dell 3100cn printer prints individual colors fine. When printing full color picture the paper wraps around the fuser. Tried new fuser - same problem. Any suggestions?
Good old fuser wrap, what a pain. What type of paper are you printing on. Often with full page coverage printing I find that you need to user a heavier bond color printing paper to achieve any sort of good quality and reliability in feeding.
Mar 18, 2011 | Dell 3100cn Laser Printer
The paper light is flashing. The tray has paper, there is no paper jam. I check everything, put tray back in, press go and after a few seconds, there is a click noise and it starts flashing. What do I do?
The light flashing may mean more things, not just a paper jam. Could mean any of the following:
- Front cover is open: Close the front cover of the printer.
- Back cover is open: Close the back cover of the printer.
- Paper jam: Clear the paper jam. To see paper jams and how to clear them, click here. If the printer does not start printing, press the Go button.
- No paper fed manual feed slot: Put the paper back in the manual feed slot.
- Memory full: The printer memory is full and the printer cannot print full pages of a document. To solve this problem, click here.
- Print overrun: A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, go here.
- Drum Error: The corona wire needs to be cleaned. To see how to clean the corona wire, click here.
Thank you for using Fixya!
Dec 02, 2010 | Brother HL-2040 Laser Printer
Paper light is on, won't print, but it is full of
I have an HL-1440. The problem was an empty toner cartridge. Got a new one and it prints like a champ again. Good luck.
Aug 05, 2009 | Brother HL-2040 Laser Printer
My Brother HL-2040 paper led light won't stop flashing, the paper's not jammed or anything, I just put in a new toner, too. I tried doing what someone else said about opening the cover and holding Go until...
Hi. The reasons listed in the manual that cause the LED to flash normally are:
Front cover is open
Back cover is open
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 6-5.
Put the paper in the manual feed slot. See Printing on plain paper, bond paper
or transparencies from the manual feed slot on page 1-10 or Printing on thick
paper, labels and envelopes from the manual feed slot on page 1-13.
Memory full
document. See Solving print problems on page 6-15.
Print overrun
Drum Error
The corona wire needs to be cleaned. See Cleaning the corona wire on page 5-14.
If you check out page 6-5 it tells how to clear the paper jam from the rear of the machine! A point often missed.
Check out the website below if you don’t have a copy of the instruction manual =
http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002089/US_Eur.pdf
If all else fails, try a reset of the printer Drum & Page counter:
  1. With printer tuned on.
  2. Press and hold the “internal button” behind front cover, until all LEDs illuminate.
  3. Make sure Drum light is off, then release and close front cover.
Hope some of this helps………..Please post a response back here and let us all know if it works?............Regards, Cornwellnet (UK)
Jul 12, 2009 | Brother HL-2040 Laser Printer
Error light keeps on flashing blue light at the
These are your possibilities based on your error.
Front cover is open
Fuser cover is open
Close the fuser cover located behind the back cover of the printer.
Paper jam
Clear the paper jam. See Paper jams and how to clear them on page 85. If the printer
Memory full
The printer memory is full and the printer cannot print full pages of a document. See
Solving print problems on page 97.
Print overrun
A print overrun occurred and the printer cannot print full pages of a document. See
Jun 14, 2009 | Brother HL-2170W Laser Printer
When i turn my printer on the light flashes green once and then orange 5 times. cannot get past this stage - any ideas?
Here are all the flashing explanations:
Two flashes: Out of paper or paper feed error
Reload the paper correctly and press the RESUME/CANCEL button.
Three flashes: Paper jam
If paper has jammed in the printer, clear the jam, reload the paper in the printer correctly and press the RESUME/CANCEL button.
See Paper Jams
Four flashes: Empty ink tank
If you press the RESUME/CANCEL button, it will continue printing with an empty ink tank. After printing is finished, replace the ink tank immediately. If you continue printing with an empty ink tank, it may cause damage to your printer.
Refer to your Quick Start Guide for instructions on how to replace an ink tank.
Five flashes: No print head installed/Defective print head
Install the print head. Also, ensure that the protective tape has been removed.
If reinstalling the print head does not solve the problem, replace it with a new one. Contact the Customer Care Center.
Eight flashes: Waste ink tank almost full
The printer has a built-in waste ink tank for the ink used during print head cleaning. Eight flashes indicates that the waste ink tank is nearly full. Press the RESUME/CANCEL button to cancel the error so you can continue printing. Before the waste ink tank becomes completely full, contact the Customer Care Center.
Mar 08, 2009 | Canon BubbleJet i560 InkJet Printer
Paper tray is full and the paper light keeps flashing.
First check the machine for paper jams. If not, remove the paper from the paper tray and reinstall it. Then try to print from the MP tray.If this works, check paper size settings on the printer driver, or the small black arm which hangs down next to the paper pick up roller, and is the paper sensor.
Feb 09, 2009 | Brother HL 5040 Laser Printer
Printer says printing but no print out.
all my cartridges are full/newly changed. my epson stylus cx5200 keeps on feeding papers, displaying printing message but with no actual print out i.e. blank paper comes out. please help. thanks!!
Darren.
darren.lee54@yahoo.co.uk
Oct 06, 2008 | Epson Stylus CX5200 All-In-One InkJet...
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
Paper LED Blinking
Did you see http://www.fixya.com/support/r310860-lights_indicate
The Paper LED is flashing.
papereroor2.gif Meaning of LED Indication
Back cover is open:
Paper jam:
Memory full:
Print overrun:
A print overrun occurred and the printer cannot print full pages of a document. To solve this problem, click here.
Clean drum unit:
Jan 04, 2008 | Brother HL-2040 Laser Printer
91 people viewed this question
Seeker5211
Seeker5211
