Question about Linksys Wireless-G WRT54G Router
Uplink internet (PPPoE) will not be accessible after power cut
The problem seems to me close to identical.
Following a power cut with both computer and router "on", it is possible to see that:
a) all the computers are assigned IP addresses by the router and can access each other
b) the router connects to the internet (PPPoE)
c) the computers cannot access the internet (!?)
Now, I have fiddled with the problem quite a bit. I can't figure out *exactly* what happens but I suspect the problem is two-folds:
1) whatever you might reset on the computer (network connection, internet connection, etc.) it won't work by itself.
2) whatever you might re-set (and not reset) on the router won't work by itself.
3) however, if you reset the router (10+ seconds press on the little button on the back), re-enter all the parameters (that takes typically 5 minutes usually, not an hour, unless you are a network tycoon that uses all the settings) and then "repair" (right click on the connection) the network connection then "voilà".
In summary, the router has a problem (needs to be reset) but then Windows has conflict issues with the router and needs its connection reset too. Well, that is my hypothesis. I am NOT a network admin and I barely know DHCP, IP, Gateway stuff... What I have noticed is that while the router is not "sharing internet" with the computers, windows has a "internet gateway" connection automatically up and running, while once the router is reset, windows "sees" there is nothing such as a router gateway and removes it. When the router is fine, and the windows connection is"repaired", and internet works at last, THERE IS NO INTERNET GATEWAY in the connection panel of windows anymore. I think there is something there that might generate conflicts, but hey, I need the words of an expert out there! (please note that the term "internet gateway" might not be the exact term, and I don't intend to switch my electricity breakers off to reproduce the problem...).
*practical note: I haven't tried yet, but instead of re-entering all the router setting manually, I guess a router configuration backup saved while everything works fine can be reloaded when things are bad, that would save the 5 minutes of manual re-entry.
So, anyone wishes to rationalize all that?!? What is THE exact problem and what is the systematic and exact way to fix it?
--I love my router anyway---
  • 2,260 Answers
You are using the PPPOE connection. when you set up the router for the PPPOE connection, Do you see Internet IP address on the status page of the router.
If you have the internet IP address on the status page of the router then that is a very good thing. make sure that it shows the Internet connection type pppoe on the status page also.
your computer are communicating with each other they have the IP address that is a good thing also.
Now you can check the internet connection.
open the command prompt ( START ==> RUN == type cmd and click OK) In the command prompt try to ping the router IP address.
Suppose your router IP address is 192.168.1.1. then in the command prompt type " ping 192.168.1.1 " and hit ENTER on your key board.
You will get replies from the same IP address that is 192.168.1.1.
that means the connection between the computer and the router is working properly.
Now type in the command " ping 4.2.2.2 " and hit enter.
If you get the 4 replies from 4.2.2.2 that means you computer is communicating with the DNS servers. If you get the reply form different number or if you do not get replies that means the router is not set up properly or user name and password for the pppoe might not be proper.
Now you got 4 replies from 4.2.2.2.
Then type the command " ping yahoo.com" and hit enter.
Now check if you get replies from yahoo.com ( there might be replies from the number 66.x.x.x. or 207.x.x.x).
If you get the replies then everything is working properly. the issue might be with the firewall or internet browser.
Now if you don't get replies from yahoo.com but getting replies from 4.2.2.2 that means you will need to assign static DNS numbers on the computer.
In preferred DNS = 4.2.2.2
in alternate DNS = 4.2.2.3
that will resolve the issue.
Click Here for more info about the networking
Posted on Oct 07, 2009
What is 2Wire161 and what does it do?
it is a dsl modem and wireless router with 4 port switch all in one!
it recieves its internet through the phone lines via pppoe and cannot uplink to anything other than DSL. it can however be used as a wired wireless AP or four port switch in a pinch.
Aug 02, 2012 | NetGear WGR614 Wireless Router
Why can't I connect to the internet via my router but when I connect directly to the modem, I have internet access
If you don't reset the modem after connecting the router, the modem is still trying to send data to the MAC address of your PCs network card.
You need to disconnect power from everything, then power up the router first.
Once the LEDs on the router settle down, power up the modem.
Once the modem's LEDs have settled down, power up the computer.
You should now be able to access the internet through the router.
The only time this won't resolve the issue is if the PPPoE negotiation is being done by the PC and not programmed into the modem itself.
This is almost unheard of with modern DSL and ADSL modems today, but if that is the issue, you will need to contact your ISP for the information you will need to program the router to do the PPPoE login through the modem and reconfigure the computer to not do the PPPoE authentication any more.
Jul 21, 2011 | Linksys Wireless-G WRT54G Router
Installing a netgear router
It seems that you need to reconfigure router ,you can use following steps to reconfigure router
1. Please remove all the connections from the router. Connect power to the router and then connect a cable from the computer into any of the 4 lan ports on the router. Make sure the modem should not be connected to the router or to the computer.
2. Open up the Internet Browser (Safari, Internet Explorer, Mozilla Firefox, Opera, etc.).
3. Put http://www.routerlogin.com/basicsetting.htm in address bar.
4. On the basic setting page scroll to the bottom and click on Apply.
5. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
6. Click on lan ip setup under advanced.
7. Change the lan ip to 192.168.10.1 and under use router as a dhcp server change the starting ip as 192.168.10.2 and ending ip as 192.168.10.51, click apply and click ok for any popup message that arise.
8. Once the browser display some error message like CANNOT FIND SERVER, ACTION CANCELLED etc, Connect the dsl modem on the wan port of the router and restart the computer.
9. Power off the dsl modem and the router after making the connections.
10. Power on the dsl modem and wait till the dsl light comes on, then power on the router.
11. Open a web browser (Internet Explorer, Mozilla Firefox or Safari).
12. Access the router (http://192.168.10.1).
13. Login to the router (Username = admin Password = Password).
14. Click on Setup Wizard and then select "Yes" and Click "Next" on the detection window.
15. It should give you a "Dynamic IP Detected" or "pppoe detected"(type the Username & Password of your dsl account in case of pppoe detection) and then click next.
16. Click Apply.
17. Logout of the router.
18. Open up another browser window and try to access internet.
May 17, 2010 | NetGear WGR614 54 Mbps Wireless Router -...
I'm having trouble with my DLINK dir-615 router. I can get a connection to the router through a wired connection and I also can connect to the router via wireless. I CANNOT get access to the internet...
I believe you have an IP Address conflict or the router needs to be configured for PPPoE. Here's how:
Basic DSL Setup - PPPoE
Most Internet Service Providers offer PPPoE authentication. Please consult your ISP if you are not sure if PPPoE could be used.
To configure your router for PPPoE you will need to set your router's WAN (INTERNET) port to 'PPPoE' option. However majority of Modems nowadays already have PPPoE enabled. If your modem has PPPoE client built-in, you need to select the 'DHCP' option in your router. The router is set to this option by default.
Configuration steps:
Step 1
Connect the broadband modem to the WAN (INTERNET) port of your router. If the modem has USB connection make sure that it is NOT connected to any computers via the USB cable and that the modem is switched to Ethernet (not USB). Only the modem's Ethernet port should be connected to the router's WAN (INTERNET) port.
Connect your computer(s) to the router's LAN port(s) or establish connection to it wirelessly.
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.0.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default is `admin' (optional) and password is blank (nothing).
Step 3
After logging into the router select Setup. Set Internet Connection to 'PPPoE' option.
This can be done by either clicking on Internet Connection Setup Wizard or if you want to set it up manually, then click on 'Manual Internet Connection Setup'. Note that it is very common for broadband modems to carry out the PPPoE authentication for you. In this case you need to select the 'Dynamic IP' option (DHCP) in your router, do not select PPPoE. If you have such modem proceed to Step 5
Step 4
If your broadband modem does not have PPPoE function, select the 'PPPoE' option in the router and enter your account details (username and password given by your ISP). Note that some ISP's require username to be as your full e-mail address (ex: username@ispname.com).
Step 5
Click on SAVE SETTINGS and then on REBOOT THE DEVICE to apply the new configuration. Recycle power to modem.
You do not have to run any login client (like PPPoE) on your computer in order to connect to the Internet. If you had it setup when using the modem without the router, disable it in Internet Explorer under Tools > Internet Options > Connections > set to 'Never dial a connection'.
If you did not have to run PPPoE login client on your computer when modem was directly connected to your PC, your ADSL modem has PPPoE built-in. In this case set the router's WAN (INTERNET) port should be set to the 'Dynamic IP' option.
If your ISP requires PPPoA connection you need to make sure that your ADSL modem supports PPPoA (PPPoA can not be used on Routers which do not have ADSL Modem built-in). If your modem will be carrying out PPPoA connection you need to set your router's WAN (INTERNET) port to the 'DHCP' option.
If you are having difficulties accessing the Internet:
- Turn the modem and the router off for a minute and then turn the modem first and then the router.
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.0.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
- Select the MAC Cloning option. Click on Clone MAC Address button. Do this from the computer which the broadband modem was directly connected to the last time. This will place the MAC address of your computer into the router. Save settings and reboot the router. Reboot your broadband modem as well.
- Uninstall your antivirus software (sometimes disabling or closing the software is not enough) and reboot your PC.
Oct 22, 2009 | Computers & Internet
I downloaded latest security software from apple. now my wireless linsys g wrt54g won't work. I can connect directly to dsl, but can't make any connections with the router. I reset the router since it...
Step 1
Step 2
Open your Internet Explorer and log into your router by typing in its IP address (in most cases the default IP is http://192.168.1.1 ). Note that you do not have to be on the Internet in order to access this address because you are just connecting to your router's address. Specify username and password for your router, the default password is `admin' (optional) and username is blank (nothing).
Step 3
Step 4
Step 5
- Log into the router and go to Status page. Note what IP address it is getting on the WAN (INTERNET) interface. If the IP address you see under WAN (INTERNET) appears to be in the same range you are using on your network (e.g. 192.168.1.x), you will need to change the range you are using on your LAN to something different, e.g. 192.168.88.x. You can do this on your router under Setup > LAN Setup. Note that after changing the IP of your router you will only be able to access it through its new IP, e.g. 192.168.88.1.
Oct 06, 2009 | Linksys Wireless-G WRT54G Router
Hi there! ;) I've recently changed password of my AT&T Yahoo email account. It led to the corresponding password change for the DSL connection at my home. During establishing this connection (while...
To access the Zoom Configuration Manager (web-based configuration utility)
  1. Close any open programs including antivirus and pop-up blockers.
  2. Open a web browser, and in its address bar, type http://10.0.0.2 (or http://192.168.0.1 for Zoom ADSL X6v users) and then press Enter (or Return).
  3. In the Enter Network Password dialog box, type the following username and password in lowercase then click OK. (Note: The modem User Name and Password you enter here are NOT the same as the User Name and Password that your Internet service provider may have given you.)
    • User Name: admin
    • Password: zoomadsl (where "l" is a lowercase letter L)
Mar 04, 2009 | Zoom (5590-00-03) Wireless Router (G66115)
Installation CD
I lost my installation CD and received these instructions from the Belkin Tech Support, and was able to install the Wireless N Router with no problems.
Follow the steps given below for configuring the Belkin N router manually.
- Connect the computer to the "LAN" port on the router and connect the modem to the Internet/"WAN" port, using Ethernet cables.
- Take a paper clip, insert the paper clip in the reset hole of the router and hold it for 15 seconds.
- The power light will flash and then come back "ON" solid, indicating that the router is being restored to factory defaults.
- The corresponding lights on the front of the router should be lit up.
- On the computer, check if you have an IP address in the range of 192.168.2.x.
- If not, specify a static IP address, gateway and "DNS" address by following the steps given in the link-
http://web.belkin.com/support/kb/kb.asp?a=2824
- Log on to the router web interface by typing in http://192.168.2.1, in the address bar of your browser.
- By default, the password is blank.
- Click on "Connection Type" in the left hand column under "Internet WAN" heading.
If the connection type is Dynamic (cable):
- Choose "Dynamic" and then click on "Next".
- Type in your “Host Name”, if you’re Internet Service Provider has provided it. Else, leave it blank.
- Click on "Change WAN MAC Address".
- Click on the button "Clone".
- Click on "Apply Changes".
If the connection type is PPPOE (DSL):
- Choose "PPPOE" and click on "Next".
- Enter the user name and password given by your Internet Service Provider.
- Save the settings.
- Click on the "Home" link at the top of the screen.
Internet Status should show "Connected" on the top right hand corner of the web page.
If the problem persists, please get back to us with the following information:
1. Type of connection provided by your ISP (Is it PPPOE, Dynamic or static).
2. Name of the Internet service provider (ISP).
Aug 11, 2008 | Belkin Wireless-N Wireless Router with...
How To Set Up PPPoE DSL Connections with a WRT55AG Router
STEP 1: Before You Begin In order to set up your Linksys Router, be sure to first have the following: 1. A Linksys Router. 2. A DSL modem. 3. A working computer that can be wired in directly to the router for initial configuration and testing. 4. Two (2) standard Ethernet network cables. Linksys Routers come with one (1) standard network cable that you can use. 5. The PPPoE DSL username and password assigned by your Internet Service Provider. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. STEP 2: Check Your Internet Connection Before installing your Linksys Router, it is important to first verify that you can successfully access the Internet by connecting directly to your modem (without your Linksys Router installed). 1. If you are connecting for the first time, follow the instructions provided by your provider to set up your modem and computer for online access. 2. Verify that you are able to access the Internet without any problems. If you are not able to get a connection, contact your Internet Service Provider for assistance. When you are able to access the Internet using your modem, continue to Step 3 and proceed with the installation of your Linksys Router. STEP 3: Connect the Hardware Follow these steps to connect your Linksys Router to your modem and computer. 1. Shut down your computer and unplug the power cords connected to your modem and Linksys Router if they are currently powered on. 2. Disconnect the network cable that connects to the back of your computer. 3. Connect the network cable that you just removed to the Internet port (or WAN port) located on the back of your Linksys Router. Your modem should now be connected to your Linksys Router. 4. Connect a second network cable back into your computer (into the same port that was disconnected in #2). 5. Connect the other end of the second network cable to one of the numbered ports located on the back of your Linksys Router (labeled 1, 2, 3, 4, etc.). Your computer should now be connected to your Linksys Router. The following diagram shows how your network should be connected. Verify that your connections are correct, and continue to the next step. 6. Plug the included power adapter into the router?s Power port. Then, plug the other end of the power adapter into a nearby electrical outlet to supply power to your router. 7. Turn on your computer. Do not turn on your modem at this time. Only your router and computer should be turned on for Step 4. STEP 4: Configure the Router Follow these steps to configure your Linksys Router. 1. On the computer that is connected to the Linksys Router, open a web browser such as Internet Explorer or Netscape. 2. Type http://192.168.1.1 into your browser?s Address or Location bar and click Go or press the [Enter] key on your keyboard. The IP address 192.168.1.1 is the default IP address of Linksys Routers. 3. A user name and password prompt will appear. Leave the user name field blank (empty), and type in admin (lowercase) for the password. The password admin is the default password of Linksys Routers. NOTE: The following username/password prompt screen will vary by operating system. 4. Once logged in, the router?s web-based Setup utility should load. In the section labeled Internet Connection Type, or WAN Connection Type depending on router model and firmware version, select the PPPoE option on the drop down list. Click here to view what an older Linksys router interface looks like. 5. Once PPPoE is selected, enter your PPPoE DSL username and password provided by your Internet Service Provider into the router?s User Name and Password fields. Depending on the provider, your username format might be similar to username, vzn123456, or an e-mail address (username@isp.net). If you are not sure what your username and password are, contact your Internet Service Provider for more information. NOTE: Be sure to clear the ?Password? field before entering your account password. AOL USERS: Enter in your PPPoE username as screenname@aol.com. 6. If the Keep Alive option is not selected, be sure to select it instead of the ?Connect on Demand? option. The ?Keep Alive? option will ensure that your connection stays connected even when it is not in use. 7. Scroll down to the bottom of the page and click on the Save Settings, or Apply button depending on router model, to save your changes. OR 8. Once your changes are saved, you will be presented with a button to return or you will be returned to the previous page automatically. If prompted, press Continue to return to the router?s Setup page. 9. Close and exit the web browser. STEP 5: Power Cycle Follow these steps to power on and off your devices in the correct o
Feb 16, 2006 | Linksys WRT55AG Router
Linksys Wireless-G WRT54G Router Logo
241 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
