Question about Whirlpool LER5636P Electric Dryer
Whirlpool dryer LER4634PQo won't heat up - Whirlpool LER5636P Electric Dryer
    President:
  • 1,304 Answers
If it spins
its more than likely just your heat package
ive included the national part number
you can order it through sears
4391960 42.00
Posted on Oct 06, 2009
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: I HAVE A WHIRLPOOL DRYER
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
if you dryer is gas check out this gas no heat tip....
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
check out this electric no heat tip...
heatman101
Posted on Feb 11, 2011
heatman101
  • 43501 Answers
SOURCE: whirlpool dryer - ler4634pqo
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Posted on Sep 06, 2011
Whirlpool GEW9200L Electric Dryer won't heat up
The heating element can fail open. Curious that Whirlpool did not mention that possibility.
Jan 25, 2018 | Whirlpool GEW9200L Electric Dryer
Whirlpool dryer - ler4634pqo Runs fine but won't heat or shut off. Happened at same time.
heatman101
Sep 06, 2011 | Whirlpool Dryers
I have a Commercial Quality Whirlpool model LER4634PQo 4 cycle/ 3 temp electric dryer. The drum turns but it's not producing any heat. it's hooked up to a double breaker. It worked...
The most prominent things to go out causing the dryer to not heat are, thermal cutoff,high limit thermostat,heat element & cycling thermostat. All of those in the rear of the dryer and be checked with a meter set a low ohms setting and check all listed parts for continuty. THe picture shows locations of all those parts. The only one in the picture that has nothing to do with it not heating is the THERMAL FUSE,the thermal cutoff is different from the thermal fuse. If all those check good i would suspect the TIMER as being the problem but most likely it will be one of those on the back as pictured.
Good luck,i hope i have been able to help you determine why your dryer won't heat...GENE
Aug 15, 2011 | Dryers
2005 Whirlpool Gas Dryer. It won't heat. The coils won't glow. Had the fuses, ignitor, and coils checked and are ok. Could it be the timer? How do I check it?o
heatman101-
Jul 22, 2011 | Whirlpool LGQ9858P Gas Dryer
My ler4634pqo dryer has no heat. I have taken the back panel off but do not know how to locate the fuse.
heatman101
Jun 26, 2011 | Whirlpool Dryers
I HAVE A WHIRLPOOL DRYER MODEL LER4634PQO...IT WON'T STOP RUNNING WHEN IT GETS TO END OF CYCLE AND IT DOES NOT HEAT UP
heatman101
Feb 10, 2011 | Whirlpool Dryers
Mod ler4634pqo push button to start and nothing--i traced power all the way to push button and it is fine ?????
Did you check the HI Limit on the back where the heating elemnts is?There is a little red button on click disk where the heating elements is. Power has to go throught there before it gets to the push button.
Jan 29, 2011 | Whirlpool Dryers
MY LER4634PQO DRYER HAS STOPPED GETTING HEATED? FUSE BOX WAS CHECKED AND THAT WAS OKAY..WHAT COULD IT BE?
ALWAYS UNPLUG YOUR DRYER BEFORE ATTEMPTING TO DO ANY WORK ON IT.
Check to make sure you are getting full 220 Volt power to the dryer, if you are then:
Sounds like your problem may be with the heating coil. Remove the back/or front just under the door of the machine and try to locate the air duct going from the blower to the drum. Normally inside/outside of the air duct you will find the heating coil and the thermostats/thermistor. Once you have located the heating coil, remove the two wires from it and check the coil with an ohm meter across the two terminals of the coil.
You should read continuity across the terminals, if not you will need to replace the coil as it is faulty.
If the heating coil is ok, then:
You can check the thermostat/thermistor one at a time, by removing the two wires and taping them together with electrical tape or with an ohm meter. (Should have/show continuity)
If the coil heats up then replace the thermostat/thermistor.
DO NOT LEAVE THE WIRES TAPED TOGETHER AFTER THE TEST.
This could cause a FIRE, as you have removed the safety of overheat from the machine.
Please rate me
Aug 23, 2010 | Whirlpool LER4634J Electric Dryer
ITS MODEL number ler4634pqo
take a clothes hanger and try and remove it
Apr 21, 2010 | Whirlpool LEQ8000JQ Electric Dryer
Whirlpool model LER4634PQO dryer. Will not heat. Dryer also will not shut off. Timer is running but will not shut off at the end of cycle. Can manually shut off and opening the door also shuts dryer off.
96f3244.jpgEither the top limit or the element is open, that is why the timer motor is not advancing. The small wire on the bottom limit powers the timer motor. The fuse is not blown because the dryer runs. The fuse has smaller wires and is tied into the door switch wiring and when it blows it is as if you opened the door. If the top limit is dead it is because of a vent blockage. I have repair photos HERE
Feb 28, 2010 | Washing Machines
Whirlpool LER5636P Electric Dryer Logo
247 people viewed this question
Top Whirlpool Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Sal De
Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
