Question about Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive
How to set jumpers in an old quantum fireball Lct20 HD. The master mode needs to be "jumpered"
    Champion:
  • 201 Answers
Please look on top of your HD and u will see a table that show u the HD jumper setting (Master, Slave or Cable Select).
Then look again the rear side of the HD and u will see some pin that locate beside the power input of the HD, that is the jumper pin.
Now set the jumper according to your requirement refer to the jumper setting table just now. To set it just unplug the jumper (look like a U shape contactor covered with plastic) and plug it back according to the requirement. Sometime u may lost the jumper contactor, nevermind just use what ever conductor cable to roll between the two pin and make sure the pin is connected that all.
YBC (/\)
Posted on Oct 06, 2009
Testimonial: "I did what you say, there is 4 pair for 3 posibilities (master, slave, CS). After all, I set pins properly. Thank you "
    President:
  • 3,278 Answers
Hello!
Here are your jumper settings:
Hope this helps.
Set jumpers
if you look on de gd it shows you to set the jumper on Master and slave just take a closer look
Feb 14, 2011 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum Fireball lct 30gig not recognized in Dell Dimension 3000
Turns out this particular drive needs TWO jumpers on it, to set it to CS. I received it used with a single jumper in the Master position, but after checking the Maxtor/Quantum website, it listed the jumper positions and showed the second jumper. As soon as I installed the TWO jumpers in the correct position, the Dimension 3000 booted right up and let me reinstall Windows. I had scoured the internet for many hours looking for a solution, none solved it until I decided to check the manufacturers website. Always start there!- Solved!
May 18, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Setint the jamper as a 2nd drive and Do i need to farmat it frist
If I recall right this HDD is a PATA (IDE) type. As for the Jumpers please check the following link. The jumper should be as Slave drive.
http://www.helpwithpcs.com/upgrading/install-hard-drive.htm
May 15, 2009 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Problem putting a 30 gig quantum lct 15 3.5"series as a slave
Did you switch the jumper config back to Master or CableSelect before trying to install them as a single drive? Also check the Maxtor website, (they owned Quantum too), for the correct jumper settings. Some of these drives (like the Quantum Fireball lct series) need TWO jumpers not just one.That was the trick that fixed mine from not being recognized by the Bios or the Windows setup disk....I got it used with only a single jumper, but it needed two to put it Cable Select mode.
Apr 07, 2009 | Quantum Fireball Lct20 (QML30000LD-A) 30...
I have a quantum fireball 20.4 gig drive where do the jumpers
There is normally a sticker on the drive, which indictates the settings.
Jan 04, 2009 | Quantum Fireball Lct20 40 GB ATA-100 Hard...
Jumper switch settings
I have the same thing and here is your solution.
http://www.babooforum.com.br/idealbb/files/152532-Maxtor2.jpg
Worked perfect for me afterwards. :)
Sep 16, 2008 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum fireball 40 not recognised as master
goto the quantum site and verify the jumper setting on the drive first
if correct then.. check your sata cable is good...
check the bios to boot options so the quantum is set to boot...
under boot options .. hard drives.. sort the drive to be the first to boot
Jan 04, 2008 | Quantum Fireball Lct20 (QML20000LD-A) 20...
Hard drive quantum fireball lct 20
go to quantum website, download manual, check for correct jumper settings
Dec 03, 2007 | Quantum Fireball Lct20 (QML30000LD-A) 30...
Quantum Fireball Lct20 (QML20000LD-A) 20 GB Hard Drive Logo
5,002 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
