Question about Canon PIXMA iP1800 InkJet Photo Printer
My pixma IP1980 ahs an error and the green at orange lights blink alternately. error code is 6000.. pleasehelpme...
    President:
  • 787 Answers
Error code 6000 mean line feed error. Possible problems in:
- Timing sensor unit
- Timing **** disk film
- Feed roller assembly
- Platen unit
- Logic board assembly
- PAPER FEED MOTOR
Posted on Oct 19, 2009
My printer canon mx328 error 6000
This information is directly from the Canon website, basically it suggests something is stuck inside. Other articles I found mentioned one person found a paperclip stopping the works.
---- quoting Canon ----
6000/P03 - Orange and green light blinking 3 times Description:
A service error has occurred.
Resolution:
  1. Turn off the printer.
  2. Disconnect the power cable.
  3. Open the printer cover.
  4. Check for any orange protective tape or white polystyrene and remove if necessary.
  5. Check that there are no foreign objects in the printer (such as a paper clip) and remove if necessary.
  6. Close the cover.
  7. Reconnect and turn on.
If the above solution has not resolved your error, please contact your nearest Canon authorised service facility using the link at the top of the page.
----- end quote ---
Best wishes -
http://www.canon.co.uk/support/consumer_products/product_ranges/printers/maxify/error_codes/#6000
PIXMA Printer Error Codes and Error Messages
Jul 05, 2015 | Canon Office Equipment & Supplies
It shuts off and blinks 11
AHX18MEV
4 - 12
[8] SELF-DIAGNOSIS FUNCTION
1. Indoor unit
(AH-X18MEV, AH-X18MEV-1, AH-X24MEV, AH-X24MEV-1)
To display the self-diagnosis, hold down the AUX button for over 5 seconds on the indoor unit when the indoor unit is not operating.
• The operation lamp (red), timer lamp (orange) and Super jet lamp lighter) flash to indicate the information of malfunction.
(Display of self-diagnosis result)
The operation lamp (red) and the Super jet lamp (green) flash in synchronization with the timer lamp (orange).
(AH-XP18MV, AH-XP18MV-1, AH-XP24MV, AH-XP24MV-1)
• The POWER CONSUMPTION indicator indicates the information of malfunction by showing the main category error (number) and the sub-category
error (-number) alternately in 1-second intervals.
Example: Compressor high-temperature error
Remark
3. CHART
<INDOOR UNIT> ?:1-second ON / 1-second OFF
Problem
symptom
Outdoor
unit indication
(LED1)
Indoor unit Malfunction
No.
Content of diagnosis Check point Action
Lamp Main Sub Main Sub
Normal
condition
Normal
blinking
? ? ? ? ? Timer (Orange) 0 0 Normal
Operation (Red)
Super Jet (Green)
Indoor and
outdoor
units do not
operate.
1-time ? ? ? ? ? Timer (Orange) 1 0 Outdoor unit
thermistor
short-circuit
Heat exchanger
thermistor short
circuit error
(1) Measure the resistance
of the outdoor
unit
thermistors.
(1) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
Super Jet (Green)
? ? ? ? ? Timer (Orange) 1 Outdoor temperature
thermistor
short circuit error
(2) Check the lead wire
of the outdoor unit
thermistor for torn
sheath and shortcircuit.
(2) Replace the outdoor
unit thermistor
assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 2 Suction thermistor
short circuit
error
(3) No abnormality
found in above
inspections (1) and
(2).
(3) Replace the outdoor
unit control
PWB assembly.
? Operation (Red)
? Super Jet (Green)
? ? ? ? ? Timer (Orange) 3 2-way valve
thermistor short
circuit error
? Operation (Red)
? ? Super Jet (Green)
LED1
AU-X24MV, AU-X24MEV
AU-X18MV, AU-X18MEV
LED1
May 27, 2012 | Sharp Heating & Cooling
Error code p08 showing. pixma mp258
This is a waste ink absorber warning. 3 choices 1. take to service center to have it cleaned, 2. attempt to clean it yourself, or what I did without problems on my MP470, 3. follow these instructions:
Waste ink full reset
These are the instructions which worked for me on my Canon pixma mp470:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Dec 28, 2010 | Canon PIXMA MP210 Photo All-In-One Printer
My canon iP1980 printer is blinking orange light 7 times then 1 green. what should i do?
Try to use another cartridge (borrow from another printer first)
This should fix your problem, I hope.
Jun 08, 2010 | Canon PIXMA iP1800 InkJet Photo Printer
Canon pixma ip1980 service error 6000
Hi there
You can try this may help you.
These are the steps:
1. Turn On iP1980
2. Push and Hold Resume button about 2 minutes
3. Release Resume button
4. Printer back to normal again
To get Permanent , follow the steps here :
Manual Resetter canon Pixma iP1980/1900 Download
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 07, 2010 | Office Equipment & Supplies
Green and orange light is blinking continuous.. and the cartridge head is not moving. ip1980.. please help..
check the status of the printer in its driver. the error will be shown there. error 5100 is the most common. error 5100 means the carriage is experiencing difficulty in moving itself.
Jan 19, 2010 | Canon PIXMA iP1800 Printer
LED light keeps blinking
That is a service error code, but you need to count how many blinks between the longer green blink, and that tells the error code...
Oct 13, 2009 | Canon PIXMA iP1500 InkJet Photo Printer
Ip1980
Error 6000 is not completely defined but you can reset completely the printer by the following steps:----------
  • Unplug the cable to cut off electricity.
  • Press the Power Button and while doing it enter Power Cable into socket to turn on.
  • Then give the resume command 2 times. For the command you need to press the glowing orange button and then the green indicator light.
  • Then disengage all pressed buttons.
  • The printer will get warmed up and will be resetted.
Thank you Sir, Have a nice day.
Sep 23, 2009 | Canon PIXMA MP150 All-In-One InkJet...
Error lights
Dear mary,
Blinking in Orange/Green or jus Orange is one of error indicator of canon inkjet printer. You need to specify how many times it blinks to get more help. Find how to identify error indicator here. Read more article there and you will get what I mean.
Regards,
Source:
Canon Inkjet Printer Forum
Nov 21, 2008 | Canon PIXMA iP1600 Printer
Canon PIXMA  iP1800 InkJet Photo Printer Logo
656 people viewed this question
old marine
old marine
