Question about Sony Handycam DCR-TRV103 Digital Camcorder
No playback on DCR-TRV103
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my computer and I got no picture. I
  • 5 more comments
  • Anonymous Feb 03, 2008
    No playback, no rewind, only fast forward
  • Anonymous Mar 09, 2008
    No playback on DCR-TRV103. Will fast forward, rewind, etc. Will not play. Get blank blue screen.
  • Anonymous Mar 30, 2008
    Same thing happened to me 3/29/2008. worked perfect for years. Now I just get a blue screen when I try to playback a tape. can it be fixed??
  • mejis May 22, 2008
    same problem with no playback and blue screen.  I think it has to do with the VTR thinking that the digital8 tape I inserted is Hi8.  Once I fixed this by removing batteries for 10 minutes, but then it reverted back and the battery fix doesn't work.  I also tried going to menu to make sure the PB Mode was set to auto, but this didn't work either.
  • becktra Oct 31, 2008
    I have the same problem with no playback and a blue screen, etc. When I was recording before this happened, I got a message to use a head cleaner. I got it to work long enough to record by taking the tape out and putting it back in. It played for awhile but now I have the blue screen. I used the cleaner with no luck. Any suggestions?
  • Anonymous Dec 13, 2008
    Same problem with me :(
  • Anonymous Feb 09, 2009
    I have the sa me problem. With TVR460. Blue screen and 0 meter. Same excat proble
In playback mode the lCD displays the battery time, hi8 symbol and the tape counter. all the functions work the tape will play, rewind, fast forward. The screen stays blank on playback and the tape counter stays at 0:00:00 eventhough I can see the tape turning. I also hooke the camera to my tv and I got no picture.
Posted on Mar 09, 2008
Play back pre recorded HI8 tapes on my TRV130?
The Sony DCR-TRV130 is a D8 digital camcorder which is not compatible with Hi8 camcorders.
You need to have an Hi8 camcorder or DCR-TRV103 or similar camcorders that backward compatible with Hi8 camcorders.
Dec 31, 2014 | Sony Handycam DCR-TRV130 Digital Camcorder
Can I use Hi8/Digital8 NTSC tapes in my DCR_TRV250E?If so would I be able to playback recorded tapes on the UK televisions?.
DCR-TRV250E is a PAL version camera of the Digital8 format.
Yes you can use Hi8/Digital8 NTSC tapes. The camera will record a PAL digital picture on the tapes which means that you can play back the tapes in PAL and therefore you will be able to playback recorded tapes on UK televisions because they are also of the PAL format.
Oct 10, 2009 | Sony Handycam DCR-TRV250E Digital...
Having problem with sound playback from TDK Metal 8 tapes
I don't remember where I read it, but somewhere like this site.
Just as you start the play back, give your camera a bump with the heal of your hand. This has worked a couple times, and the issue seems to be with just the metal tapes. My husband was a bit appalled until it worked. It might not solve the issue long term, but I was wanting to recover baby footage so I wanted to just get it done.
May 12, 2009 | Sony Handycam DCR-TRV103 Digital Camcorder
Hi8 Playback Problem
Clean the tape heads and see if that makes a difference.  If that doesn't work, it could be the tape motor is going out.  Thats typical behavior when that happens.
Oct 07, 2008 | Sony Handycam DCR-TRV350 Digital Camcorder
Hi8 Playback Compatibility with Digital* Camcorders
I believe all Sony model DCR-TRV2XX and 3XX would play Hi 8 and ST8
Such as DCR-TRV265, DCR-TRV285 DCR-TRV340, DCR-TRV355
I hope that give you some ideas
Aug 01, 2008 | Sony Handycam DCR-TRV510 Digital Camcorder
Blue screen on playback on Sony DCR-HC40
You can see an image in a camcorder viewfinder any time the camera's actually on in record mode, whether or not the camcorder is actually recording. So that's no guarantee.
Assuming the obvious (you have the right kind of tapes, they're not in write-protect mode, you rewind before playing, etc). I recommend that you borrow a tape of the same kind from someone else and check it on playback in your camcorder. This should lead you know understand if you have a playback problem or a recording problem.
Jan 20, 2008 | Video Cameras
Imovie imports Hi8 tape but not plain 8 tapes
What it is, is the standard 8mm tapes are not digital, and therefore won't import into imovie, unless you have the 8mm to Hi8 option enabled in playback mode, by setting it in the menu, under playback settings.
Dec 29, 2007 | Sony Handycam DCR-TRV103 Digital Camcorder
Camcorder won't playback most Hi8 tapes
may be your camera not design to play the analog tape...there are some model that can playback a analog tape...i think your camera is for digital playback only.... check your user manual
Aug 11, 2007 | Sony DCR-TRV285E Digital-8 Digital...
Old tapes don't play
I have the same problems. Makes me mad. I have a years worth of tapes that I can no longer view. My dog at peed on my old camera which was a digital one.
Mar 03, 2007 | Sony Hi8 CCD-TRV138 Camcorder
No picture during playback on LCD or TV from my Sony DCR-TRV255E
Just use good quality Video Head Cleaning Cassette. Video head is dirty/ clogged.
Feb 17, 2007 | Sony Handycam DCR-TRV255 Digital Camcorder
Sony Handycam DCR-TRV103 Digital Camcorder Logo
893 people viewed this question
Top Sony Video Cameras Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
