Question about Samsung SPH-m510 Cell Phone
Need the code and instructions for connecting to bluetooth microphone device
    President:
  • 1,462 Answers
First you have to enable the Bluetooth to scanning mode,
To do this, press and hold the power button continously for 10 seconds, you may have a stable LED, this shows that its in discoverable mode, Now perform scanning and you may get your device and you can pair and make it work..The deafult pair code would be 0000 or 1234 in some case
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Posted on Oct 06, 2009
I need to know the bluetooth pairing code for sanyo M1
Well I know for sure the default pin for the M1 is indeed 0000. However I cannot tell you what the pin would be for your specific bluetooth dongle. If I where you I would try 0000, 1111, 2222 and so on
  • As with all Bluetooth headsets, the H700 needs to be paired with the device before it can be used, which is done in pairing mode. In pairing mode, the H700 makes a transmission so that Bluetooth-enabled devices can pick up the device and connect to the headset. Once connected, no other device can connect with the Bluetooth headset. To enter pairing mode on the H700, open the headset boom located near the microphone. After a few seconds the indicator light will turn purple. Once purple, the H700 is in pairing mode.
Searching for the Device With the M1
  • Once the H700 is in pairing mode, have the M1 search for Bluetooth devices. To do this, press "MENU/OK" and choose "Tools," "Bluetooth," "Add New" and "Search." A list of Bluetooth devices will show up on the screen. Highlight "Motorola H700" and press "MENU/OK." Choose "Add to Trusted," enter "0000" and press "MENU/OK." The devices are now connected and ready to be tested.
Testing the Devices
  • Once the devices are connected, test that both the phone and the headset are working properly together. First, place the headset in your ear. Dial a number on the phone and press "Send." If you can hear ringing, the devices are connected properly and ready for use.
    If the connection was not successful, repeat the previous steps and try again. Make sure the indicator light is glowing purple and is steady. If you have connected the headset to a previous device, make sure that device is turned off so as not to interfere with the connection procedure. Once the other device is off, close and reopen the boom to enter pairing mode.
Feb 16, 2012 | Sanyo Cell Phones
My new phone a Samsung Gusto is not pairing to my Plantronics 233 bluetooth? Is it compatible?
Hi, to be sure if the blue tooth wll be compactible with Samsung Gusto, you will need to use the below instructions first after trying out the instruction and still does not work,that means it's not compactible with it.
instruction:
Read the owners manual for your bluetooth device. You will need to find the code to pair your headset to your phone. This code is usually 0000 (those are zeroes) but verify before you proceed.
Enter your bluetooth option on your cell phone. These can be found in your menu under "bluetooth," "connections," "settings," or something similar.
Turn on your bluetooth headset and put it in pairing mode. Pairing mode means the bluetooth is ready to be found by your cell phone. To pair your headset, follow the owners manual for your specific bluetooth model.
Select "add device" or "search for new device" from your cell phone. Your cell phone will then search for your bluetooth. Once it is found, or discovered, you will need to enter the pairing code (most likely 0000, check your manual to verify).
Select "connect" to finalize the connection if the bluetooth headset didn't connect automatically after the pairing code was entered. Make a test call with your bluetooth in your ear to ensure it is connected properly.
Good luck..
Feb 23, 2011 | Plantronics Explorer 230 Bluetooth Headset
In recent days my headset (590A) has only been transmitting sound on the right ear via bluetooth connection, when I use the 3.5mm jack (connected to left ear) both ears work. Is there a fix for...
Your headset can be used as stereo headphones or a wireless microphone for a bluetooth enabled device like a cell phone or a computer. When you plug the headphones into a device with the 3.5mm jack the headset automatically turns into stereo headphones and disables the microphone(headphone mode). It sounds like whatever device your headset is connected to via bluetooth is using the wireless microphone protocol where sound only comes through the one speaker and the microphone is on(microphone mode). The bluetooth protocol settings of your device may have been changed accidentally. You will need to go into the bluettoth settings of your device you are using with your headset and change the protocol. If it is a cell phone you will need to go into the bluetooth settings in the settings menu. If it is a computer your can adjust the bluetooth settings in the control panel.
You can download the pdf file of your instruction manual for your headset here
I hope this was helpful and let me know if you have any other questions. Thanks for using FixYa
Oct 15, 2010 | Plantronics Pulsar 590A Wireless Headset
I tried to connect my emerson 227 bluetooth to my ps3. it tells me to press the start button and enter button on the device at the same time and wait until the screen changes.. well it never changes.. what...
Pairing the Headset with a Sony Playstation3 Entertainment System:
To pair your [EM-227] Bluetooth Headset with the Sony Playstation3 (PS3), go to the PS3 main menu, scroll to "Settings" and select.
Scroll to "Accessory Settings" and select.
Scroll to "Manage Bluetooth Devices" and select.
The menu will ask: "The Bluetooth device has not been registered. Do you want to register it?"
Select YES.
Put your [EM-227] Bluetooth Headset into discover mode (see X.XX of this manual for instructions on how to get the headset into discover mode).
Select "Start Scanning" from the PS3 menu.
Once the PS3 has discovered the [EM-227] Headset the screen will read "Select the Bluetooth device to register".
Select [EM-227].
The PS3 will ask for a passkey. Enter [0000] then press "OK".
Now press O (the PS3 circle button) to get back to the previous menu.
Scroll to "Audio Device Settings".
Change the "Input Device" to [EM-227].
Note: "Input Device" is the microphone, how others will hear you speak.
By default, the "Output Device" will now switch to [EM-227].
Note: "Output Device" is the audio, how you will hear the PS3 audio and others speaking.
If you would like to hear the PS3 audio and others speaking through your TV or Audio System, scroll to "Output Device" and switch to "System Default Device". If you would like to hear sound through the [EM-227] headset, then leave the "Output Device" setting on [EM-227].
To test your connection, speak into the headset and you will see the bars above the "Microphone Level" moving. If not, repeat the pairing process.
Press "OK" to confirm the new settings. You are now ready to use the [EM-227] Bluetooth Headset with your PS3 Entertainment System.
For further assistance with Bluetooth settings on your PS3 please refer to your PS3 instruction manual.
Oct 06, 2010 | Samsung WEP200 Headset
Lost instructions and forgotten how to pair with a mobile phone
How to connect or pair a Blueant Bluetooth handfree.
1. Switch off the Blueant:
i.e. push the microphone inside the Blueant.
2. Get you mobile in Bluetooth search mode to pair with a new device.
3a. Press and hold the red telephone symbol pushbutton on
the Blueant flat face for 8 seconds.
3b. at the same time switch Power On to the Blueant by pushing out
the microphone on the side of the blueant.
6. The Blueant will request your mobile device for a password.
7. Enter the password= 0000 , the devices now will be paired.
Mar 09, 2010 | Blueant Supertooth Light Bluetooth Speaker...
Owners manual needed for BTSVBC3
Thank you for visiting FixYa!
I don't have a user guide available, but here are the instructions to use your Supertooth.
Pairing with Phone
1. Turn off all devices (ST Light and Phone)
2. Turn on Phone
3. Go to Bluetooth menu on the phone (might be in Settings > connectivity)
4. Go to device list or paired devices (make sure bluetooth is turned on)
5. Delete any old profiles that are still in there.
6. Go to the Supertooth Light (BlueAnt)
7. Hold down the green button (send button)
8. while holding it down, open the microphone
9. the light should start to flash "red" and "blue" (you can release the green button)
10. go back to your phone, and go into either 'device list' menu or 'paired devices' menu on your phone.
11. click on either search, add or new devices. Function depends on different phones
12. when the phone has found the device, it should say 'ST Light BA V1'
13. select it, then enter passkey "0000"
14. If your phone ask for authorization or auto connect, just click "yes"
By now, you should be connected to your device. Always remember to close the microphone before you leave the car.
Otherwise, it will slowly drain the battery. If you want to reconnect, just simply open the microphone.
Make sure you turn off your phone once every 2 weeks to reset the phone memory. This will help give a better
performance and clearer sound.
If you found this information helpful, please give me a big thumbs-up when you rate my answer. Thank you.
Jan 12, 2010 | Blueant Supertooth Light Bluetooth...
Trying to connect my new handset with my Parot . when it starts conecting Parot says: Pair the device or something like that.How do i pair the device? I've done it before but I lost the manual.
This is a software issue, you need to update the parrot kit to the latest software. Im guessing you got a new nokia. Nokia changed the bluetooth coding so you can now block devices but it now causes issues with other bluetooth devices.
Oct 10, 2009 | Parrot 3000 Evolution Advanced Bluetooth...
I just bought a set on ebay but there was no software or instructions, how do i get them to work
I have this pair of head phones and I've connected them to my computer which uses vista. What I did was connect them to the computer through pairing. If you get a message asking for a pin, you just type 0000 for the code and you should get it installed just fine.
After this is done, you go to the microphone symbol in the bottom left toolbar and right click, and go to playback devices. From here you should should see a symbol that says "Speakers" and right underneath it should say "Bluetooth Audio device". Click this one, set to default and click ok. The sound from the computer should go to the headphones at this point.
As for getting the built-in microphone to work with the computer, I'm still working on that issue myself
Jul 02, 2009 | Insignia Bluetooth Wireless...
Windows Vista wont connect to these headphones
Try going to control panel->sounds->make the hands free audio the default.
Jun 17, 2008 | Insignia Bluetooth Wireless...
Samsung SPH-m510 Cell Phone Logo
44 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Fotis Papastamatiou
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
