Question about Lexmark X6570 InkJet Printer
How do I edit a name in the fax phone book? Just need to add a space between first and last names.
3 Suggested Answers
SOURCE: FAXING
right click on the for the printer, Left click on 4200 ALL IN ON CENTER (top). Look at the top right hand corner and you will see FAX UTILITY, go thru those steps. Email me if you are still having problems. burpo01@aol.com
Posted on May 09, 2008
SOURCE: Faxing
By deleting them from the setup menu
Posted on Apr 21, 2009
How do I set up speed dialing on my HP Officejet 5740
While "Speed Dialing" or "Speed Dial" is listed in its fax specifications on some sites, it appears to be a mislabeled categorization of its group fax feature as HP's manual makes no other mention of it--save to say, the "fax to multiple numbers" (or multiple recipients) feature. There does not appear to be a speed dial list, but there is a phone book feature for adding contacts (individual numbers) & groups. (The following is detailed in a more explanatory way on pages 65-66 of the user's manual (http://support.hp.com/us-en/product/HP-Officejet-5740-e-All-in-One-Printer-series/6617253/model/6617254/manuals?cc=us&lang=en).
1. From the printer control display, touch Fax.
2. Touch Send Now.
3. Touch the telephone symbol to access its phone book feature.
4. Touch the person symbol for a phone book contact; or touch the multiple person symbol for a group of phone book contacts.
(Note: Contacts should be established before any of these could be added to any group.)
5. Touch + (plus sign) to add a contact/group; or touch the gear symbol (edit) to edit/delete a contact/group.
6. Touch Name.
7. Changes to contacts/groups:
•Adding a contact/group: type the name, & then touch Done.
••Adding a fax number to a contact: Touch Fax Number, enter this contact's fax number, & touch "Create".
••Adding a contact to a group: Touch Number of Members, select all of the contacts to add to this group from this printer's phone book, & touch Select followed by touching "Create".
•Editing: Select the contact/group name, & then touch Done. Then...
••Editing a Contact: touch Fax Number, enter the fax number, & touch Done.
••Editing a Group: touch Number of Members & deselect the contacts to remove from this group or touch + (plus sign) to add contacts to this group. Then touch Done.
•Deleting a contact/group: Select the name, & then touch Delete followed by touching Yes.
Feb 25, 2015 | HP Office Equipment & Supplies
NEED HELP IN SET UP SPEED DIAL NUMBER
To enter or edit a speed dial number on the Uniden D1788, go to PHONE BOOK (the book icon), when SELECT appears use the up/down arrows to select the previously entered phone book name, press MENU/SELECT (EDIT appears), press MENU/SELECT (EDIT NAME appears), press MENU/SELECT (EDIT NUMBER appears), press MENU/SELECT (SPEED DIAL - XXXXX) appears. Now, to assign a speed dail number, use the up/down arrows to select the desired speed dial number (Expl: SPD2) and then press MENU/SELECT to save it. The selections are SPD0 to SPD9 and also NO SELECTION to remove an existing speed dial number. You can also assign a speed dial number that's already used to a different phone book name. It will remove it from the old name and reassign it to the new name. Use the above procedure to assign a speed dial number to a new phone book entry when SPEED DIAL appears.
Nov 05, 2012 | Uniden DECT 6.0 Cordless Phone System...
How to add new contact to phone book
There are several ways to enter a number into your Phone Book:
1. Call GreatCall Customer Service for assistance 24 hours a day, 7 days a week at 1-800-733-6632.
2. Create an account at mygreatcall.com and modify your Phone Book online.
3. Manually enter a number into your phone.
To manually enter a number, it depends somewhat on what model phone you have - either the Jitterbug Original/One Touch or the Jitterbug J. In all cases, you will need to open the phone and access the Phone Book menu option. With an Original or One Touch, this can be done by pressing NO until you see PHONE BOOK listed at the top of the screen. With a J, you will press YES once the option for PHONE BOOK is highlighted in the center of the screen.
Press the up arrow and you will see the option EDIT PHONE BOOK. Press YES to select. Press YES again to select Add. Now you will be prompted to type in the name of the contact using the Triple-Tap method. Each number corresponds to 3 letters. Tap the appropriate number in quick succession until you see the letter you want to enter. Use the "#" to enter a space.
Example: To enter the name "John," you would press 5-666-44-66.
Once you are satisfied with the name, press YES to select DONE. You will then be prompted to enter the number. It is recommended that you include 1, the area code, and then the 7-digit number even if it is a local number.
Example: 1-760-555-4321
Once done, press YES again. You will see the message Successfully Added and you are done!
Jun 17, 2011 | One Touch Jitterbug One-Touch Cellular...
How do you add to existing contact list
Jan 04, 2011 | One Touch Jitterbug One-Touch Cellular...
I wish to add new contacts and delete obsolete one. Help!
Dec 18, 2010 | One Touch Jitterbug One-Touch Cellular...
How do i add phone numbers
Oct 21, 2010 | One Touch Jitterbug One-Touch Cellular...
Updating a Group Fax
Assuming the group name will remain the same, you can edit the Sender's name and/or phone number by doing the following:
  1. Go through the procedure to Add a Contact or number
  2. When you reach that Contact, you can edit by pressing the < key to move through the name or number
  3. Press Delete key to remove the name and re-insert the name/ same process for editing the number
The process is as follows to get to the option you need:
  1. Open all three one-touch dialing panels
  2. Press Data Registration
  3. Use up down arrows to get to Add. Registration
  4. Use up down arrows to get to Touch Spd Dial
  5. Use up down arrows to get to the desired Contact name or number
  6. Use side arrows to move cursor
  7. Use Delete key to remove and re-enter Name and/or number
  8. Once the name/number appears as you want it, Press "SET"
This should change the name/number individually and in your group.
Best of luck.
Greg
Jun 17, 2009 | Canon Office Equipment & Supplies
Nokia E71 - Saving new contact
check your phone memory limit may be it is full.
if it is still empty u need to reset all settingms of your cell phone to factory defaults.
Go to setttings then reset your celll phone.
but i think your cellular limit is over for save new contact check it .
Apr 05, 2009 | Nokia Cell Phones
How do I enter phone numbers into the address book for faxes
select (custom settings) then (address control)
then (diret address) its easy from this point
Mar 05, 2009 | Sharp AR-M455N Copier
Samsung d900i
Create contact (Menu 2.3)
Use this menu to add a new contact to Phonebook.
Storing a number in the phone’s memory
1. Select Phone.
2. Change the settings or enter information about the
contact:
First name/Last name: assign a name.
Mobile/Home/Office/Fax/Other: add a
number in any category.
You can change the number type, or set the
number as the default for the contact by
pressing <Options> and selecting Change
type
or Mark as default number.
Email: assign an e-mail address.
Graphic ID: assign a caller ID image to alert
you to a call from the person.
Ringtone: assign a ringtone to alert you to a
Group: assign the number to a caller group.
Birthday: enter the person’s birthday.
Notes: add a memo about the person.
3. Press <Save> or [ ] to save the contact.
Storing a number on the SIM card
1. Select SIM.
2. Select New or Update.
3. Enter information about the contact:
Name: assign a name.
Phone number: add a number.
4. Press <Save> or [ ] to save the contact.
Mar 05, 2008 | Samsung SGH-D900 Cellular Phone
Lexmark X6570 InkJet Printer Logo
12 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
