Question about Kenmore Vacuums
We have a cannister model 116.23613300......all of a sudden there is no suctiion....it will only blow.....no suction at all.....plz update with any suggestions....thx
4 Suggested Answers
SOURCE: model 116 hose clog?
http://geeksquad.fixya.com/ThreadView.aspx?prdid=109459&thid=699656
Model 116 hose clog?
Posted by rfrazelle on Jun 23, 2008
My old canister model 116 followed with numbers 2839580 marked Kenmore 3.9 with power-mate, worked fine until the bag got overly full. I have changed the bag, cleaned the filter, and removed a nasty hair/fur/dust clog :-p from the lower metal tube of the power mate. It now has very weak suction and won't pick up anything. I suspect a clog in the grey plastic flexible tubing attached to the canister but cannot get it apart. Advice?
RJ
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Kenmore 22313 Bagged Canister Vacuum. The best way to find a clog in an electric hose is to use a steel ball or a large marble to place inside the hose and to let it so threw as far as it can to determine where the hose clog is. Once you have determined where the hose clog is then you can use a small end of a broom handle of take an old wire coat hanger and place a hook on the end and try to pull the clog out of the electric hose – the electric hose is very expensive so try not to damage the hose in any way, shape or form. Or another way is that id you have another canister vacuum you can try to pull the clog apart by using two vacuums turned on and running. If you are successful then run the round marble or steel ball thru the hose again and the clog should be cleared.
http://www.sears.com/ Customer Service 1-800-4-MY-HOME 1-800-469-4663
Thanks, Don the Vac Man
Go Ahead. Use Us.
Posted on Jun 24, 2008
Dysonteam
  • 167 Answers
SOURCE: my dyson slim dc18 has suction in hose attachment
Hi its Darran at Dyson.
It would be worth checking that the brush bar is turning when the machine is in the vacuuming position. If it is not turning, please press the re-set switch located on the cleanerhead.
If this starts the brush bar turning but does not solve the problem, please check the cleanerhead for blockages and remobve any threads or hair trapped around the brush bar.
Shoudl you need any further help or advice, please contact our Helpline on 1866MYDYSON.
Kind regards
Darran
Dyson Customer Service
Posted on Apr 19, 2010
  • 3 Answers
SOURCE: I have a kenmore vacuum,
If the squeal is coming from the canister portion of the machine, then you most likely have a fairly serious motor/fan problem. There are no moving parts on that machine other than the fan/motor assembly in the canister.
A local service center could confirm that. You can try to get a free quote if they offer such a service. Many may charge a fee even for diagnostic work.
If the noise is coming from the power-head, then there are multiple possibilities ranging from bad brushroller bearings to failing power-head motor.
Posted on Apr 04, 2011
I have a hoover Dust Manager DM6200. actually it is my friend's. She said it wasn't working well, so I took a look. It wasn't picking up, and seemed to be spreading dirt in fact. I emptied...
Hey Julie,
Hopefully we will get this solved together.
To me, this problem sounds like either the filters are choked up and cannot breathe, OR.... the bagless cannister is not quite sitting in the machine properly.
Honestly, I am more leaning towards the cannister not quite in properly, that is assuming that everything is out of the suction hose.
Start with the process of elimination. Remove and clean the filters with a paint brush or other brush. Get as much dirt and debris off of them as you can and replace them into the machine.
Turn on the machine, and using only the hose attachment, feel if the suction is there. If not, try a re-alignment of the cannister and check the hose. a small coin or marble running through the hose will tell you if there is still a blockage in there.
Where the attachment hose connects to the bottom of the machine could also be blocked up as well. This will also give the same effect of the dirt blowing out the bottom of the machine.
Lastly, it is also quite possible that the belt has stretched or worn out. This too will contribute to it not picking up.
Let me know if this helps, and we will go from there.
Good luck,
Mark
Jan 24, 2012 | Kirby Ultimate G Bagged Upright Vacuum
Hoover dm6200 blowing air
check your suction hose again, follow it to where it goes into the body of the machine. I assume this will be near where the bagless cannister is. Remove the bagless cannister and look up inside to where the attachment hose should come into the cannister. I believe you are still blocked up there. using a butter knife or something along those lines should free up the blockage.
Also, if that is all clear, try re-adjusting the dirt cannister as it may not be on properly to create your suction flow through the hose.
Good luck and let me know if I can help further.
Jan 24, 2012 | Hoover Vacuums
Suction has diminished since I purchased it a year ago. Hose is not blocked, Cannister is empty, and plastic filter above cannister is clean. What could be the problem?
Three possibilities I can think of:
1. Leak/holes in the hose.
2. The fan blade are worn down or broken. The more they're worn down, the less suction.
3. The motor itself is dirty and/or wearing out.
Any one of those problem would call for a replacement of the part involved, or the vacuum itself. It could also be a combination of any of them.
Dec 14, 2010 | Bissell Versus Bare Floor Vacuum
My dyson slim dc18 has suction in hose attachment but no suction in floor attachment. Tried to clear any obstruction by running clothes hanger in rectangular opening that empties into cannister and also...
Kind regards
Darran
Apr 19, 2010 | Sharper Image Dyson Slim DC18 All Floors...
Poor suction (new bag, clean filter, clear hose)
check the impeller on the moter it may be missing a fin or two (question does it make any unusual noise or vibration ?)
May 01, 2009 | Vacuums
No suction, again.
There is a blockage somewhere and its most probably jammed between the main dust channel between the beater bar and the bottom hose inspection. Remove the sole plate to see if anything is still stuck, check the beater bar as well and see if there is anything obstructing at the main hose removal point.
Mar 12, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
My central kenmore vacuum wont suction
Hello hdd85,
I think you answered your own question when you verified that all the vacuum outlets have vacuum on them and then after you hook up tyhe vac hose, you fail to get vacuum at the other end. I would say that based on your problem description, you have an obstruction in the hose. You may have afriend with an air compressor that you can try forcing air in one end to free up the clog but if that doesn't work, do you know anyone with a wet/dry utility vac that you can try using the vacuum or exaust side to free the hose up ? Lastly, if you know an electrician, they normally have 'snakes' used to fish wires thru wall cavities... If careful, that might get the clog out.. Hope that gives you soem ideas on how to resolve,,,,
Regards,
Rick
Jan 26, 2009 | Vacuums
No suction.
Mine is doing the same thing, the hose picks up things fine but the rollers turn and instead of picking up it is blowing air out????
Nov 29, 2008 | Eureka WhirlWind 4381 Upright Vacuum
Central Vaccum - Kenmore Model No 34330
Is there suction where the pipe hooks to the cannister? If so, then are all of the outlets without suction? Maybe the hose is plugged. If the hose is ok, and there is suction at the cannister, then **** up a small **** of paper, one for each room outlet, have a number on each piece of paper, Which ever one doesn't ,ake it thru to the cannasiter is the outlet that is plugged. You can use a plumbers snake to clean out a clogged outlet or even a clogged hose.
If the motors are running and sound ok, then there has to be suction at the outlet on the cannister. If the filter bag is old, it may be best to replace it with a new one.
Jul 19, 2008 | Vacuums
Vacuums Logo
61 people viewed this question
Top Kenmore Vacuums Experts
Are you a Kenmore Vacuum Expert? Answer questions, earn points and help others
