Question about Rado Jubile Sintra R13432732 Watch for Men
My second hand is not operating in single seconds - it jumps about 5 seconds at a time
The movement on the second hand is jumping every 5 seconds instead of every second, however the time is still correct.
Many high end quartz watches have a feature called the EOL or end of life indicator. This causes the seconds hand to jump 2, 3 or 5 seconds depending on the make of watch when the battery life is low. The watch will continue to keep accurate time until the battery dies completely. So, when you see your seconds hand jumping multiple seconds it is time to get a battery.
Oct 13, 2010 | Omega Seamaster 2561.80 Wrist Watch
The second hand jumps forward every 5 seconds but the watch still keeps time OK.
You need to replace battery.
Q/A from swiss army website.
Q. How do I know when the battery needs changing?
A. In select models, the battery end-of-life indicator signals that the battery should be replaced within two or three days. When the battery is low, the second hand stands still for 2-4 seconds, and then speeds up to the correct time. This indication will last for approximately one week, and then the timepiece hands stand still.
Jul 02, 2010 | Swiss Army Wenger Victorinox Swiss Army...
My Wittnauer is jumping every 5 seconds
Your watch is fitted with EOL feature and let you know about insufficient battery power by moving seconds hand by 2-5-second increments. You have about two weeks time to change the battery from the EOL engagement or your watch will start to malfunction or even stop. In this case you will have to reset your watch after battery replacement. EOL = End Of Life (relates to battery only). Jumping seconds hand means it's time to change battery.
Rate me, plz.
Jan 04, 2010 | Wittnauer Laureate 12R12 Wrist Watch
Second hand not sweeping but jumps at 5 secs intervals. Appears to be keeping accurate time.
When the second hand moves in short jumps rather than a smooth sweep or a second-by-second hop, it means that the battery is about to run out. Usually, with a week or two the watch will stop working altogether. You should go and have it changed as soon as possible.
Aug 02, 2009 | Tag Heuer WAF2110.BA0806 Aquaracer...
Second hand skips
This is warning: it's time to change the battery. Your watch is fitted with EOL (end of life) feature and this is how the low battery power is displayed. However, the watch will keep running correctly for about two weeks.
Rate me, please.
Jul 30, 2009 | Tag Heuer Watches
Second hand doesn't move for each second
Your TAG is fitted with EOL (end of life) feature. This is the cause of that 4 seconds interval movement of seconds hand and thus indicating the time for battery replacement. The timekeeping is not affected by this- it is just warning to replace battery a.s.a.p.
Find your nearest watchmaker and ask for battery replacement.
Do not forget to rate, please.
Mar 20, 2009 | Tag Heuer 2000 Classic WK1311 wristwatch
Navy Seal Luminox watch second hand problem
It is a feature of this watch, it is referred to as the end of life (EOL) feature, it is a way of letting you know its time to change the battery before it dies to the point where it cannot keep time anymore
Oct 24, 2008 | Navy Seal Luminox Dive Watch
Longines watch problem
Some longines watch has built-in battery gauge. When battery is low, the second hand jumps every four seconds. If you have new battery installed and the problem persists then there is a short circuit somewhere that drinks a lot of battery juice.
Mar 11, 2008 | Longines Watches
Rado Jubile Sintra R13432732 Watch for Men Logo
Top Rado Watches Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Rado Watch Expert? Answer questions, earn points and help others
