Question about Toshiba Satellite 1005-S157 Notebook
CANNOT USE ETHERNET ADAPTER - Toshiba Satellite 1005-S157 Notebook
Sony bravia lcd tv 40 inch
I have a Sony Bravia 46'' TV. I bought a Universal WiFi Adapter from Walmart a few years ago for about $50. You have to plug it into the Ethernet port on the Bravia using an Ethernet cable (the other end of the Ethernet cable goes into the Ethernet port on the adapter). The adapter needs also a power outlet. I do not remember if the adapter came with the Ethernet cable (likely) or I had to buy it separately.
Before buying the adapter make sure that:
1. Your Bravia has an Ethernet port (on my Bravia it is in the back of the TV), and
2. You have/use a wireless router for your home network.
Hope this helps.
Jun 22, 2014 | Sony BRAVIA Televison & Video
Digitech usb to ethernet adapter
That usb is usually for keyboard or mouse, interesting that you got it to work. It would depend on if android has a driver for the Ethernet adapter built in. Any reason why you are not using the wifi?
Feb 05, 2014 | Computers & Internet
Dell optiplex GX620 desktop has an ethernet port on it, that is not an adapter, I cannot connect to the internet, I downloaded and installed a driver for a wireless ethernet adapter, but that has not...
Okay,..........
1) You can download a wireless Ethernet adapter driver all day, but if you Do Not have a wireless adapter card installed in your computer, the drivers do you no good.
Or if you do not have a wireless USB adapter plugged into a USB port.
Example of a wireless adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4695358&CatId=2692
Example of a wireless USB device,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=6367137&CatId=2692
Example of an Ethernet adapter card,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=686143&CatId=200
If you are just going to hardwire the computer, just buy an Ethernet adapter card, (PCI version), and install it in your computer, (On the motherboard), in any available white PCI slot.
IF it is the Mini Tower model.
The Desktop, Small Form Factor (SFF), and Ultra Small Form Factor (SFF) computers, are too small in width for a regular size Ethernet adapter card.
They need a Low-Profile Ethernet adapter card,
http://www.newegg.com/Product/Product.aspx?Item=N82E16833114034
This is for a Dell Optiplex GX620 Mini-Tower computer,
http://support.dell.com/support/edocs/systems/opgx620/en/ug/A02/mtabout0.htm#wp1051997
Scroll the page down until you come to the bold blue heading - System Board Components
This is an illustration of a Top view of the Mini-Tower's motherboard.
16 and 17 point to two PCI slots.
This is where an Ethernet adapter card that is the PCI version, will plug into.
PCI slots are White in color.
An example of a basic PCI slot, ( 3 are shown),
http://en.wikipedia.org/wiki/File:PCI_Slots_Digon3.JPG
If you do decide to go wireless;
1) Wireless networking operates at half of the speed of wired networking.
A computer that is wired directly to an Ethernet adapter card, is twice as fast on the internet, as a computer that is connected wireless.
2) Make sure your Router is capable of wireless.
Make sure the wireless router has a built-in Modem, or that you have a separate Modem.
[ For DSL.
Phone line connects to Filter. Filter has a place for a telephone cable, and an Ethernet cable.
Ethernet cable connects to Filter, and other end connects to Modem.
Ethernet cable goes from Modem to Wireless router that does not have a built-in Modem.
OR,
Phone line connects to Filter. Ethernet cable from Filter goes directly to wireless router, that has a built-in Modem.
Computer has to have a USB wireless device, or a wireless adapter card, installed.
For additional questions, or to clarify anything I have stated, please post in a Comment.
(Believe upper right of your page, blue Comment)
Regards,
joecoolvette
Sep 16, 2011 | Dell OptiPlex GX620 PC Desktop
No ethernet adapter or ethernet port
no ethernet adapter or ethernet port so u can't get net aceess so get ethernet adapter or ethernet port
Feb 14, 2011 | Gateway E-4100 PC Desktop
My router won't link up to my modem. I have a
make sure that you ethernet adapter is enabled. you should be seeing a two computer icon in the notification area. reinstall driver of your eternet adapter.
If you need further help, reach me via phone at https://www.6ya.com/expert/elixirjose_00375ea24bd8141b
Apr 01, 2010 | Powerline Ethernet Network Adapter
Can you explain to an idiot, which exactly what is the correct way to connect Powerline Adapters to orange livebox, I have connected Powerline Adapter to yellow ethernet socket is this correct with the...
Plug the PowerLine adapter into the wall
Plug one end of the ethernet cable into PowerLine wall adapter
Plug the other end of the ethernet cable into the Orange LiveBox
Plug the Orange LiveBox power adapter into the wall
Mar 09, 2010 | Powerline Ethernet Network Adapter
Ethernet adapter error during install
Your ethernet adapter might be disabled. Go to Control Panel > Network Connections and look for Local Area Connection. Right-click it and choose Enable. Or go to Device Manager and Enable it there. If that didn't help, try to use a different Ethernet cable.
Jun 02, 2009 | NetGear WGR614 Wireless Router
My Ethernet card doesn't work on my n845wn Intel
It's possible the drivers are not installed.. To check if drivers are properly installed for the Ethernet card, if you have win XP
* go to Start>Control Panel>System> click on Hardware tab, then Device Manager
- once you're on Device Manager, look for network adapter, you should see something like "Via Rhine II Fast Ethernet Adapter", this is just an example, you may have a different brand of Ethernet adapter
- if you can see the Ethernet Adapter and it has a green icon beside it, it should be working fine, you can also double click on it, to view the Status
- if you don't see the Ethernet Adapter on the list, look under the section "Other Devices", if you see an "Ethernet Controller" on the list with a yellow exclamation point, it means the drivers for the Ethernet Adapter were not installed, which means the drivers has to be re-installed
- you need the manufacturer cd for the drivers
*Now if there's no "Ethernet Controller" on Other Devices section, it's possible the Ethernet card is not being detected by the computer
- you may have to unplug the Ethernet card physically from the computer (computer must be completely turned off) then try to insert the Ethernet card again and boot up the computer, if the computer detects the Ethernet card, you need to install the drivers
- If the computer doesn't detect the Ethernet card, most probably it's busted. You may have to replace it.. You can also try to install the Ethernet card on a different computer just to check if it's really the Ethernet card or the motherboard that's the problem..
May 10, 2009 | Intel Desktop Board D845WN Motherboard
Ethernet adapter jack is broken
There are Ethernet to USB adapter such the products shown here. Alternately, you can use a PCMCIA card with Ethernet such as shown here.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 13, 2008 | Computers & Internet
Do I need an ethernet adapter with the siemens 587 router? I have an ethernet card that is enabled and working properly but I keep getting an error message saying that I need an ethernet adapter. The...
1. Test your system with another ethernet card to be sure of the status of your ethernet adapter.
if it works fine that means all is well,if not update the neworking protocols on your computer so that it would be compatible with the routers TCP/IP net. protocol
Apr 22, 2008 | Siemens SpeedStream 2624 Router...
Toshiba Satellite 1005-S157 Notebook Logo
35 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
