Question about The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac
12(q plus q over 3 plus q over 4 minus q over 6)
  • 292 Answers
Hi pink_bubbles
Have a look at this solution
your question can be rewritten as
12 times (12q/12 + 4q/12 + 3q/12 -2q/12)
= 12 times of (12q+4q+3q-2q)/12
= 12 times 17q/12
=17q
If this makes you happy please give a rating
luciana44
Posted on Oct 08, 2009
    President:
  • 1,901 Answers
OK It is a little difficult trying to figure out the fractions you are trying to describe. Are there 3 fractions within the ( ) ? One with a denominator of 3, one with a denominator of 4, and one with a denominator of 6?
If so, the answer is 9q.
You must change the fractions within the ( ) to a common denominator, which would be 12. That would be 8q+3q-2q all over 12. Since it is all being multiplied by 12 outside the brackets, you just cancel the 12 outside and the 12 denominator inside which leaves the 8q+3q-2q which equals 11q-2q which equals 9q.
Thanks for using Fixya.
Posted on Oct 06, 2009
How do I do feet and inches calculations on the Casio FX-115ES Plus? For example, how can I do calculations like 10'-3" + 5'-4" + 11'-11" without having to convert the inches to feet?
You can combine all the feet together 10+5+11=26 feet
Combine all the inches together -3-4-11=-18 inches=-2 ft + 6 inches
26 ft -2ft +6 inches =24 ft +6 in=24.5 ft
You can also multiply each inch -value by 1/12
10-3/12+5-4/12+11-11/12=10+5+11 -(3+4+11)/12=26-18/12, continue
Jul 22, 2014 | Casio fx-115ES Plus Scientific Calculator
Ouku single din no sound from rca cables
Sorry I did not use the video out RCA cables. My audio RCA cables worked fine... I ran them to my JBL amplifier through a conversion adapter. I did not run it direct to the amp.. I used Metra TYTO-01 03-08 Toyota Vehicles Harness for JBL SYS (Ebay item 160560648718) and it worked great.
Here is the wiring color coding that I found online:
Code on stereo for steering wheel is 0000
2011 Toyota Camry Car Audio Installation Diagram
F6 Pins:
1.Light Green (LG) Front Right (FR) plus (+) speakers source
2.Pink (P) Front Left (FL) plus (+) speakers
3.Grey (GR) Accessory power [switched on with the ignition switch] +12v
4.Light Blue with Yellow Stripe (L-Y) always +12v [radio memory]
5.Light Blue (L) Front Right (FR) minus (-) speakers return
6.Violet (V) Front Left (FR) minus (-) speakers return
7.Brown (BR) Ground (GND) radio ground
8.Orange (O) Antenna Amplifier (ANT) power source
9. No Connection
10.Green (G) Night Lighting [+12 when the taillights are turned on]
F7 Pins:
1.Red (R) Rear Right (RR) plus (+) speakers source
2.Black (B) Rear Left (RL) plus (+) speakers source
3.White (W) Rear Right (RR) minus (-) speakers return
4.No Connection
5.White Black (W-B) Lighting Intensity [Pull down circuit, voltage level drops {Bright Dash Lights}or raises {dim Dash Lights} Caution with this one, DO NOT CONNECT DIRECTLY TO +12 VOLTS, you will mess up your instrument panel cluster.
6.Yellow (Y) Rear Left (RL) minus (-) speakers return
F8 Pins:
1.No Connection
2.No Connection
3.Violet (V) Speed Pulse Connection (SPD) [Pulses from the speed sensors applied here. This is for the automatic sound level system. The volume raises when the speed is above a specified level, if enabled.]
4.No Connection
5.No Connection
6.Pink (P) Steering Wheel (Switch) Ground (SWG)[common]
7.Orange (O) Steering Wheel (Switch Group) one (SW1) [source for Seek+, Seek-, Volume+, & Volume-]
8.Yellow (Y) Steering Wheel (Switch Group) two (SW2) [source for Mode, (if equipped On Hook, Off Hook & Voice)
9.No Connection
10.No Connection
11.No Connection
12.No Connection
13.No Connection
14.No Connection
15.Orange (O) Auxiliary Right Input (ARI)
16.Brown (BR ) Auxiliary Shield Ground (ASGN)
17.Red (R) Auxiliary Left Input (ALI)
18.No Connection
19.Green (G) Auxiliary Input [Sense](AUXI)
20.No Connection
Car Radio Battery Constant 12V+ Wire: Blue/Yellow
Car Radio Accessory Switched 12V+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: N/A
Car Radio Dimmer Wire: N/A
Car Radio Antenna Trigger Wire: N/A
Car Radio Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Tweeter Size: 3 1/2? Tweeters
Car Audio Front Tweeter Depth: 2?
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Violet
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Blue
Left Rear Speaker Positive Wire (+): Black
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Red
Right Rear Speaker Negative Wire (-): White
Apr 02, 2014 | Crown Ouku 7" Car Dvd Player
2x minus x cube plus 5x minus 2
Your question is interpreted in following way as it is not clear as cube of what & minus of what?
2x minus x cube plus 5 x minus 2
Solution 1:
= 2 x -1 x cube plus 5 x minus 2
= -2x cube plus 5 x minus 2
= cube of -2 plus 5 x minus 2
= (-8 +5) x -2
= -3 x -2
= 6
Solution2:
=2x-1x cube of +5 x -2
= -2 x 125 x -2
= 500
I think logically the solution 2 must be right. How you interpret the question is important.
sonsunny
Jul 04, 2011 | Acer Computers & Internet
Equation of line between to points
Example: Equation of the line through (1,5) and (3,6)
Calculate the slope (gradient) of the line as a=(y2-y1)/(x2-x1) where y2=6, y1=5, x2=3, and x1=1. You should get a=(6-5)/(3-1)=1/2
The equation is y=(1/2)x PLUS b, where b is not known yet.
To find b, substitute the coordinates of one of the points in the equation. Let us do it for (3,6).
The point (3,6) lies on the line, so 6=3/2 PLUS b.
Solve for b: 6 MINUS 3/2=b, or b=9/2=4.5
Equation is thus y=(x/2) PLUS 9/2 =(x PLUS 9)/2
Jan 10, 2011 | Texas Instruments TI-84 Plus Calculator
Model 31981B Replaced AAA battery's and now it is 3 hours behind
PROGRAM MENU: b> TIME ZONE: Use a pencil or paperclip togently press and release the TIME ZONE button one time. Press and release the PLUS button to choosefrom: PST= Pacific Time MST= Mountain Time CST= Central Time EST= Eastern Time Press and release the SET button to return to a normaldisplay. DAYLIGHT SAVING INDICATOR: The DST indicator isdefaulted to the ON position. If your area does not observe DST please removethe battery cover on the back of the station and move the DST switch to the OFFposition. SET CALENDAR, TIME, 12/24HR & F/C: Press and release the SET button once toenter the program menu. NOTE:Holding a button will move the digits faster. YEAR: The Year will be flashing. Use the PLUS or MINUSbutton to set the Year. Press and release the SET button one time. MONTH/DATE: The Month and Date will beflashing. Use the PLUS or MINUS button to set the Month and Date. Press andrelease the SET button one time. HOUR/MINUTES: The Hour and Minutes will beflashing. Use the PLUS or MINUS button to set the Hour and Minutes. Press andrelease the SET button one time. 12/24-HOUR TIME: 12Hr will be flashing. Use thePLUS or MINUS button to switch to 24-Hour time. Press and release the SETbutton one time. FAHRENHEIT/CELSIUS: The Temperature will beflashing. Use the PLUS or MINUS button to switch from F to C.
Dec 06, 2010 | Equity Time USA Sky Scan 44100 Clock Radio
Find an equation of the line containing the given pair of points (1,5)and(3,6)
Oct 20, 2010 | Texas Instruments TI-84 Plus Calculator
I have a Coleman Powermate portable gas 110 volt generator that engine runs but will not produce power. How do I recharge field?
Check where is the plus and minus of the field.
Take a 12 V battery. Connect the minus to the field minus.
Start the generator and just for a second connect the plus and disconnect.
The voltage should build up. If not check the AVR.
May 21, 2010 | Coleman Electrical Supplies
Err:syntax when I try to graph with ''-'' on ti-84 plus
The calculator has two minus signs
  1. The regular MINUS sign which is used with the subtraction operation. This operation is binary, requiring two operands (two terms). In a-b, a and be are the operands (they very specific names, but I will skip this detail).
  2. The negation or change sign. This operation is called unary, requiring one operand. -a means take the negative of the number a.
These are the technicalities, in which you may not be interested. On calculators, the two operations are implemented differently, with two signs, the regular minus sign -- , and the change sign (-) usually smaller in size than the regular -- sign and raised above the main line.
Examples. Let (-) be the negation and -- the regular minus.
  • If you enter (-) 12 the TI84Plus accepts it and calculates the negative of 12.
  • If you enter 12 (-) 13 the TI protests with a syntax error
  • If you enter 12 ( (-) 13) the calculator interprets it as 12* (-13) and calculates -156.
  • If you enter --12, the calculator displays Ans--12, where Ans is the last result calculated. If Ans happens to be 0, the new result is obviously the one you are expecting. But if Ans holds a non zero value, this is incorrect.
Suppose you have to calculate X^(-2)*X^(-1/3)
You can enter it exactly as it is written above. In this case, you must use the change sign (-) in both factors.
You can also decide to use the power rules and enter the expression as X^( -2 --1/3). In this case the first minus is the negation and the second is the regular minus.
I could go on with a few more examples, but that will take us away from your present concern.
In short.
  1. If the minus sign is the leftmost (first) symbol in your function (after the Y1=) you should use the negation. Any subsequent minus should be the regular minus --
  2. If the minus sign is the first symbol in an exponent, you must use the negation. Any subsequent minus in the expression of an exponent should be the regular minus --
I hope it did not bore you death with details you do not care to know about. I do hope that it will help you prevent this type of syntax errors.
Do not forget to rate the solution
Dec 13, 2009 | Texas Instruments TI-84 Plus Silver...
In dire need of timing specs for a 2003 6 speed 2.7 Tiburon so we can get my son back his car. Please help. Thanks Lisa
the timing is 12 degrees before top dead center at curb idle plus or minus 5 degrees.hope this helps Ray
Nov 12, 2009 | 2003 Hyundai Tiburon
Using JBL 4410 3-Way crossover, trying to use PG 12" Dual 4-ohm
ok, connect the amp positive to the positive end of one sub coil, take the negative of that coil, and run it to the positive of the second sub coil, then run the negative out of the second sub coil to the negative of the amp.
Mar 29, 2009 | Phoenix Gold Octane-R 15.0:1 Car Audio...
The Learning Company Achieve! Math & Science Grades 1-3 (381933) for PC, Mac Logo
303 people viewed this question
Top The Learning Company Computers & Internet Experts
k24674
Stitch85
Level 1 Expert
Are you a The Learning Company Computer and Internet Expert? Answer questions, earn points and help others
