Question about HP Pavilion dv6000z Notebook
My lap top keep shutting down , right after i turn it on.It shows no picture , nothing just make a beeping noice if i try to press on any key and turns right back off and then turns itself on. I want to know what i can do to get it back to normal?
I have a dv6000 pavillion laptop and it was my motherboard, same problem, no video, no power, in fact I replaced it and then 4 mths later did it again, Im trying to figure out what to do with it, sell it or what because everybody who bought these computers are dealing with same problem! sorry we got scammed!
Posted on Oct 08, 2009
Nothing from my desktop shows up when I turned my lap top on. When I last shut down - I don't think I shut it down right. Got the spinning beach ball. Nothing is working now
Check for a failing hard drive
Trying booting from the Mac OS X install disc. insert the Mac OS X install disc. press the start button, while holding down the "C" key on the keyboard
Once you are running from the disc. go to Disk Utilities select the hard drive click the "repair permissions" button at the bottom.
If you get any red errors listed or it doesn't seem to finish repairing the permissions you have a failing hard drive and it will need to be replaced.
If you don't get errors you then need to reinstall your operating system.
Dec 26, 2010 | Apple MacBook Mac Notebook
Aw60447w digital watch. I cannot turn off the hourly beep. help
Hourly chime on/Off:
1.) Press and hold the lap/reset button (bottom right) to display alarm time
2.) While holding lap/reset button, press the mode button (bottom left)
3.) If the all the day of week indicators our lit, beep is on. If they are all off, beep is off.
Alarm On/Off:
A press of the lap/reset button (labeled) will show the alarm time, Unpress will show the time of day. Press again toshow the alarm time. Press and hold the lap/reset button will show the alarm time again, but it will hold there. While holding this lap/reset button, press the start/stop button (labeled). This will turn on (or off) the alarm (tiny indicator). Press this start/stop button repeatedly (while still holding the lap/reset button and you will see the indicator turning on and off with each press. Stop this button pressing with the indicator OFF, let up on the lap/reset button, and the time will return to the screen. The alarm will now be OFF.
Jan 26, 2010 | Swi Watches
My lap top beeps and will not recoognise the keypad buttons
You may have a bad memory stick or your os may need to be reinstalled.
Try removing battery, press and hold power button for 5 seconds and then put back in and turn on and see if it works then.
Nov 12, 2009 | Toshiba Portege 4010 Notebook
I cannot get my lap top to show on the all with my projector
Laptop will often have a function key (usually F5) for cycling between built-in display, external monitor, and both. Try pressing F5. If that doesn't work and you have a "Fn" key (usually near the left Shift key) hold down Fn and press F5.
Oct 11, 2009 | Compaq Presario Notebook
I used The FN and F5 key and it worked
Go to the point where you have a stable picture even if it is huge. Right click on an empty space on the desktop and scroll down to properties. Click on settings and increase the resolution a little at a time hitting apply and checking the display as you go. Keep hitting ok to the display settings if you like them. Find the resolution and display size that suites you.
Sep 07, 2009 | Acer Aspire 5500 5570-2609 Laptop
Dropped lap top now wont boot up
press the fn key on laptop hold it down and then press the power key on the laptop. once u see any display on the screen you will get some tests running on the screen. The system will show you the error message which u need to note down. else you can do a Flea Power on your laptop. Remove the adapter and the battery and then press the power button and hold it down for 30 seconds then connect the battery and adapter back and try to turn on the laptop. See if the magic works for you
Jul 16, 2009 | Dell Latitude D600 Notebook
I cannot restore my acer aspire 3630 lap top
hi you need to press the FN and F8,9 or 10 repetedly to restore it to default settings.
May 04, 2009 | Computers & Internet
My lap top worked just fine in the morning and went into sleep mode. The computer was unplugged so there isn't a power surge issue. I've tried shutting it down by holding down the power key, I removed the...
try the following steps.
1.remove the battery pack
2.press and hold the power button for 30 seconds.
3. plug in the ac cord to the wall and to your laptop, (make sure the light indicator on ac adapter is on)
4. press the power button once to turn on
IF this process fails, more likely you have a motherboard issue. South Bridge chipset may need to be resoldering or replaced
hope it helps yuva
Mar 26, 2009 | Computers & Internet
Password not working
To boot in Safe Mode, as soon as the computer begins booting tap the F8 key repeatedly.
You should get a menu to choose from.
If there select Safe Mode with networking.
If you can get that far, try System Restore for an earlier date.
If you can't get into safe mode watch as the comp boots and see if it says something like "For Recovery Press <One of the F keys>. Somesystems allow a partial recovery that keeps your documents intact. If you end up doing a full recovery, you lose everything.
Oct 19, 2008 | Acer Aspire 3000 Notebook
Keyboard problem's
Yeah lol!!! shot the cat!
press the fn key and there should be a num key at the very top press those!
Dec 02, 2007 | Acer TravelMate 2300 Notebook
HP Pavilion dv6000z Notebook Logo
96 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
