Question about JVC AV48P777 Television
Where can I purchase a focus block for a jvc av48p777 tv? I need it asap
  • dsantiago726 Oct 07, 2009
    nO LUCK BUT THANK YOU I SENT EMAIL TO JVC I SEE TOMORROW
    Brigadier General:
  • 5,158 Answers
One source is
http://bestbuy.partsearch.com/Model/Matsushita/JVC/AV48P777.aspx
you may also be able to purchase parts here
http://maps.jvc.com/cAscList/
let them know what you need
Posted on Oct 06, 2009
Jvc AV-48p777 turn on goes right back off thin green light wont come on again unless i unplug it
The power suply board is dead.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Sep 09, 2010 | JVC AV48P777 Television
No sound or input
You have the center sound on in your menu, just turn off the cneter sound option and it will all come back on
May 14, 2010 | JVC AV48P777 Television
I have a model av48p776 jvc I am getting jitter lines across the screen more often than not and the bright comes and goes what do I need to do to fix it I would hate to get rid of the TV I just bought it
JVC AV48P776 Jitter and Brightness Varies
Check for convergence failure. Convergence Gallery Try adjusting convergence in user menu. If convergence display is messed up or adjustments do not work correctly, you have an Intermittent short circuit within an STK IC.
Look at menu screen with an unused input (antenna or video). If menu is stable and clear, TV may be OK and you may have a signal input problem.
If it is not poor quality input signal or convergence problem, someone has to troubleshoot to determine if it is a Video, Processing, Power supply or CRT related problem.
Most likely convergence.
easyab
Feb 28, 2010 | JVC AV48P777 Television
Need to reset v-chip code JVC t.v. vcr combo 2000
I got a jvc tv-13142 at a pawn shop but some of the channel is blocked and i need a vchip code to unlock it i try all zeros and it show error how do i reset code
Jan 22, 2010 | JVC TV-13142 13 in. TV/VCR Combo
MY JVC AV 48p777 wont turn on. It may be the power board????? is there a test i can do to identify the problem?????
Yes unplug the TV for 5 minutes and hold the menu button down while powering it up for 1 minute then release the button and press volume up 6 times followed by down volume key 4 times.
Let me know if it works
Dec 15, 2009 | JVC AV48P777 Television
The HDMI inputs won't work. I've adjusted
You will have to go into the settings and turn on hdmi input
Sep 21, 2009 | Televison & Video
Blinking powerlight on front when i try to turn on tv
This is more likely a power supply failure. Most causes of tv failure are due to bad capacitors on either a system board or the power supply. In this case, it sounds like the power supply. You can test the capacitors with a capacitor tester to determine faulty capacitor. You can also test other components like power supply current with voltmeter or mulit-tester.
Aug 13, 2009 | JVC AV48P777 Television
Vertical jitters on picture - JVC AV48P776
What you are experiancing is loss of High voltage. The line is called a retrace line. It is usally caused by failure of the flyback circuit or aging of the TV tube. This is the single most common failure with CRT based display systems. The high voltage can be tweaked up, to accomidate for the age of the tube. Its a short term solution. Because of the high voltage nature of this circuit, suggest a professional repair.
Jun 29, 2009 | JVC AV48P777 Television
We had a bad storm and now my JVC AV-48P777 won't turn on. I have tested all of the outlets, but no luck. Help!
There is a fuse on the inside back panel that is suspect. Located near the power entry to the back of TV. Some versions were socketed others soldered.
Jun 10, 2009 | JVC AV48P777 Television
JVC 48WP74 HDTC rear projection
While it is true JVC tubes rarely fail, they can give trouble.
Another possible solution is bad screen / focus block......
Remove lower front grill panel and access board...Check for
smooth adjustment of RGB screen and focus.....let me know....T..
Sep 28, 2007 | JVC AV-48WP74 48" Rear Projection...
JVC AV48P777 Television Logo
55 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
