Question about Panasonic DVD-LS91 Portable DVD Player with Screen
Player will not read. Error code H03 shows up on screen.
  • 98 Answers
Dirty worm gear on laser (dirt or particles got caught not letting the pick up move easy go take apart but be careful many small screws and gears.
Posted on Oct 06, 2009
4 Suggested Answers
SOURCE: error code on Panasonic LS50 portable DVD player
I also had the HO3 code...I re-alligned the laser..and now it reads the disk and shows the movie....BUT NOW I have no sound..?
I re-initialized the unit & still now sound...? IDEAS anyone..?
Posted on Jan 03, 2008
  • 4102 Answers
SOURCE: code h03
Hi the code HO3 relates to their being a problem with the laser you could try using a lense cleaner and see if its just dust or something like that failing that its going to be getting the laser replaced let me know if you need further assistance.
If you type in your search box this
DVD-LS90 Portable DVD Player with screen HO3
then search this will then list a load of sites that cover your dvd player and will also tell you what that error code means have a look and if you was getting it repaired then their should be a few sites that are selling the parts you need ok
Posted on Mar 19, 2008
Benimur
  • 6966 Answers
SOURCE: Error code HO3
On most Panasonic, error code HO3 indicates a mechanical problem, more specifically, the cradle that supports the laser eye could not traverse along its patch. Corrective action requires opening the unit, cleaning the slider bar, plastic cogs, worm gear/drive. It may help to use a can of compressed air and re-lubricate appropriate parts. Since the unit is open and expectantly dust would be swirling after the use of the compressed air, it may be to your advantage to swab/clean the lens itself prior to closing.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards. Thank you for using FixYa.
Posted on Aug 18, 2008
What does error H03 means af the Philips portable dvd PD9030?
Go to this link http://tech.rickumali.com/blog/2008/12/30/fixing-my-portable-dvds-h03-error
Aug 06, 2016 | Philips PD9030 9" LCD Portable DVD Player...
Whate causes Error H03 on a PANASONIC DVD-LS5?
the is not able to read the disk that's why you get that error message.the cause of error reading disk are busted dvd lens and the spindle motor it is the motor that holding the disk and spins .first try to replace the motor you can buy that in an electronics supply store next is try to replace the lens
Jul 17, 2010 | Panasonic DVD-LS5 Portable DVD Player with...
Portable dvd player h03 what to do fix it?
this error code means that there is something wrong with the laser lens most portable dvd players over time get weak motors or lenses you may try to take a small cloth or cotton ball and move the lens back and forth from the spindle to the end then place it as close to the spindle as you can then turn it on and you might be good to go! if not then you have a bad motor and may have to replace it! hope this helps!
Dec 18, 2009 | Panasonic DVD-LS50 Portable DVD Player
Error code HO3
Aug 18, 2008 | Panasonic DVD-LS90 Portable DVD Player
Panasonic DVD ls 850 H03 Code error, how to solve this problem
H03 is a mech problem if I remember you need to take the bottom cover off and remove the mechanical assy (laser chassis) then you need to clean the worm gear (this is the gear that moves the laser back and forth) even the littlest amount of dirt will jame this gear and make the unit go into H03 Mode
Jun 02, 2008 | Panasonic DVD-LS850
Pls help
H03 error means Traverse servo error. The spindle motor may be defective.
Mar 28, 2008 | Panasonic DVD-LS50 Portable DVD Player
Code h03
Mar 19, 2008 | Panasonic DVD-LS90 Portable DVD Player
Error code on Panasonic LS50 portable DVD player
I purchased my LS50 over 16 months ago. I had a H03 error before and it went away after sitting on the shelf for three days. It worked ok for another couple of months and then stopped again. The screen says reading but the motor is not spinning. i pointed out that the laser lens is in the wrong place. When at resting location, the lens should be parked near to the spindle in the middle. The mechanism to move the lens backward and forward sometime get stuck at the end of its travel - furthest away from the spindle. If your player is out of warranty, then you maybe able to try this. Open up the bottom cover by taking out the screws - 10 or so. This will reveal the lens and motor module. Flip over the model and you should see the gear and shaft for the lens. Move the gear so that the lens move towards the centre. Click the covers back into place , reconnect the battery and try. If it works, put all the screws back. Mine was fixed this way but this is not a gaurantee that this will work on yours. Good luck.
Forgot to mention. You can also clean the gear shaft in case there are small particules stuck to the grease and affect the movement. After cleaning, apply a tiny bit of grease just to lubricate the moving shaft. Not too much. I am glad that the instructions help.
Nov 25, 2007 | Panasonic DVD-LS50 Portable DVD Player
Error H03
I have had this problem for 2 years, mech.is hanging up. mine was replaced.... 3 weeks later same problem. I take out the disc and very GENTLY press one direction or the other to free it up. works great for a whole movie or several movies in a row. A small amount of electronic lube helps, just make sure you don't get it near the laser head or it will mess things up. Just clean it off real well if you get some on it.
Jan 06, 2006 | Panasonic DVD-LS55 Portable DVD Player...
Panasonic DVD-LS91 Portable DVD Player with Screen Logo
246 people viewed this question
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Jaime Hernandez
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
