Question about JBL CREATURE II Computer Speakers
Volume control does not work. Neither volume button seems to work.All LEDs functioning. Has worked in the past.
  • chucktraver Oct 06, 2009
    Tried your suggestion. Replugged all cables. I can not press either button. Buttons are stiff. Will not depress.
    I am using an IMac running OSX 10.6.1. Need further suggestions.
  • chucktraver Oct 07, 2009
    Plugged the speaker cable to wrong jack on back of computer. Plugged speaker into input jack instead of output jack.
    Sorry form mistake!
    Regards,
    Chuck Traver
    President:
  • 1,462 Answers
Try to simply disconnect and reconnect the right channel cable to the sub woofer..
If it doesnt work, try removing all the cable and reconnecting,but use the part of your finger behind the knuckle and it will work..
This usually happens in most of the JBL Creature II reciever..
Please leave me comment, if this solution doesnt work or if you need further assistance
RNJ VINODKUMAR
Posted on Oct 06, 2009
  • Vinod Kumar
    Vinod Kumar Oct 06, 2009
    Do you get small volume from your speaker, ot fully muted..Have you tried adjusting the volume in the system..What response do you get..Please leave me comment, will help you furthur
If a warning light indicates the CPU is not functioning, does that mean I have to get a new processor?
Yes! judging by all the cascade break downs, I would suggest replacing the motherboard, HP has a history with motherboard issues.
Mar 29, 2012 | HP Computers & Internet
Samsung HL-T6187S SOUND DROPPING TO 0? By itself
If you can get at the controls again----undo or unsolder the micro switch for volume down! Remove it and see if set works.
A no brainer in that if that switch is bad and vol down still displays nothing else would work
Feb 21, 2012 | Samsung HL-T6187S Television
My remoute control joust change the volume and anyother keys doesn't work.
The remote's volume keys are "punch-thru" keys, meaning they'll work for the TV for which the
remote is programmed no matter what mode the remote is in. It seems your remote is not
in "TV mode," but the punch-thru keys (volume UP/DOWN) are working.
The Solution: change the remote from "AUX mode" or "DVD Mode" back to "TV mode", by
pressing the "TV" button at the top of the remote.
Either that, or your remote keypad has failed with the exception of the Volume UP/DOWN keys....
Also, your batteries may be failing, since it takes a tiny amount of energy to light
the IR (infra-red) LEDs at the front of the remote to change the volume.
Is your remote a "multi-function" remote?
Could help more if you could post your Samsung remote model number, since
www.samsungparts.com lists 37 pages of TV remotes (at 10 models per page).
Jul 02, 2011 | Samsung TV Remote Control
Mixer volume LED's do not work
a circuit controls the LED meter. i dont think the LEDs are faulty. the LEDs are connected to this circuit (IC). changing the LEDs wont work.
Mar 14, 2010 | Audio Players & Recorders
Vur9 remote only controls the volume and nothing else, cant change channels or anything any suggestions?
Press the TV button on the lower right (not the upper right) to tell the remote to control the TV.
The upper buttons are the Input Selector buttons. The lower buttons are the Device Control Selector buttons.
I had this same problem until this dawned on me.
Apr 20, 2009 | Vizio VO47L 47 in. LCD TV
880 universal remote volume button broke. little rubber botton on inside that pushes the volume button on inside broken.face plate cracked and arrow button on left right underneath face broken and missing...
My volume button also broke (actually, the VOLUME UP function stopped working). Rather than trying to get the remote fixed, I found a different solution...
I reprogrammed the + key (bottom left of the remote) to be my new Volume UP function. You can do this by going to any of the activities you've already defined, and adding a custom button to the activity.
Choose the + button (it will probably not have an existing function), and tell it to use the Volume Up function of the component you normally use for volume. In my case, it was the Home Theater Receiver.
I hope that helps.
Mar 02, 2009 | Logitech Harmony 880 Universal Remote...
Sanyo DS32224 tv remote
It sounds as if you have inadvertently selected the 'Aux' function. Pressing the 'TV' button (should be close to the Aux and others) should restore full control.
Since the volume generally means 'TV Volume,' this function often stays effective but the other controls will not respond, including 'Power.'
This happens to us all the time with our Dish remote which also has 4 basic functions.
Apr 26, 2008 | Sanyo DS32224 TV
Volume control stopped working
Take the warranty and the MP3 and go to the shop from where you bought. They will repair for you.
Sep 02, 2007 | SanDisk Sansa m240 MP3 Player
JBL CREATURE II Computer Speakers Logo
112 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
