Question about Mitsubishi WD-62525 62" Rear Projection HDTV
Mitsubishi wd-62525 sound will come on but no picture.
Green timer light comes on when powered up but after 30-60 seconds TV goes off and red lamp light comes on steady. Replaced lamp but get the same thing. Before this happened, I would turn TV on and get a screen with rolling lines and garbled color. TV worked perfect yesterday. Tried to reset but get the same thing. HELP!!!!
  • 115 Answers
Your tv would turn on if you replace the only two 3300µf@16v capacitors on the power board . You wil notice they are bad by the way they bulge up at the top and may be leaking electrolyte a little from the tops . But the rolling lines would still remain but much less noticable.Then other symptoms will eventually appear. Truth is many many many many other capacitors need to be replaced inside the electrical chassis. Your TV would need to go to a repair shop that is expierienced in that repair because it is so extensive.
Posted on Oct 06, 2009
Mitsubishi WD-62525 TV will not turn on
Hi,do you hear any strange noises? If you hear clicking or like wanting to turn on it could be the board that powers the lamp it's called the ballast.Here's the instructions to replace it for a samsung ,it works like your mitusibishi:http://www.fixyourdlp.com/guides/samsung/bp47-00033a.php The ballast has a sensor that detects when it's not able to power the lamp or if lamp is not responding,it will flash red when that sensor detects that.When you say: "it began to roll like the vertical and horizontal hold did not work then the sound went out" Do you mean you where getting horizontal lines? If you did that could be the Dmd.his is how it works: http://electronics.howstuffworks.com/dlp1.htm Basically the light of the lamp goes through a tunnel that carries a color wheel(rotating disc with a gamma of colors that creates the colors on your tv)then the light of the lamp goes through the DMD board which is a chip composed of around 2 million pixels that creates the images and colors.When it starts to fail it will create black bars,pixelation,color distortion or white dots on screens. Usually when there's a green light it could indicate a problem with the power supply,sometimes some capacitors do go bad. Check all of this and comment on this answer to see how it went.
Apr 08, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Tv tries to turn on but then turns off with a red
Lamp light on again?must replaced the lamp again,the lamp hours it up.
Mar 30, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi wd62525 replaced lamp still no picture
If Fans are OK and color wheel is running then it is the Ballast Board Call Encompass Electronics or visit website 1-800-638-3328 they will have part number and price I found Ballast board for my DLP for only $65.00 on E-Bay Depends on who has what for sale.
Oct 05, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Red flashing status light
Press and hold the "Device" and "Menu" for 5 seconds and see what code comes up....... 12 No error detected
22 Recovery from momentary Reset
32 Lamp Cover open
33 Air Filter Cover open
34 Lamp abnormality
35 Chassis Fan failure
36 Exhaust (Back Cover) or Lamp Ballast Fan failure
37 Engine (DMD or Lamp) Fan failure
38 Excess Lamp Temperature
39 Excess DMD Temperature
41 Short Detected
44 DVI Cable (between Chassis and Engine) disconnected
Apr 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
No picture or sound mitsubishi 62525
Capacitor failure is the most likely scenario the FMT ans Signal PWB would cause the picture interference and the power pwb would cause the lamp light to turn red and give a 34 code when the device/ input and menu buttons are pressed in together and held for five seconds. That chassis has issues with every board in the chassis having failed capacitors you can get repair kits for the V26 chassis at the follwing link that come with instructions. Your model is the V26 chassis. Heres the link.
http://servicemanuals.vstore.ca/
Jan 25, 2009 | Mitsubishi WD-62525 62" Rear Projection...
WD-62525 green timer light keeps blinking after lamp replacement
Did you let the green light flash for about 70 seconds? It goes thru a self check when plugged in and takes a little time
Dec 29, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi WD-62525 timer light keeps flashing after lamp replace
There is a tiny reset button to the left of the timer light. Press with a pin or something small, wait 60 seconds. Viola!
Mitsubishi WD-62525 62" Rear Projection HDTV Logo
164 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
