Question about Car Audio & Video
One day it just went to protect and wont come off no matter what i do.
  • 655 Answers
Hello sobe54,
Disconnect everything except ground, power, and remote.
If the amp still goes into protect mode when powered on, the amp itself is defective.
Hope this helps.
Posted on Oct 06, 2009
98.3hombre battery went dead after a jump it wont start
double posted, why?
JUMPS OK
AFTER JUMP WORKS AND DRIVING, AND STOP AND KEY OFF
IT WILL NOT CRANK.
did i guess right?
that means ,
check all fuses first. even the alt fuse (large)
1-battery bad? #1 top failure all cars.
2-Charge system bad. (is the charge/ batt warn lamp glowing when running car, bingo.????
3-or phantom drains. (if no crank just after stall then it not this) if drains while sleeping yes.
the tests are easy, a dirt cheap voltmeter
13.3v to 15v running is good charge system.
if 12v and falling not.
if the battery is bad, the charge system can shut down, so, the best practice is to try a know
good battery out of 2nd car, do you have battery to barrow, this is TOP CHOICE< not thinner wallet.
if the good battery fails then the charge system is failing (note I said system and not a part)
or the belt missing or slipping to the alternator.
btw the 4.3L PCM runs the alternator
PCM is engine brain.
btww, same true 2.2l engine.
the regulator is in the PCM.
so is the charge/bat lamp in cluster
on key on, lamp test
the jump start it , it runs
does the charge./batt.lamp go out.
id be all over that lamp, costs nothing to look.
Oct 09, 2016 | 1998 Isuzu Hombre
I went to plug my dyson dc 33 and it wont turn on
First, have you tried it in other outlets, If you do, and it starts, then obviously you have a bad receptacle - or at least one of the receptacles is bad. If that doesn't do it, try manually bending the prongs on the vac cord to widen them just a wee bit. If that fails, then there is either a short in the cord or something going on in the machine. Clean the roller bar - it pops out easily, dump the cylinder (it may be so full of schlock that it's protecting the vac by not starting). Having done all of that, if it still won't start, could be the motor is fried. At that point, call Dyson. . .
Aug 10, 2016 | Dyson DC-33 MultiFloor Upright Vacuum...
My new tv 40" led haier tv wont turn in at all please help
I understand in a way but if it is brand new--take it back and either have it exchanged or sent in for repair. From the brand you are in the UK? Many companies will insist it goes for repair (a shell game) but most major stores selling sets have an unwritten rule: for first 30 days it can be returned and either exchanged or credit given to purchase another set--reason does not matter= you do not like the color of the cabinet take back and they will (not be happy) do something.
Seen a few here in USA where set when removed from box was destroyed in shipping--told customer to take it for repair---again a shell game by maker to have seller deal with this issue.
Don't take no for an answer would be my solution here.
May 01, 2012 | Haier 40" Class LED-LCD 1080p 60Hz HDTV,...
When you're choosing sunglasses, does UV protection matter?
Yes, ultraviolet (UV) eye protection matters. UV radiation from the sun can damage not only the skin of your eyelid but also the cornea, lens and other parts of the eye. UV exposure also contributes to the development of certain types of cataracts.
When you're choosing sunglasses, look for UV-protection details on product labels. Choose sunglasses that block 99 to 100 percent of both UVA and UVB rays. Skip sunglasses that are labeled "cosmetic" and those that don't offer details on UV protection. Opt for larger lenses rather than smaller lenses - or, better yet, the wraparound variety.
Nov 07, 2010 | Clothing Accessories
Drop GE A1230 digital camera in water. Let dry and now wont power
Unfortunately, there are several parts that may be damaged with water. It doesn't matter if it's already dry. Water contains lots of minerals and other material that are conductive. Once the water evaporated, the conductive materials stays in the electronics.
As you have a broken camera anyway, you can try:
* Using a hair dryer, blow some hot air (no the hottest level) inside the camera. protect display away from the heat.
* Get a new camera to replace the damaged one.
Sorry Ricky, I don't think it can be fixed.
Aug 29, 2009 | Canon PowerShot SD850 IS Digital Camera
Red protection light wont turn 2 green no matter what so the amp wont work
Hello mcis43fan,
The protection circuit can be activated by shorted or grounded wiring or it can be caused by a defect in the amp itself.
First, disconnect all wires except power, ground and the remote turn-on lead and see if the amp powers up normally. If it still goes into protection, the amp is defective, most likely shorted outputs and needs repair or replacement. If the amp powers up normally, test the other wiring for shorts and grounds. You can reconnect them one at a time to determine which one is causing the problem.
Hope this helps.
Aug 06, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Wont let me record! Flashes "Protection!"
My Samsung camcorder one day displays protection. Used or new tape no difference. Used the menu options to remove protection and it gives me a play mode alert. Regardless I can not record in protection mode. Help!
Feb 08, 2009 | Samsung SC-D103 Mini DV Digital Camcorder
Protect Mode on Kenwood KDC-MP335
this is very simple to do just take your face plate off and were you see a red light blinking just get like a bobby pin or something and pit it through the hole and the radio will reset and that should fix your problem
Jun 23, 2008 | Kenwood KDC-MP205 CD Player
Stuck in protect mode
Speakers shorted out, blew a fuse. Replace the unit or (cross your fingers and) open up the box and find the blown fuse.
Nov 23, 2007 | Sony STR-DE425 Receiver
Car Audio & Video Logo
69 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
