Question about Poulan Pro Chain Saw 46cc 20"
Rewind pully spring - Poulan Pro Chain Saw 46cc 20"
    President:
  • 2,220 Answers
Recoil Spring Rewind
I invert and secure the housing and rewind the spring large coil to small (need eye protection, both hands and no women around work area!). I'm right handed so I tension the spring enough to insert it inside the previous coil while holding what has already been installed with my left about 180° from my right hand. The tension will hold the spring in the housing once completely inserted. Then bend slightly the inner most part to engage the starter spool. It will require about 2 turns of pretension for it to retract properly.
If you're lucky you can pull the cord out enough for a pretension then slightly raise and add the withdrawn cord to the spool. HTH
Lou
Posted on Oct 06, 2009
2000 Sportsman 500. How do I reinstall spring on rewind start cord?
An easy way to fix a pull start recoil spring . - YouTube
? 8:48
https://www.youtube.com/watch?v=d4r8wbejHXY
Feb 19, 2013 - Uploaded by chaseme81871
Thank you so much! I was able to find the pull cord at a local home depot store and when when my husband ...
How to rewind a pullstart spring - YouTube
? 5:05
https://www.youtube.com/watch?v=qTcL3_3leTk
Mar 13, 2010 - Uploaded by lenniepincher
If you ever need to rewind a un coiled pullstart spring. ... ( NEW VERSION ) How to Rewind and Replace Recoil Starter Spring - Duration: 3:53.
Nov 24, 2015 | Polaris ATV
How do i rewind the recoil spring on my craftsman lawn mower?
Normally these small engines use a clock spring to retract the rope.
Remove the cover on the top and you should find the spring either broken or the tab where the spring end has broken off or jumped out of the mount.
You will need to pre-load the spring with enough tension to retract the rope.
Remove the pull handle from the rope, load the spring and then wrap the rope around the pully holding the pully and spring in the loaded position. place the end of the rope through the hole and tie up the handle. The rope should pull and retract without being installed on the engine.
Best explained here...
https://www.youtube.com/watch?v=tmo6oYOJJ4U
Jun 27, 2014 | Mtd 22" Yard Machine Push Mower
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
Recoil starter repair
It sounds like the spring has come loose or broken. Remove head and see if you can twist by hand. If it feels like it's tightening then spring is ok. Let it go then remove cord with knife and turn winder back until tight. Feed string pully through and knot the end.Release inside of pully and it should work.If this dont work it will need a new spring.
Jun 25, 2013 | Cub Cadet Garden
How to rewind the pull start spring on my murray push mower
you have to do with the sring through the pull start hole wind it clock wise it will attach to the pully and wind it up if you have a spring cartige you have to wind by hand and put it in the catrige wind in the direction of spring
Jun 13, 2012 | Briggs & Stratton Garden
How do you put the rewind back together? Is it better to purchase a new unit?
well its not an easy job but it can be done,,,,first you need to put the pully on the spring and wind the spring up tight so it will rewind the starter rope when pulled,,,then tiy the starter rope into the pully,,,easy if you have done it before?
Aug 28, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Replace pull cord
i roadworks63. Pull off the right side cover to expose the recoil, remove the rest of the rope. Now rewindthe pully c.c.wise until it stops then release it just enoughto align the rope holes,use a C clamp to hold the pully from unwinding. Insert the rope enough to tie a knotHeat the knot to make it hard,now slowly let the pully re..turn or unwind tieon the handle. You are home free.
May 17, 2010 | Stihl Concrete Cutoff Saw Rewind Recoil...
Petrol Lawn Mower starter cord and spring problem
remove the shroud Ithe cover over the flywheel) and remove the old rope. now rewind the spring in the opposite direction of the string hole until the spring is tight. Then clamp it down so i won't unwind and reinstall a new rope (the same size) into the notch in the pully and tye a knot. then release the clamp and let the cord wind onto the pully(make sure the cord gose through the hole in the shroud. then replace the handle and reinstall the shroud back onto the engine..Good Luck
Apr 04, 2010 | Garden
How to replace pull string on honda 5hp pressure washer?
you will need to remove the flywheel shroud and turn it over so you can see the pully, remove the old rope then wind the pully against the spring tension until it stops, then clamp it with a c-clamp then take the new rope and feed it through the pully into the knot hole and tie a knot on the end release the clamp and let the rope rewind into the pully(slowly) until it can't fit anymore then pull a little bit back out then cut it off there and reinstall the handle then tie a knot on this end and reassemble the shroud back onto the engine...good luck
ps this also works on any small engines)
Apr 03, 2010 | Karcher 2500 PSI Pressure Washer
Weed Eater PE550 - How do you change the spring that operates the cord pull. Cord not rewinding. Spring broken
Lay the unit on it's side, carborater down. Removed the 3 screws holding hold the gear assembly housing. Hold the clutch assembly inside a cloth with a wrench and remove the nut. Left from the starter cup as a stack and set aside. There is a starter retaining ring on the shaft. Pull this with a long nose plyers. If it spings free, it is easy to loose. Then left out the starter pully. The starter spring is under the pully. Remove it with a sharp pointed tool. A broken one is crusted in rust and will be snapped off inside the coil.
Jul 31, 2009 | Poulan Garden
Poulan Pro Chain Saw 46cc 20" Logo
186 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
