Question about Toshiba 46HM95 46" HDTV
Popping Sound speakers on the TV make a popping sound if I raise the volume.
    Sergeant:
    Champion:
  • 346 Answers
Speakers may be going bad
Posted on Dec 27, 2007
I get a popping sound on my tv when I change Chanel's
Check all of your audio and video connections to make sure they are seated(connected properly). After doing so,if you still have the popping sound try lowering the volume and see if the popping noise lessens or gets worse.If the noise goes away then you may have a problem with the speakers,either in the tv or in an external sound system if one is connected.
Feb 19, 2015 | Samsung "UN46D6000 46"" LED ""SMART"" TV "
My T.V. is making a weird clicking/popping/thumping sound and it sounds like it's coming from the speakers. It will do it for a few seconds stop and then do it again. It pauses the audio when it does...
Tries tv and cables or satalites services boxes unplug,replug it back like about an hour later for tv to do a whole tv set resetting itself back to factory setting and those services boxes rebooting and updating it software.Recheck all tv wires connections and sevices boxes for input cables wires for lose cables wire connections and damages connections cables wires.These steps should help,for stopping the volume just suddenly raise up and out of control for no apperance reasons.
May 28, 2011 | Mitsubishi WD-57732 Projection Television
I have a powered sub for my surround sound and every now and then its starts crackling and popping. i can make it stop by playing with the volume knob or even tapping it sometimes. my old sub did the same...
Does the crackling and popping sound comes only from the sub, or from the other speakers too? Try switching of to check. I think that it is problem on volume control potentiometer. In that case all the speakers must sound crackling and popping. If the problem is only in the sub you have to check its connections.
Stelios.
Feb 20, 2010 | Audio Players & Recorders
Popping noise from speakers
You have a problem indeed. try lowering the tv volume . if the signal is too high on tv it can cause some problem with the sound system if that dosent work then you may have some electronic sound output resistor problem.
Aug 15, 2009 | Teac DC-D6300 CD Shelf System
Popping Audio
You may have blown the speaker and need to replace it. Try at a low volume and then at high to notice any difference, if the popping occurs only at higher volume then it needs replacing. I hope this helps
May 27, 2009 | Logitech Z-5500 Computer Speakers
Cracking popping type sound coming from front and center speaker
if u are trying to connect the audio of ur tv as input to flow out from the home theater; this is a common thing; u need to replace the audio cable that connects the tv to 3565 with a good quality cable
Apr 01, 2009 | Philips HTS-3565 Theater System
Mitsubishi tv volume on tv not working
If the TV has stereo sound, there may be a speaker switch for internal/external speakers on the rear of the TV that may have gotten bumped by something. (kids, pets, something fell behind?) If no switch, the sound driver chip or speaker may be failed. If the speaker is the culprit, headphones would still work if there is a jack for headphones. Might be a good time to consider a new HDTV
Dec 22, 2008 | E-Machines eMachines Desktop PC
Sharp Aquos LC-26D4U sound problem
You want me to tell you how I fixed it for free, but you don't want to help me for free. What's with that?
Aug 01, 2008 | Televison & Video
Popping & cracking noises
Is the popping noise coming from the speakers? If it is, lowering the volume to zero does not stop the popping from the speakers, then you have an audio output failure. If the sound is not from the speakers, you probably have a high voltage leak. If this is the case, are you in a moist environment or using the set near a window??
Mar 01, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Popping noise
If the popping sound is NOT coming through the speakers, you probably have high voltage arcing. Probably close to the high voltage (flyback) transformer. If this is the case then other parts could be damaged if allowed to continue. If the popping is coming through the speakers then you could have a problem any where in the signal circuits. Like a loose connection. You'd need to have it checked out to find the problem.
Feb 27, 2007 | Sanyo AVM-3680G 36" TV
Toshiba 46HM95 46" HDTV Logo
23 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
