Question about Vacuums
Hello, I have an Electrolux vacuum. In desperation, I vacuumed up some water and my machine stopped. I am hesitant to take the machine to a repair place for fear that if it is a simple repair they will not be honest. Can anyone give me advice on whether this is a problem that requires a new motor or major repair? Thank you!
  • matkabob Oct 07, 2009
    Thank you very much for your help! This gives me a good idea of the extent of the problem!! :]
  • Chemist1961 May 11, 2010
    In most cases, you will severely damage the motor with water. A wet dry pickup vac would have a float WHICH RISES UP TO BLOCK THE WATER FROM ENTERING THE MOTOR. At a minimum you will need an overhaul and new motor bearings, but the overhaul will include dismantling the entire motor to allow it to dry and prevent mildew.Over an hour in labor with wet dirty parts some of which will begin to rust together very soon Most shops are NOT motor rebuilders so the simple fix is a drop in replacement motor. Figure on at least $125 depending on age and model of the vac
    President:
  • 389 Answers
Although it's never to be recommended, it is sometimes possible to vacuum up a little water without doing significant damage. However, the fact that your machine then stopped suggests that the electrics got wet. That may or may not have caused expensive damage (probably not), but it is essential that the machine be thoroughly dried out before further attempts to use it. That will involve dismantling it, and my guess is that the labour involved will be the most costly part of the job. A competent vacuum engineer should be able to complete the job in about an hour.
Good luck! Please remember to rate this response - thank you.
Posted on Oct 07, 2009
Where do I get Electrolux motor in south Africa?
A local rewind or motor repair might prove more convenient and perhaps cheaper but Electrolux service is available in South Africa
Electrolux South Africa ' Home Appliances and Household Appliances
www.electrolux.co.za/
Welcome to Electrolux South Africa. Discover our range of ... Enter your postcode, town or city to find your nearest authorised dealer. Translation missing for ...
May 03, 2016 | Electrolux Vacuums
My electrolux versatility vacuum doesn't have much suction
Hello, this is Ava with Think Crucial.
If you are experience less or no suction of you vacuum, most of the time there is a blockage that clogs up your unit resulting to this. Turn off your vacuum first and unplug the machine from the power before doing any troubleshooting with your vacuum. Remove the attachment hose and check inside the hose and the openings where the hose attaches for any blockages. You may refer to your manual below for troubleshooting solutions:
Electrolux EL8502 User Manual
You can purchase a wide variety of high quality Electrolux replacement parts for your Electrolux vacuum direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
https://www.thinkcrucial.com/search?type=product&q=electrolux
I hope this was helpful.
Ava B.
Think Crucial Customer Care
http://www.thinkcrucial.com/
Jun 18, 2014 | Bissell 9200 Upright Vacuum
I need the Manual for #2100 Electroluks vacc
Service manuals for the Electrolux vacuums, including the accessories, are only available to the franchise owners and service techs.
Also, having said that, I don't recommend fixing the switch yourself. Replacing the switch involves disassembly of the canister, which is a bit complicated. Putting it back together correctly, without crimping wires. even more so.
I used to be an Electrolux service manager and have seen vacs brought in in pieces. Customers had succeeded in dismantling the machine, but were unable to reassemble it. Or had cracked or broken a piece. This makes the repair more expensive.
Or machines were brought it that had been reassembled incorrectly and wouldn't work. Or worse had shorted out due to crimped or incorrect wiring.
I strongly suggest taking the vacuum to a repair shop that is familiar with the older Electrolux vacuums, in this case the plastic models.
Mar 06, 2014 | Electrolux hose 2100 series diplomat
Electrolux L E Canister stopped working
It sounds like it may be a bad control valve assembly, which is found inside the machine. This part is controlled by the dial on the top of the vacuum and does wear out eventually.
If you've got a clean bag in the vacuum, this is the most likely cause. There may be other things that could cause the problem.
This is a repair that needs to be done at repair shop, I recommend one that has personnel trained in repairing the older style Electrolux vacuums like yours.
Dec 17, 2013 | Electrolux EL7020A Oxygen 3 Ultra Canister...
Hello. first id like to thank you very much for helping me. There is no problem really. Id just like to know if i can use other soap or product to clean the rug besides the kirby evaporated dry...
I would only use the brand intended to be used in this machine. Home Solutions Turbo Shampoo by Aerus Electrolux. This machine doesn't **** up water, and if used according to the directions, there really shouldn't be much water on the carpet.
Go to http://www.aerusvacuums.com/support/manuals/index.cfm
to download a manual for use instructions.
Or contact me for additional information.
Sep 05, 2010 | Electrolux Floor Pro Vacuum
Electrolux 6500 sr
take it to a vacuum shop. often these plastic machine are broken beyond repair when someone tries to take them apart at home. a vac shop should be able to diagnose the problem and provide and estimate for repair at little to no charge.
Jun 03, 2009 | Electrolux Epic 6500 Vacuum
Hi, I have an electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the electrolux stop (has happened before) and when I pressed the reset button, the motor is on but...
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=678083
Generic problem for all Vacuums
Hi, I have an Electrolux Ambassador
Posted by greenforest on Jun 17, 2008
Hi, I have an Electrolux Ambassador and the other day I was vacuuming a fringe carpet and the fringe made the Electrolux stop (has happened before) and when I pressed the reset button, the motor is on but the wheel does not spin. Any suggestions?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. There are 2 possibilities that could be happening. Either the belt is broken of which you can replace the belt @ least one a year for proper maintenance or there may be a reset for the vacuum in case you get something caught in the brushroll section of the vacuum. Check both of those items and it should work unless you have a motor burn out – if you did there would be a burning smell. Feel free to contact your local vacuum cleaner dealer in your area.
So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://electrolux.com/ Customer Service 1-800-896-9756
Electrolux Home Care Products – North America
P.O. Box 3900 Peoria, IL 61612
Thanks, Don the Vac Man
Go Ahead. Use Us.
Jun 17, 2008 | Vacuums
Electrolux Epic 8000
YES,JUST TAKE OFF THE HEPA FILTER.
IF I MAY SUGGEST,IF YOU WANT TO BUY AN AREUS/ELECTROLUX YOU MAY WANT TO LOOK AT THEIR "BOTTOM OF THE LINE" MACHINE, THE "CLASSIC" IT'S HALF THE PRICE AND A MUCH BETTER DESIGN THEN THE NEW "FLAGSHIP" MODEL, WHICH IS COMPLETELY DIFFERENT THAN ANY PAST ELECTROLUX. IT'S BULKY,AWKWARD TO USE. EVEN IF YOUR BUYING FROM ANOTHER SOURCE, GO INTO AN AERUS DEALER AND GIVE THEM A TEST DRIVE.
I CLEAN APARTMENTS FOR A LIVING AND AM VERY FAMILIAR WITH ALL ELECTROLUX MODELS.
GOOD LUCK!
Apr 01, 2008 | Electrolux Epic 6500 Vacuum
Electrolux 2000 canister vacuum cleaner
The first two solutions are liars!!! The way to open an Electrolux LE canister vacuum is to use a screwdriver or drift punch and hammer to gently tap the two bumpers on the sides of the vacuum towards the opening end (where the bag goes in). The bumpers will slide off and then the clamshell case will open lengthwise. There is NO maze of vacuum hoses or wires inside. I just repaired my own vacuum and am speaking of experience.
Feb 11, 2008 | Electrolux UltraLux 2000 Bagged Canister...
Electrolux 2100
Call your local Aerus Electrolux office. If there is a problem in the electrical system you should get that checked before you continue with the machine. As for the cord replacement- Any Aerus service dept. can do that for you. I say an Aerus office because should you let a non-Electrolux employee work on it you will void your warranty.
Dec 08, 2007 | Electrolux UltraLux 2000 Bagged Canister...
Open Questions:
Vacuums Logo
26 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
