Question about Dell Latitude C610 Notebook
Laptop screen colors are all muted.
Just replaced Screen on D810..Worked perfectly for months. now the color tone is muted on my screen, lost clear multicolor display. Is there a diagnostic program to check this problem out? Thank you
  • jovanni cabanag
    jovanni cabanag May 11, 2010
    which one is lost? multi color display? what do you mean?
    Scholar:
  • 67 Answers
Connect an external monitor to your laptop. If it displays beautiful colors that means you have a defective backlight/inverter/screen. Have it checked by a professional. It could be expensive to fix. You may think to buy another laptop.
Posted on Oct 07, 2009
My xbox 360 causes my hdtv screen to crash and display colored static. It only does this on the 'optimal display' of 1680x1050. I plugged in my laptop on the hdmi and it worked perfectly. Is t
Try manually choosing lower resolutions in your xbox display settings. My Insignia HDTV does that when switching resolutions like on Hulu in between commercials and then back to the show but only for a second or so. Also does this when going from the loading screens to the game screens for a few seconds when playing the game Split/Second
Jan 10, 2013 | Microsoft Xbox 360 Console
I have a HP dv5000 notebook and the screen started showing weird colord lines and eventually turned black. I replaced the inverter and it worked for a couple of days then it did the same thing. I...
The problem is not from the inverter of the laptop. It is the module that is faulty, the module is like a flex in the laptop that assists in getting information from the motherboard to the screen, if it is faulty, it will start showing weird colors or start having some screen malfunctions.
Have the module replaced and the laptop will be in good condition once again. I had such experience with my HP530 and i replaced the module, trust me it worked perfectly fine.
Take care and good luck
Oct 14, 2010 | HP Computers & Internet
Vertical lines on my lcd laptop screen
It's the connector problems.
If you know what to do, I can guide you:
First, remove the screw all over the LCD case, then you can see the connector, and flexible cables.
Second, remove the keyboard unit(by removing all screw on the unit), after removed, find the edge of the LCD cables, then you can see the connector.
The solution:
1.Try clean this two connector with soft brushes ( paint brush is good ), by removing the cable first,then clean the flexible connector using wet tissue ( use the alcohol ).
2. If still exist, you need to replace the flexible with new ones.
Feb 26, 2010 | Dell Inspiron 6400 Notebook
WHEN I DISCONNECT THE POWER SUPPLY THE SCREEN GOES DIM
how do i get permission to download flashplayer on laptop
Feb 23, 2010 | Dell Latitude D810 Notebook
Anycool T828 - Screen
There are three reasons. The LCD got damaged, change it. The connectors got loose/disconnected due to fall, have them fixed again and the display IC got damaged (hope not) as no one can repair it. The phone is scrapped if the IC goes.
Aug 25, 2009 | Cell Phones
Different color vertical lines on screen Sony KDF-E55A20
Go to the last page of troubleshooting in the manual and perform the system reset procedure. Basically hold the Wega "arrow up" as you manually switch the TV off. It will automatically switch back on and reset. I had only vertical colored lines on the screen, with audio but no response to any remote control functions. The rest worked perfectly.
Aug 06, 2009 | Sony KDF-E55A20 55 in. LCD Television
Laptop screen fading in streaks
this thing happened in my laptop also i got green screen fully
then when i hit it behind the screen it was gone but comes many times then again i would hit
later on the screen was completly lost then had to replace the screen
yous is a starting period so go to a nearby computer service and fix the screen
May 27, 2009 | Compaq Presario M2000 Notebook
HP Pavilian external monitor color problem.
The easiest thing would be to check your cable for a bent or loose pin. Next put another external monitor on the laptop. The circuitry to provide video to the laptop screen and the external monitor are separate except that they share a video processor and video memory. There can be bad electronics involved.
Apr 08, 2009 | HP Pavilion dv6000z Notebook
Canon MP 730 prints wrong color tones
I was having a similar problem-- what was happening was the print cartridge head seemed to be letting the colors leak into each other. (the science behind this is beyond me!)-- I noticed that instead of being cyan/magenta/yellow, my yellow cartridge had actually turned green, magenta was picking up blue and was turning purple, etc etc. I ended up replacing the printer's printhead and all the color cartridges and then it worked.
You can order printheads online.
Not sure if this fixes the original reason why they got all mixed up in the first place-- if the printer will continue to allow the print head to leak the colors into each other-- but hopefully that's a fixit!
Aug 10, 2008 | Canon SmartBase MP730 All-In-One InkJet...
Left side vertical color lined right side clear picture half screen
I solved the same problem by replacing my digital board. Cost $118.00. Been working perfectly for several months now.
Apr 06, 2008 | LG 42PX5D 42 in. Plasma HDTV
Dell Latitude C610 Notebook Logo
121 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
