Question about Philips Magnavox MWR20V6 DVD Recorder/VCR
My magnavox zv420mw8 combo will not play and shuts
My magnavox zv420mw8 combo will not play in vcr mode and shuts down after a few seconds If it does happen to play, it may eat the tape at any time. The dvd player works fine but, of course, I cannot copy a vcr tape. I am referring to non protected, or home made video.
  • ralph zimmerman Oct 18, 2009
    I have tried video head cleaners and no success.
    Finially I removed the cover. I understood nothing about what I was seeing. So, I prayed to GOD Who made heaven and earth and simply asked for His help as I have done in my past 83 years. I had read where certain light sensors made things happen and "The Thought" came to me to shield different parts from light. When I shielded this 'little post' on the left side of the set it played. I constructed a box from cereal box cardboard two inches high with half inch bottom and 1 inch on two sides amd placed it around the post. Now it works even with the cover back in place. You were a great help because I read somewhere about the sensors on Fixya.
  • 3 Answers
SOURCE: VHS won't play, sounds like tape will load then power shuts off.
This is similar or identical to another post, but here is an answer...
Hi, I have a solution you can try.
I had exaclty the same problem. When I tried to play a tape it would load (However, I recall I had to push hard to get the tape to be accepted, which is part of the problem) but would shut off after about 12 seconds, then when I powered back up the tape would eject. Finally I took the unit completely apart and attempted to use it with the covers off. Lo and behold, I found I could play a DVD on the unit without the unit powering off, but only if the room lights were on! If I tried to play a tape it would shut down the unit. So that led me to diagnosing the infrared loading and reel sensor circuits.
Background on that is there is an infrared LED that shines up through a plastic light pipe lens. The light from that LED (you can't see it) should shine on two photodiodes that are on either side of the tap mechanism, plus down through a gear with holes in it on to the reel sensor. When there is no tape inserted the two photodiodes will be illuminated and have about 0.2 volts across them. When a tape is installed the light will be blocked and the voltage goes up to above 2.5 volts across the diodes. You have to check this with the room lights dim as the diodes will respond to that light. When you block the light on either side of the plastic light pipe with your finger (with the unit disassembled) you should see the load motor engage, and it will back off when you take your finder away. For some reason in my unit the light from the LED was insufficient to turn on one of the diodes, and also to pulse the reel sensor when the gear turned. That could be due to component aging, or even if the light pipe started to cloud due to age, I don't know. However I was able to get the thing working...
In short I got the unit working by adding 3 resistors.
To do this you'll have to remove all the covers and remove the main PCB from the bottom chassis, unplug the power supply from the PCB, and the two ribbons going to the DVD unit. But you won't have to take off the VCR assembly, which is a pain. You just need some basic soldering skills, and remember where all those screws go...
First, I adjusted the voltage across the right-hand side load sensor diode to get the diode to switch on and off. I recall that I added 1meg across the diode. So the voltage then went from about 0.5v up to 2.8v from light to dark condition.
Second, I increased the current to the IR LED. I added a 330ohm resistor across the feeder to the LED. I recall that was R511 and was originally 220ohms. That was not quite sufficient to get the reel sensor working reliably. I didn't want to stress the LED by putting too much more current through it so looked for another idea.
Third I added 56k across the reel sensor diode to bring the voltage across it down so it would switch on and off as the reel sensor gear turned.
I now have a tape playing continuously in the unit and it seems ok for the time being. Hope that might work for you too.
Craig Townsend
Posted on May 26, 2009
premtech
  • 934 Answers
SOURCE: Magnavox combo vcr dvd
What you're describing is common when the center LED has failed / gone out. If you're really good at taking a unit like this apart and putting it back together - and not too bad with a solder stick you could attempt this one yourself... It is a pretty intensive repair but not difficult for a good shop just time consuming. The part isn't too expensive either, just an infared LED... In fact, we've run a bit short on stock once in awhile and bought one of the off the shelf versions from Radio Shack which worked just fine. Good Luck Bill
Posted on Jun 12, 2007
  • 31 Answers
SOURCE: No color and sporatic play on VCR mode, with zv420mw8
If this problem happened within a few seconds, you probably have dirty heads. If It happened slowly you could have an alignment problem. Both of these problems should be repair professionally.
Fuji
Posted on Jan 29, 2009
  • 173 Answers
SOURCE: Magnavox VCR/DVD recorder model ZV450mw8.
You will need a technical person to open the unit. This problem can be as simple as a dirty sensor, or bad tape drive parts, or burned out computer chip.
Posted on Feb 03, 2009
SOURCE: magnavox zv450mw8 Walmart VCR/DVD recorder. shuts off
Try better quality VHS tapes or 6-hour tapes instead of 8-hour ones. I had this problem myself when I used 8 hour tapes, but haven't had any problems with the 6-hour ones.
Posted on May 17, 2009
How do I change VCR recording speed on the Magnavox ZV420MW8
If you have the manual it is on page 79 (Press Rec Mode There are two speeds SP SLP it will toggle between the two.)
You can download the manual at http://www.funai-corp.com/6pdf/om/ZV420MW8.pdf
Jul 04, 2011 | Magnavox ZV420MW8 DVD/VCR
Machine shuts down after 6 seconds of operation
Machine shuts down after 6 seconds... Answer Failed: retry DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of... (More) (More) DVD/VCR Combo was working fine then one day machine started shutting down after a few seconds of operation. It happens with both, a VCR and a DVD. I can watch 6 secs. of a movie at a time.
May 07, 2010 | Sylvania DVC840G DVD Player/VCR
How do i change the drive belt on a magnavox vcr (very smart) #zv420mw8
First you need a service manual second you need a screwdriver, and maybe a magnifying glass, third the belt. (Thats the hard bit) (Also though if the/any belt is of same size & profile and length, then any belt will work) locate the belt, usually have to remove one "End" from something, take out belt, noting how it was, and.or use the manual. Re-thread, and secure the end, and test. manual below. http://www.nodevice.com/manual/newmans/funai/ZV420MW8pdf/get22628.html
Mar 22, 2010 | Magnavox ZV420MW8 DVD/VCR
Need a code to set my dvd/vcr combo (magnavox ZV420MW8) so that it will play all dvd/vcr from all regions.
I solved it by just tapping in numbers and I came up with a code don't ask me what it is because Iwas just randomly clicking and something came up. Thanks anyway.
Oct 30, 2009 | Philips Magnavox DVD/VCR Dual Player
DVD Recorder VCR combo, VCR will stop after 23 sec of play or rec
necesito saber que tecla presiono para desactivar el modo progresivo scan
Feb 14, 2009 | Philips Magnavox DVD/VCR Dual Player
Fuji
Jan 29, 2009 | Philips Magnavox DVD/VCR Dual Player
Magnavox ZV420MW8
This recorder only records inline. This means that there is no channel on recorder. It records whatever your satellite or cable box is showing. You'll have to change the channel on that.
I don't know that this will work for timed recording. You'll have to make sure that your cable/satellite is on and set to the proper channel before you leave. This wont work if you're recording multiple shows on different channels while you're gone. In that case you may need a different recorder.
Mar 16, 2008 | Philips Magnavox DVD/VCR Dual Player
VCR plays for a few seconds and rewinds. Now, the VCR plays tape in fast forward mode
Most everyone I know had problems with the tv/vcr combo including myself. I'll never buy one again. I'm sorry you are having the same problem.
Aug 28, 2006 | Quasar VV-2002 20 in. TV/VCR Combo
Philips Magnavox MWR20V6 DVD Recorder/VCR Logo
136 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
