Question about Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill
Hi I have a makita drill 18 volt. I lent the drill to a friend and got it back not working properly. When I squeeze the button, the motor is running but the head of the drill is not turning and doesn't turn the screw. It makes a funny noise like the head is slipping and not gripping anymore inside. Please help!
  • 1,305 Answers
Check the speed control. There is a speed control usually from hi to low... sounds like it's in between speeds... try adjusting it back and forth...
It should go back into one gear and work fine.
Posted on Oct 06, 2009
Makita BHP452ZW light works but no drill power
Your most likely problem is the switch (PN 650583-6). When they go bad they will let power go to the LED light but it won't get to the motor. With a multi-meter, check the power going into the switch and coming out to the motor. If 18 volts are getting through to the motor then you may have armature (PN 619198-8) issues.
Nov 26, 2013 | Makita BDF452HW 18V Cordless Lxt Lithium...
Bhp452 makita cordless drill smoking. how can i troubleshoot?
the switch or motor is wired incorrectly. These parts are polarity sensitive. The smoking I would assume is from the old switch and now the rotation is reversed. Let me know if you need more assistance.
Dec 10, 2011 | Makita 18 Volt Cordless Hammer Drill Kit ...
I have 3 drills, (2)14.4 and (1)18 volt Dewalt. the 14.4 drills starT to smell of burning and then smoke. One of the 14.4 drills seems to be less powerful. The 18 volt hammer drill is stuck in forward...
Well burning and smoke is either a switch or motor. Disconnect the motor and run it with battery voltage and no switch. If it's still slow and smokes it's the motor if not it's the switch. The other one sounds more like the switch but could be the motor. Testing would be the same as the other. On the 18 volt open it up and see if the reversing lever got hung up. It may be that you can line it back up and be ok. More likely it's a bad switch and needs to be replaced.
All these tools have static sensitive switches and need to be worked on at a static free work station.
Hope that helped..
Oct 16, 2011 | Dewalt 18 Volt Compact Drill Kit
My Makita BHP451 Li ion battery drill periodically the varible speed does not work, ie. the button works as a on/off switch - any idea what's wrong. Thanks Bjarne
Bjarne, odds are the variable speed function of the trigger is failing. There are Makita repair centers that perform repair, and sell parts if you want to take it on as a DIY project. Before proceeding, I would make sure the warranty has expired. If it is still in warranty a Makita repair center should repair it for no charge.
Dec 19, 2010 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Between us my son and I have 10 18 volt batteries for our Makita power tools which we use in our Carpentry work of these 10 batteries 6 have failed. I have to say the reliabillity of the Ni-cad equipment...
Join the battery collectors club. I have 25 batteries, 12 guns, I quit buying the batteries, I found it cheaper to buy the gun with new batteries and charger once a year. Cause they don't even last that long. I have tried different brands too all the same. Got batteries?? Sure do.
May 15, 2010 | Makita Tools 18V 1/2" Lxt Lithium - Ion...
I have a makita cordless drill 18 volt,after I release the trigger it keeps running..
dirt in the trigger most likely. you will have to take it apart and clean it. Some hardware stores may service it for you.
Jan 07, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
My Makita BTD140 seems to be gradually losing torque. Batteries(tried 4) check out okay. It just doesn't have the power to drive screws like it used to.
If the motor is working good then check the hammer and anvil to see if they are rounded over. A weak spring under the hammer can also add to this problem. Also check the spindle and the two steel balls that hold the hammer to the spindle. Sometimes the spindle will become chipped on the edge of the grooves and let the steel balls get out of alignment in relation to the hammer.
If the motor itself is loosing power with full batteries then you will need to check the brushes and the armature for damage. If the brushes are chipped or broken you should replace both the brushes and armature. Any questions please post back.
Oct 27, 2009 | Makita LXT202 BHP451 18 Volt Hammer Drill...
Dewalt 18 volt cordless hammer drill
You should try to charge the battery again. Or you can try to fix it or then its time to get a new battery.
May 10, 2008 | Dewalt 18 Volt Compact Drill Kit
Makita 2 Bl1830 18v Battery,dc18ra Charger Lxt Fr Drill Logo
597 people viewed this question
Top Makita Drills Experts
John Trevino
Are you a Makita Drill Expert? Answer questions, earn points and help others
