Question about Olympus FE-170 Digital Camera
The lens dont come in and the screen is black
Canon A630 lens error and black photos
hi u need to get the lens repaired the railing in the lessystem is no correct so pleas dont try to doit or push in .... it will be permanent damage ....get to the shot5 the camera is not broken need small fix....
Aug 30, 2009 | Canon PowerShot A630 Digital Camera
This is exactly my problem.
Focus is stuck - could be sand or something in the focus gears. That's the weak spot for these lens. Contact your local Olympus service center or any other camera service center or me at toms.safranovs@gmail.com
Tom
Jul 28, 2009 | Olympus FE-170 Digital Camera
Image is always black, CCD working fine
lens retract or not
it is a possible CCD FAILURE !
u are covered dont worry it is a manufac fault inn CCD's Canon has issued service advisory for the issue pls see the link and call them and PLS RATE ME FIXYA for help
http://www.usa.canon.com/consumer/controller?act=PgComSmModDisplayAct&fcategoryid=221&modelid=8288&keycode=2112&id=29819
just give them a call and they will send u postage paid envelope no mattter which region u are in it is for the whole world !!!
May 07, 2009 | Canon PowerShot A75 Digital Camera
E18
E18 is the canon fault number for lens error. Is the lens stuck out? does it click when the camera is switched on? Try lightly tapping the lens on a hard surface. This sometimes resets the lens. If all this fails take it to bits! (but watch the flash module as this can give a nasty shock.Big black capacitor) You will see the lens module take the it to bits carefully and re seat the components. I have done a few over the years. It takes about an hour. If you have any more issues contact me.
Sep 04, 2008 | Canon PowerShot A400 Digital Camera
Problems taking pictures
Six months - Yes warranty.
Yes vendor still liable
Jun 14, 2008 | Nikon COOLPIX S6 Digital Camera
Samsun s630 lens is stuck out, won't turn on
guessing it was dropped, have a side look at the lens, its probably not straight. pull it straight gently and try again
Apr 19, 2008 | Samsung Digimax S630 Digital Camera
Black particles on focusingscreen
If the specks are just on your viewfinder focussing screen, they won't be on your pics. If they're on both your pics and focussing screen, you need to find someone else to clean your camera. Cleaning either your CCD sensor or your screen yourself can leave scratches. Changing lenses often can suck dust into the inside if the body is dusty. Try another repair shop for thorough cleaning - it shouldn't cost more than $50.
Dec 17, 2006 | Nikon D70 Digital Camera with 18-50mm Lens
Water behind screen
Did he think the programming stunk or something??? lol sorry. Sometimes the screens or lens is truely what they are are two piece type lens, depending on the make and the age of the set. On two piece screens (or lens) theres an outer type called a linticualar lens and the inside is like a light house lens as its called a freznal type lens. On Some makes and models these come apart BUT also in some makes and models they are a one piece design. as theres an inside ground lens and the other side is another ground lens. But im woundering if yours isent the two piece type that could be taken out and separated and cleaned as why would it suck up into the lens if it wasent??? I would call a specialist and ask them if its a two piece and could be cleaned or is it a one piece. Try calling toshiba first so you know what it is so you dont get ripped off so the repairperson wont pad the bill. Good luck Oh try calling this # first. 800-457-7777
May 25, 2006 | Toshiba 46H83 46" Rear Projection...
Olympus FE-170 Digital Camera Logo
19 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
