Question about Cakewalk Music Creator 3 Full Version for PC
I just installed this on a new computer but I can't hear anything on playback. How can I fix this? I have tried selecting an output but the only one listed is the MIDI mapper
  • Cakewalk Master
  • 5,603 Answers
I have the Sonar version of this. For it you have to select one or more tracks on a certain screen before playing can be done. The mapper just selects which instruments are tied to which MIDI channel. You have to arm appropriate MIDI channels as well as selecting output.
Posted on Oct 06, 2009
How can i fix my audio suon
Method 1: Restart the computer Restart the computer at least one time after you install a Windows Vista service pack to verify that all processes related to the installation are complete.
After you restart the computer, determine whether you can hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 2. uparrow.gifBack to the top Method 2: Try another sound deviceIf it is possible, try plugging a different sound device into the computer. For example, if you were using speakers, try a different pair of speakers or a set of headphones to make sure that the problem is not related to the sound device.
Determine whether you can hear sound. If you can hear sound, there is a problem with the original sound device and the issue is resolved. If you cannot hear sound, plug the original sound device back into the computer, and then go to Method 3. uparrow.gifBack to the top Method 3: Unplug the computer speakersUnplug the computer speakers or other sound devices that you may be using, such as headphones, from the computer and then plug them back in to the same port. Most sound cards that are compatible with Windows Vista include a feature that detects sound devices plugged into the audio jack. This procedure may prompt the audio detection feature to detect and configure the sound device to make sound.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try Method 4. uparrow.gifBack to the top Method 4: Verify that the default sound device is set correctlyAfter you install a Windows Vista service pack, you may find that the default sound device, also known as the playback device, was changed. You may also find that the sound quality has changed. Make sure that the default sound device is set correctly for the sound device that you are using. To set the default device, follow these steps:
  1. Click Start vistastartbutton.jpg, type Sound in the Start Search box.
  2. Click Sound in the search results at the top of the Start menu.
  3. Click the Playback tab. Notice the check mark next to the default device. For most users, the default device is Speakers. Make sure that your audio settings are configured as expected. Follow these steps:
    1. On the Playback tab, select the playback device, click Properties, click the Advanced tab, and make sure that the Default Format is set to the value that you expect. When you finish, close this window to return to the previous window.
    2. On the Playback tab, select the playback device, click Configure, and then make sure the configurations are set correctly.
    If the sound settings are set correctly, you are using speakers as the sound device, and your speakers are already set as the default device, go to method 5 now.
  4. Select the sound device that you want as the default sound device, and then click Set Default.
  5. Click OK to save your settings and to close the Sound dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If you cannot hear sound, try method 5. uparrow.gifBack to the top Method 5: Verify that a sound driver is installedWithout a sound driver, you will not hear sound. Make sure that a sound driver is installed. To do this, follow these steps:
  1. Click Start vistastartbutton.jpg, type Device Manager in the Start Search box, and then press ENTER.
  2. In the Device Manager dialog box, expand Sound, video, and game controllers.
    If there is a speaker icon next to the sound driver, the driver is installed. If there is a yellow question mark next to the sound driver, the driver is not present or will not load.
Go to method 6 to reload the current sound driver and test for sound. uparrow.gifBack to the top Method 6: Reload the current sound driver If you discovered in method 5 that the sound driver was not installed, or if you discovered that the sound driver was installed but is not working, try to reload the sound driver. To do this, follow these steps:
  3. Locate the audio device that was included with the computer.
  4. Right-click the device, and then click Properties.
  5. Click the Driver tab, and then click Uninstall.
  6. Make sure that the Delete the Driver Software for this device check box is cleared, and then click OK.
  7. In the Device Manager dialog box, click the Action menu, and then click Scan for hardware changes.
    You receive a message that states that a hardware device is being installed, and then the uninstalled audio device appears in Device Manager.
  8. Close the Device Manager dialog box.
Determine whether you can now hear sound. If you can hear sound, the issue is resolved. If the current sound driver did not reload or if it did reload, but you cannot hear sound, try method 7. uparrow.gifBack to the top Method 7: Update the current sound driver If the current sound driver does not seem to be working, see whether there is an updated sound driver that you can install. To request an updated sound driver, contact the manufacturer of the sound driver.
For information about how to contact hardware and software vendors, visit the following Microsoft Web site: http://support.microsoft.com/gp/vendors/en-usNote In some cases, the manufacturer may instruct you to uninstall the current sound driver and to delete the driver files. To do this, follow the steps in method 5, but at step 6, click to select the Delete the Driver Software for this device check box.
Dec 12, 2010 | Toshiba Satellite M35X-S114 Notebook
Speaker wires are pluged in on my dell inspiron 530 but not working help
    • 1 Make sure that your computer and speakers are plugged in, have power and are turned on. If the speakers are plugged in but don't appear to have any power, plug them into a different outlet. Some speakers are self powered and use a USB cable to supply power. Make sure that the USB cable of your speakers is connected securely to the USB port of your computer.
    • 2 Retest the sound. If you still don't have any sound, make sure the cable connecting the speakers to the computer (known as a 1/8-inch TRS cable) is plugged into the green audio output jack on the PC.
    • 3 If you're using self-powered USB speakers, remove the USB cable and plug it into a different USB port. If you're using outlet-powered speakers and have a working set handy, replace the suspected non-working speakers with the working pair to test.
    • 4 Navigate to the Microsoft Fix It troubleshooter (windows.Microsoft.com/en-US/windows/help/no-sound-in-windows) to automatically detect and fix sound playback or hardware problems. If that doesn't work, proceed with the next step.
    • 5 If you have an add-on sound card and none of the hardware or software fixes helps, you may have to replace the sound card. If you use on-board sound, it will probably pay to purchase an inexpensive sound card rather than a new motherboard. Check the system BIOS to determine whether you have inadvertently disabled your on-board sound.
    • 6 Navigate to the "Start" menu and select the "Control Panel" and "Sounds and Audio Devices." Then click the "Volume" tab. If everything is grayed out, proceed to Step 7. If the "Mute" box is checked, uncheck it. In "Device Volume," make sure that your volume level is set to a comfortable volume level for your speakers.
    • 7 Click the "Sounds" tab. Under "Sound Scheme," determine whether "No Sounds" is selected. If it is, click "Sound Schemes." A drop-down list will appear. Select "Windows Default" as the scheme. To test your sound now, click on a sound listed below the "Program Events" window. The sounds will be indicated by a small "Speaker" icon located next to them. Left-click the sound once, then click the "Play" button. If you still don't hear sound, proceed with the next step.
    • 8 Click the "Audio" tab. Under the "Sound Playback" option, make sure your sound card is selected as the default playback device. Usually, only one device appears here, unless you have multiple playback devices installed.
    • 9 If everything is grayed out, you either do not have a playback device installed or your drivers are corrupted and need to be replaced. Drivers help hardware and software function together. Fix this by reinstalling the appropriate drivers. Do this by navigating to the "Start" menu and right-clicking "Computer." Then select "Properties" from the drop-down menu. Click the "Hardware" tab and then click the "Device Manager" button. The Device Manager will open.
    • 10 Look for either a red X or a yellow question mark listed under "Sound, Video, and Game Controllers." If a red X appears, right-click the device with the X and select "Enable" from the pop-up menu. Test your sound at this point. If a yellow question mark appears, right-click the device, click "Properties" from the pop-up menu, and then click the "Driver" tab on the window that appears. Next, click the "Roll Back Driver" button to roll back to the previous drivers that were functioning correctly. Restart your computer when prompted.
    • 11 As a last resort, you can uninstall and reinstall the device. To do this, right-click the device and select "Uninstall" from the pop-up menu. Restart your computer. Windows will automatically detect and install your audio device upon boot-up. If you still don't hear any sound from your computer speakers, contact a qualified computer technician.
Nov 14, 2010 | Dell Inspiron 530s Desktop Computer
I have a canon sd 1100 camera with video recording. It no longer records the sound with teh video and I don't know if I hit a button or if it just broke. any thoughts?
If you're not hearing anything on playback on the camera, try pressing the up-arrow during playback to increase the volume. If you're not hearing anything on playback on a computer (and neither the viewer nor the computer are on mute) then something is broken on the camera, causing it not to record audio.
Jul 06, 2010 | Canon PowerShot SD1100 IS Digital Camera
When I record and listen to playback, I only hear the left side.
This is normal for recording. Even professionals do the same. What you need is to set your input to mono(either hardware or software), or explore your software look for effects like STEREO to MONO with some delay which I prefer for my recording. I did have a good result. Good Luck
Mar 07, 2010 | M-Audio M AUDIO MOBILE PRE - USB MIC...
No sound from the HDMI
This document pertains to HP or Compaq PCs with an HDMI (High-Definition Multimedia Interface) connector for connecting a monitor or TV. If you use HDMI to connect your display, you must activate HDMI sound by adjusting your Windows settings . If HDMI is not activated, you cannot hear any sound. Because of this, HP recommends that you connect analog speakers to the computer to hear sound during the initial setup of the computer. Use the following steps to activate HDMI sound on your computer: NOTE: If you ever perform an HP system recovery, you must repeat this procedure to activate sound for the HDMI connector.
  1. Right-click the Volume icon by the time in the lower-right corner.
  2. Click Playback Devices . The Sound window opens.
  3. On the Playback tab, click Digital Output Device (HDMI) if it is listed. If it is not listed, click Realtek HDMI Output . Figure 1: Digital Output Device (HDMI) selectionc01503048.gif Figure 2: Realtek HDMI Output selectionc01063625.gif
  4. Click Set Default .
  5. Click Apply .
    • If you used Digital Output Device (HDMI) , click OK to close the window. This completes the steps to activate HDMI sound.
    • If you used Realtek HDMI Output , continue with Step 6.
  6. Double-click Realtek HDMI Output . The Realtek Digital Output Properties window opens.
  7. Click the Supported Formats tab.
  8. Place a check in the 48.0 KHz check box, and make sure that there are no checks in the Dolby Digital check box and all other check boxes. Figure 3: Supported Formats settings in the Realtek Digital Output Properties windowc01503049.gif NOTE: For most TVs to play back audio, the sample rate must be 48.0 KHz.
  9. Click OK to close the window.
Nov 23, 2009 | HP Compaq Computer Speakers
Problems with audio after installing radeon hd 2400
This happens because the video card has hdmi output. Since hdmi output can carry audio signals also, the audio driver gets disabled. Uninstall audio driver and video driver both, install the video driver, and then install audio driver. after installing the audio driver, in playback and recording devices choose choose the audio output device you purchased along with the computer. This should fix the issue.
Revert back for any clarifications.
Warm Regards,
Zulfir Sadat M
Apr 12, 2009 | Diamond Multimedia Stealth RADEON 9250,...
Bought an MXL V88 Mic and i hear no sound ,not working
go to control panel> hardware and sound> sound; click recording tab, select USB Audio Codec, select Properties, click Advanced tab, select 2 Channel 16 bit 44100Hz and then hit apply. You have to make sure you have the 2 channel option selected. otherwise the computer just recognizes one channel and assigns it for playback. HTH
Apr 09, 2009 | Audio Players & Recorders
No sound from the monitor or playback
check out where your monitors are receiving their audio from.is it from the tascam or the onboard or audio another interface.first choose an output for your sound,if you using the tascam as an output for your sound connect your monitors to the phones input in front and use the mono mix knob to swap between audio coming from your usb or computer.if you want to hear from your mic or guitar move knob to usb if you want to hear from computer as in playbck move it to computer.
Nov 21, 2008 | Tascam US-144 Sound Card
Headphone jack
when the sound device is installed it should give you sound effect manager or sound device,to access this go to START then CONTROL PANEL then SOUND SPEECH AND AUDIO DEVICE,open Sound Effect Manager,then Sound Effect,select Headphones from the Enviroment Dropdown and click ok.test this output now.
If this doesn't resolve the problem ,
reinstall device again.
Jul 09, 2008 | Acer Aspire 3680 Laptop
Sonar 6 Producer - palyback quality issue
I had this problem today whilst installing Sonar on my new laptop. It wasn't the click track. It was the playback glitching, clicking and rattling. I put the buffer size to maximium but it was still happening.
I got round it by downloading the latest version of ASIO4all (2.9 beta4) and installing it. I then opened Sonar 6, options, audio, advanced, then selecting ASIO in the driver mode drop down box. Then I closed Sonar and reopened it.
If you use one device for recording and playback it should work now but if like me you use seperate devices or if it doesn't work click, options, audio, general, ASIO panel, advanced options. Here you can select your inputs and outputs. Play around a bit here. Mine worked when the output of the playback device was selected and both the input and output of the recording device was selected.
ASIO4all sorted out my latency issues as well.
Hope it helped.
Mar 12, 2008 | Cakewalk SONAR 4 Producer Edition for PC
Cakewalk Music Creator 3 Full Version for PC Logo
159 people viewed this question
Top Cakewalk Computers & Internet Experts
Parshiv Luthra
Are you a Cakewalk Computer and Internet Expert? Answer questions, earn points and help others
