Question about Samsung RS265LABP Side by Side Refrigerator
The freezer door was parcially open all day and now the freezer side is not cooling at all. when I got home the temp meter at the frezer door was flashing at -4 degrees. Since I unplugged and wait 10 minutes is been at 53 degrees for 45 minutes without change.
  • 41 Answers
It takes 24-48 hours for the temperature to be as cold as it was before you left the door open. Leave it closed and check back a day or two later.
Posted on Oct 06, 2009
Kenmore side by side refrigerator model 596.50009100 not cooling.
I would make sure they fan on the bottom that cools the condenser is turning easy way to test is. Put a fan in front of the fridge blowing under it if it starts cooling that is now working right
Nov 12, 2013 | Refrigerators
Vent flows cold air through frezer to right side when door open, but no flow when freezer door is closed. Temp drop in fridge side. Vent is cleared of ice build up.
Good day,
There are 2 vents. The one on the top to allow air from the freezer into the fridge. There is a second one, a return on the bottom left that allows the air to return to the freezer.
The return vent is the one that is blocked. (iced up).
On your model, it is very difficult to melt the ice out especially using heat due to all the plastic and foam.
Although ugly, it is best to unplug the machine, and leaving both doors open fo 24 hours.
Sep 22, 2010 | Whirlpool Refrigerators
The Refrigerators inside Water Dispenser not Disapensing
Lets try this first. Have someone with a voltage meter unplug the two wires on the side of the dual water control valve for water dispenser on rear of your refrigerator and place the red and black probes from meter into the female end of the dispenser side of plug. Then while someone presses the dispense water control have the other person read the voltage. It should read the same voltage as home voltage when pressed. Us care not to touch probe ends at time of testing. Please tell me your results. I don't think the door open had anything to do with this. Yes leaving a freezer door open for hours does confuse the refrigerators memory and produces heavy ice in strange places. Unpluging and replugging will resolve that. I think the water control valve began to fail by becoming weak and finally failed, Sea Breeze
Apr 12, 2010 | Maytag MFD2561HE Stainless Steel Bottom...
Stop cooling every 5 days I defrost manual GSS201ETCBB
Does the freezer / fridge door close good? Check the hinges. Also check the seal and the amount of food stuff you may have close to the door. If you have an ice maker make sure you have it secured inside the freezer section.
It sounds like something is keeping the freezer door open or from closing good.
Mar 20, 2010 | GE GSS20IEP Side by Side Refrigerator
FREZER NOT FEEZING SOLID
you must defrost it. and it will work again about 3 hrs with fan blowing in the open door .. the cooling coils are froze over with ice .. kool fix
Jan 31, 2010 | Maytag MSD2651 HE Side by Side...
Fridge side is not cooling or very low
. Make sure it's opening and closing when you adjust the fridge temp ..If it's not it could be the linkage or the control. You probably can do the repair. post your model number to find diagrams of parts to check.
Jul 08, 2009 | Kenmore 5553 / 655532 / 55534 / 55539 Side...
Water leaks out of freezer once or twice per day
is there water frozen on the frezer floor.if yes your defrost drain is froze over.it only happens a few times a day because happening when its going into defrost,the water melts on the frezer evaporater then should go in the drain.if blocked it then runs on floor.you could turn of your refer for 8 hours or so.or get to the bottom of frezer behind back frezer panel[remove]and use a hair dryer to thaw drain use a weed eater line with a knott on an end to push thru and pull out the other side.the knott would clean any stuff in the drain line.ps watch out for water and electricty.i hope this helps God bless,tom
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Refrigerator not getting any air, (it is warm), freezer seems ok
so you mean the vents in the refer/frezer sections? yes ok there is a fan in the frezer section that moves the air thru out the box.its called the evaporator fan.you should hear a vissssss sound when you open the doors.some boxes you have to push the door switch closed with finger because fan goes off win door open.test fan with volt meter,should get 110 volts[may have to push that door switch in when testing]if voltage and not turning get new fan.hope that helps God bless ,tom
Jan 05, 2009 | Kenmore 50522 / 50524 Side by Side...
Kenmore sidebyside
Hi! There,,,If you want help, one needs to explain the problem.. A refrig is quite simple in opertion, with time used experience. For a side by side the freezer is cooled with the same system as the refrigerator cooling system. One and only. Freezer works, do you mean it is provining design temperature of some -10 deg F??? Do you have a by-pass duct between the the two. yes, then open it up more, disconnect motor is auto, and prop vent open, set refrig temp to a low temp say 40 deg F. are we cooling??? Post your condition, if you want further info Regards,,,fmauka
Sep 05, 2007 | Kenmore 74822 / 74824 Top Freezer...
Samsung RS265LABP Side by Side Refrigerator Logo
194 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
