Question about Homelite 'Yard Broom' Leaf Blower
How to position the two little plastic hoses going from carburetor to fuel tank.for my homelite leaf blower and Vac, i need a caburator view
  • 388 Answers
This is much easier than you think; the carburetor has two ports, one supply one return, the return port is the top port which allows excess fuel to be returned to the fuel tank when pressing the primer bulb. The bottom port is the intake that supplies fuel to the carburetor to be mixed with air and pushed into the cylinder for the combustion cycle. Both lines connect to the tank, the line with a cylindrical looking object is the supply line, that object is the fuel filter, so it would be connected to the bottom port of the carburetor. I hope that helps.
Posted on Oct 08, 2009
My homelite 26b is not getting gas into the primer bulb. It's only been used a few times...help
There are a few things to look for with this problem. First, open the fuel cap and look inside the gas tank. If the tank is more than half full, dump some out to assist you in seeing inside the tank. Look at the fuel line and filter. Make sure that hose is long enough to reach the bottom of the tank when tilted on its side. Make sure that there is a filter on the end of the hose also. Then follow the hose to the carburetor and the other hose from the carburetor to the primer. If they are all intact and no cracks, then the primer may be bad or there is a leak in the carburetor. It will have to be rebuilt.
Feb 15, 2011 | Homelite Garden
I have a Homelite "Vac Attack" leaf blower model
The fuel line is replaceable by itself, you don't need a new tank. Just make sure you get the same size line or it will leak where it goes into the tank. Any local small engine repair shop should have the line. There are two lines that go into the tank, the pickup line has the filter on it. It not only filters the gas but keeps the end of the line down in the fuel.
Nov 02, 2010 | Homelite Garden
I have a Homelite BackPacker leaf blower. It runs fine until the gas tank is about half empty. Then it sputters. While it's running, I can remove gas cap and replace and it runs fine again for a little...
Great job with the description of the symptoms. What you are describing is a classic case of vapor-lock. In other words, a vacuum is forming in the fuel tank and not allowing the fuel to flow to the carburetor.
Look at the cap, it probably has a small vent built into it. With a little compressed air, blowing from the outside in, try to clear the obstruction. This may not work, but don't worry. Just replace the fuel cap. Your local lawnmower repair shop can probably get a new cap for you. Otherwise, go to www.homelite.com click on the parts tab, enter your model number (starts with a "UT") and order a new one.
Oct 29, 2010 | Homelite Consumer Products Backpack...
I have a Homelite leaf blower that will start and run for a half tank og gas. However when the tank is half empty it stalls out and will not start. If I stop it fill the tank let it sit it will start
Sounds to me as though the fuel line that supplies the carburetor has been pulled out so that it is above the fuel when tank is 1/2 empty, or there is a crack/break in the fuel line inside the tank. Not a hard job to replace the fuel line, but takes patience. If your machine has 2 lines, only take 1 off at a time to avoid confusion as to which one goes where on the carburetor.
Dec 29, 2009 | Homelite 'Yard Broom' Leaf Blower
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
Just started bogging down when I try to give it gas.
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
*if all of the above are OK and/or do not improve performance then:
5) carburetor gaskets/diaphragms
Nov 09, 2009 | Homelite Consumer Products Backpack...
I have the homelite Vac Attack 2, i'm having trouble starting it, i prime it the desired 7 times (actually more) but i just sit there and pull, and pull, and pull the cord....really getting frustrated!
#1 senerio
Fouled spark plug
ie, carbon and or fuel fouled
install new plug, and withouth choking or priming, pull 4-6 times while holding the throttle at wide open.
If not fouled, go to senerio #2
#2 senerio
Fuel starvation - 'lean fuel' condition
1) spark plug
Remove Carburetor
5) replace gaskets/diaphragms
b) use a spray carb cleaner to clean jets, holes, and body of carb
Nov 09, 2009 | Homelite Leaf Vac Attack
I have two black hoses that look like they go to the gas tank one broke off and the other has a plastic nozzle on it and there is two holes in the bottom of gas tank is that where they are to go.
Yes, one goes to your primer bulb and the other is attached to the fuel filter in the tank. If the hose broke off, I suggest you go to your local small engine repair shop where you can purchase replacement hose. It will appear that the hose they give you is too big to go in the holes, so to solve that, you can cut one end at a 45 degree angle. Push and twist, push and twist will be the way to go. Now is a good time to replace your fuel filter as well. It might be rolling around in your tank now if that's the hose that broke.
The hose that has the nozzle in it...does that go to your primer bulb or to your carb?
Jul 18, 2009 | Homelite Consumer Products Backpack...
Can't figure out type of carburetor on my leaf blower.
I have seen 2 different carburetors used on this unit. A Walbro and a Zama. You will need to get the information off the carb. (Walbro WYC-10 or Zama K39A) are the two I have seen, but you need to be sure what yours is. Then purchase the correct O/H kit and rebuild it.
Apr 10, 2009 | Garden
Repair manual for mcculloch B320 blower
The hose with the filter in the tank is the pick up, the other is return. the pick up is usualy goes towards the middle pipe on the carby. if you get them around the wrong way it wont pick of fuel..
Screw the mixtures in untill they just bottom and screw them out 1 to 1.5 turns start up set low mix untill its just "four stroking" the set the high.
Jan 18, 2009 | Garden
Homelite 'Yard Broom' Leaf Blower Logo
513 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
