Question about Dryers
Ge prodigy takes way to long to dry an average load. This is a gas dryer and it is heating up.
  • 10,865 Answers
Chances are you have lint in the exhaust vent, exhaust pipe or the area out-of-doors.
Posted on Oct 06, 2009
Where is the igniter located on a ge profile dryer
You need to take the front off the dryer and it will be alongside the gas tube going inside the combustion chamber. The igniter is one of those curly wand types and has a quick disconnect connector on it and is secured with a couple of screws.
Here are some diagrams that might help you:
GE Gas Dryer Parts Model DPSR513GA
Good luck.
Oct 17, 2014 | GE Profile Prodigy DPSR513GA Dryer
Dryer stops during drying. Resumes in a few mintues. Can take 1.5 hours to dry an average load.
sound to me that you have a faulty motor or a loose connection. I suspect the motor.
Feb 07, 2011 | GE DPSE810GGWT Gas Dryer
Ge Profile Gas dryer - It takes 2 hour for a load of towels to dry - iis that normal?
If your dryer is not drying like it once did or if you just have not taken the time to give yourself a clean dryer in a long time then you need to do that. At least once a year the dryer cleaning should take place. Lint build up in the dryer duct is one of the main causes for your dryer to fail.
Here is the rest of this tip about Dryer Maintenance
heatman101
Nov 15, 2010 | GE Profile Prodigy DPSR513GA Dryer
Why is my dryer not produceingheat?
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 22, 2010 | GE Profile Prodigy DPSR513GA Dryer
GE DBSR453GB Gas Dryer doesn't dry on 1st cycle.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 30, 2010 | GE DBSR453GB Gas Dryer
Heats but does not have high heat. Takes about 80 min. to dry a average load of clothes. Dryer will heat up but does not get hot enough
have you checked to be sure you venting is clear leading to the outside of you home. obstructed venting will form your dryer to shut the heat off prematurely with then result in long dry times.
if it is a gass dryer, the the gas valve coils could be goind bad but check the venting first.
Mar 22, 2010 | KitchenAid Dryers
How do you take the front panel off of a GE Profile Prodigy Dryer DPSR483 GAWW? There is a squeeking noise inside.
Best off to call a reliable service company such as Sears. You have to remove the top and take 2 screws off that hold the front panel on but this is a gas appliance which requires a gas technician to legally work on it.
Feb 01, 2010 | GE Profile Prodigy DPSR513GA Dryer
My dryer is taking 2-3 cycles to dry clothes most of the time, but last night it did two loads the first try and then is back to 2-3 cycles today.
Remove the connecting vent material from the rear of the dryer. Run a regular cycle. If it dries normally,find and clean the blockage in the connecting vent.
Aug 26, 2009 | GE Profile Prodigy DPSR513GA Dryer
Ge dryer only dries small load
either your heating element or your limit switches are going out
Feb 04, 2009 | GE DHSR333EV Dryer
Dryers Logo
Top Dryers Experts
